    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 115.1k Views 16 Watching
      sdetweil @Shaitan
      @shaitan said in MMM-Domoticz-ext: interact with Domoticz:
      I just added its IP to the whitelist
      I just want to add for this and other folks…
      when integrating multiple systems , 1st thing to do is disable all ip filtering/firewalls
      in MagicMirror this is
      address:"0.0.0.0", // let any outside system connect , "localhost" means ONLY apps INSIDE this same machine can connect
      ipWhitelist:[],   // no restrictions on specific systems connecting.
      once working, then u can add back whatever u might need… ,
      and if it impacts the integration, then u will know as it is the last change…
      • F Offline
        Fabaude
        Hello and thank you for this great module,
        The installation and the settings went well but I can’t see my action buttons on my touch mirror.
        The overview change buttons work well!
        I integrated it into a page of MMM-Caroussel and MMM-GoogleAssistant operates my devices well but I cannot control the lights and others with touch buttons!
        I hope to be clear and in the right place.
        If you have any ideas…
        Fab
        • G Offline
          goedh452 @Fabaude
          @fabaude
          Could you post your config of the module please? And are buttons not displayed at all or aren’t they working when you click them?
          • F Offline
            Fabaude @goedh452
            @goedh452
            I don’t know where the buttons should be? Are these the icons on my dashboard?
            Here is my config and thank you.
            				    module: 'MMM-Domoticz-ext' ,
            				    header: "DOMOTICZ" ,
            				    position: "middle_center" ,
            					    apiBase: "xxx.xxx.x.xx" ,
            					    apiPort: "xxxx" ,
            					    updateInterval: 10 ,
            					    animationSpeed: 0 ,
            					    displayType: "actions" ,
            					    alwaysShowDashboard: false ,
            					    alwaysShowActions: true ,
            					    showButtons: true ,
            					    showTotals: true ,
            					    showIcons: true ,
            					    dashboardRooms: [ "1","2","3","4","5","6","7","8","9","10","11","12","13" ],
            					    buttonAllLabel: "Tous" ,
            					    buttonTypeLabel: "Par Types d'appareils" ,
            					    buttonRoomLabel: "Par Pièces" ,
            				        buttonBothLabel: "Par Types/Pièces" ,
            					    buttonFloorLabel: "Par Types/Niveaux" ,
            					    buttonDashboardLabel: "Tableau de Bord" ,
            					    horizontal: true ,
            					    columnCount: 15 ,
            					    dashboardColumnCount: 15 ,
            					    maxTitleLenght: 25 ,
            					    switchLabel: "Lumières" ,
            					    dimmerLabel: "Interrupteurs" ,
            					    temperatureLabel: "Température Intérieure" ,
            					    humidityLabel: "Humidité" ,
            					    usageLabel: "Electricité Maison" ,
            					    rooms: [
            						    { idx: "7" , name: "Cellier" },
            						    { idx: "6" , name: "Buanderie" },
            						    { idx: "1" , name: "Salon" },
            						    { idx: "2" , name: "Salle à Manger" },
            						    { idx: "3" , name: "Cuisine" },
            						    { idx: "8" , name: "Ch.Parents" },
            						    { idx: "9" , name: "Ch.Adèle" },
            						    { idx: "10" , name: "Ch.Louis" },
            						   	{ idx: "4" , name: "Bureau" },
            						    { idx: "11" , name: "Salle de Bain" },
            						    { idx: "12" , name: "Salle d'Eau" },
            						    { idx: "13" , name: "Couloir-Entrée" },
            						    { idx: "5" , name: "Terrasse" },
            					    floors: [
            						     { name: "Rez de Chaussée" ,
            							    rooms: [ "1" , "2" , "3" , "6" , "7" , "8" , "11" , "13" ]
            						     { name: "Etage" ,
            							    rooms: [ "4" , "9" , "10" , "12" ]
            						     { name: "Extérieurs" ,
            							    rooms: [ "5" ]
            