    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 117.5k Views 16 Watching
      sdetweil @Shaitan
      @shaitan ok, I can’t help with the module operation… have no system like that
        Shaitan @sdetweil
        @sdetweil thanks anyway for this errors ! Less is the better !
        • G Offline
          goedh452 @Shaitan
          @shaitan
          Ok, so the module doesn’t produce any errors. I’ll dive into it to see what is causing the problem.
            Shaitan @goedh452
            @goedh452 ok thank you !
              Shaitan @goedh452
              @goedh452
              I started from zero to be sure that it is not a problem between your module and another program on my pi.
              So I did a new installation of MM on another Raspberry Pi with a clean raspian.
              Above, there is only your modules installed (I just copy my config.js from my other MM).
              Here is the MM launch screen with SSH :
              • G Offline
                goedh452 @Shaitan
                @shaitan
                The errors indicate that Domiticz cannot be reached. Would it be possible to temporarily disable the authentication in Domoticz and test it again?
                  Shaitan @goedh452
                  @goedh452 I don’t know how to remove the authentication on domoticz, I just added its IP to the whitelist and I got this:Nouvelle ie bitmap.png
                  G S 2 Replies Last reply Reply Quote 0
                  • G Offline
                    goedh452 @Shaitan
                    @shaitan
                    Just remove the username en password and save the settings.Schermafbeelding 2021-12-06 om 13.47.23.png
                      Shaitan @goedh452
                      @goedh452 Same screen
                        sdetweil @Shaitan
                        @shaitan said in MMM-Domoticz-ext: interact with Domoticz:
                        I just want to add for this and other folks…
                        when integrating multiple systems , 1st thing to do is disable all ip filtering/firewalls
                        in MagicMirror this is
                        address:"0.0.0.0", // let any outside system connect , "localhost" means ONLY apps INSIDE this same machine can connect
                        ipWhitelist:[],   // no restrictions on specific systems connecting.
                        once working, then u can add back whatever u might need… ,
                        and if it impacts the integration, then u will know as it is the last change…
                        • F Offline
                          Fabaude
                          Hello and thank you for this great module,
                          The installation and the settings went well but I can’t see my action buttons on my touch mirror.
                          The overview change buttons work well!
                          I integrated it into a page of MMM-Caroussel and MMM-GoogleAssistant operates my devices well but I cannot control the lights and others with touch buttons!
                          I hope to be clear and in the right place.
                          If you have any ideas…
                          Fab
                          • G Offline
                            goedh452 @Fabaude
                            @fabaude
                            Could you post your config of the module please? And are buttons not displayed at all or aren’t they working when you click them?
                            • F Offline
                              Fabaude @goedh452
                              @goedh452
                              I don’t know where the buttons should be? Are these the icons on my dashboard?
                              Here is my config and thank you.
                              				    module: 'MMM-Domoticz-ext' ,
                              				    header: "DOMOTICZ" ,
                              				    position: "middle_center" ,
                              					    apiBase: "xxx.xxx.x.xx" ,
                              					    apiPort: "xxxx" ,
                              					    updateInterval: 10 ,
                              					    animationSpeed: 0 ,
                              					    displayType: "actions" ,
                              					    alwaysShowDashboard: false ,
                              					    alwaysShowActions: true ,
                              					    showButtons: true ,
                              					    showTotals: true ,
                              					    showIcons: true ,
                              					    dashboardRooms: [ "1","2","3","4","5","6","7","8","9","10","11","12","13" ],
                              					    buttonAllLabel: "Tous" ,
                              					    buttonTypeLabel: "Par Types d'appareils" ,
                              					    buttonRoomLabel: "Par Pièces" ,
                              				        buttonBothLabel: "Par Types/Pièces" ,
                              					    buttonFloorLabel: "Par Types/Niveaux" ,
                              					    buttonDashboardLabel: "Tableau de Bord" ,
                              					    horizontal: true ,
                              					    columnCount: 15 ,
                              					    dashboardColumnCount: 15 ,
                              					    maxTitleLenght: 25 ,
                              					    switchLabel: "Lumières" ,
                              					    dimmerLabel: "Interrupteurs" ,
                              					    temperatureLabel: "Température Intérieure" ,
                              					    humidityLabel: "Humidité" ,
                              					    usageLabel: "Electricité Maison" ,
                              					    rooms: [
                              						    { idx: "7" , name: "Cellier" },
                              						    { idx: "6" , name: "Buanderie" },
                              						    { idx: "1" , name: "Salon" },
                              						    { idx: "2" , name: "Salle à Manger" },
                              						    { idx: "3" , name: "Cuisine" },
                              						    { idx: "8" , name: "Ch.Parents" },
                              						    { idx: "9" , name: "Ch.Adèle" },
                              						    { idx: "10" , name: "Ch.Louis" },
                              						   	{ idx: "4" , name: "Bureau" },
                              						    { idx: "11" , name: "Salle de Bain" },
                              						    { idx: "12" , name: "Salle d'Eau" },
                              						    { idx: "13" , name: "Couloir-Entrée" },
                              						    { idx: "5" , name: "Terrasse" },
                              					    floors: [
                              						     { name: "Rez de Chaussée" ,
                              							    rooms: [ "1" , "2" , "3" , "6" , "7" , "8" , "11" , "13" ]
                              						     { name: "Etage" ,
                              							    rooms: [ "4" , "9" , "10" , "12" ]
                              						     { name: "Extérieurs" ,
                              							    rooms: [ "5" ]
                              					    utilities: {
                              						    utilityLabel: "Electricité Générale Maison" ,
                              						    showLabel: true ,
                              						    devices: [
                              						    { idx: "119" ,
                              						      deviceHeader: "Consommation Electrique" ,
                              						      useHeaderSymbol: false ,
                              						      headerSymbol: "plug" ,
                              						      counterTodayLabel: "Aujourd'hui" ,
                              						      counterTodayAppendText: "Kwh" ,
                              						      gaugeMinValue: -3000 ,
                              						      gaugeMaxValue: 3000 ,
                              						      gaugeAppendText: "Watts" ,
                              						      gaugeWidth: 190 ,
                              						      lineWidth: 20 ,
                              						      markerWidth: 20 ,
                              						      markerColor: "#F4D03F"
                              						    { idx: "121" ,
                              						      deviceHeader: "Consommation Electrique Nette" ,
                              						      gaugeWidth: 190 ,
                              						      lineWidth: 20 ,
                              						      markerWidth: 20 ,
                              						    { idx: "117" ,
                              						      deviceHeader: "Production Solaire" ,
                              						      headerSymbol: "sun" ,
                              						      gaugeMinValue: 0 ,
                              						      gaugeWidth: 190 ,
                              						      lineWidth: 20 ,
                              						      markerWidth: 20 ,
                              						      markerColor: "#70db70"
                              						    { idx: "43" ,
                              						      deviceHeader: "Production Eau Chaude" ,
                              						      headerSymbol: "faucet" ,
                              						      gaugeMinValue: 0 ,
                              						      gaugeMaxValue: 2800 ,
                              						      gaugeWidth: 190 ,
                              						      lineWidth: 20 ,
                              						      markerWidth: 20 ,
                              						      markerColor: "#1E90FF"
                              						    { idx: "46" ,
                              						      deviceHeader: "Pompe à Chaleur" ,
                              						      headerSymbol: "hot-tub" ,
                              						      gaugeMinValue: 0 ,
                              						      gaugeMaxValue: 2000 ,
                              						      gaugeWidth: 190 ,
                              						      lineWidth: 20 ,
                              						      markerWidth: 20 ,
                              						      markerColor: "#f4763f"
                              						    custonGauges: {
                              								    headerLabel: "Autres" ,
                              								    showLabel: true ,
                              								    devices: [
                              									    { idx: "25" ,
                              							  deviceHeader: "Voltage" ,
                              							  useHeaderSymbol: true ,
                              							  headerSymbol: "bolt" ,
                              							  gaugeAppendText: "volts" ,
                              							  gaugeMinValue: 210 ,
                              							  gaugeMaxValue: 260 ,
                              							  gaugeWidth: 150 ,
                              							  lineWidth: 16 ,
                              							  markerWidth: 16 ,
                              							weather: {
                              										devices: [ "140" ],
                              										weatherLabel: "Températures",
                              										gaugewidth: 60,
                              										gaugeAppendText: "°C",
                              									Actions: [
                              											{ label: "Lumiere Exter Cuisine Shelly",
                              											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=On"
                              											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=Off"
                              											{ label: "Lumiere Exter Entree Shelly",
                              											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=On"
                              											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=Off"
                              											{ label: "Prise Commandée 1",
                              											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=69&switchcmd=Toggle"
                              • G Offline
                                goedh452 @Fabaude
                                @fabaude
                                I’m not sure if this is the problem, but there are two typos in the config: custonGauges should be customGauges en Actions should be actions (lower case a).
                                • F Offline
                                  Fabaude @goedh452
                                  @goedh452
                                  moron that I am, a fresh expert’s eyes and the problem is solved.
                                  Big thanks
                                  Fab
                                  • G Offline
                                    goedh452 @Fabaude
                                    @fabaude
                                    Great! Enjoy the module!
                                    F 2 Replies Last reply Reply Quote 0
                                    • F Offline
                                      Fabaude @goedh452
                                      @goedh452
                                      I just have to order all that! ;-)
                                      • F Offline
                                        Fabaude @goedh452
                                        @goedh452
                                        Sorry to come back,
                                        I have 2 buttons for each “action / label” I created, is this normal?
                                        Fab
                                        • G Offline
                                          goedh452 @Fabaude
                                          @fabaude
                                          No, that’s not normal. In the config I see 5 buttons. Am I correct that the module displays 10?
                                          • F Offline
                                            Fabaude @goedh452
                                            @goedh452
                                            yes, when I pass “displayType: actions”, I have all the buttons in duplicate (on 2 lines) but in “all”, I have the list of devices and a line of buttons below … (can be the second line is hidden for lack of space!)
                                            I couldn’t go on tonight.
                                            Sorry.
                                            Fab
                                            • 6 / 7
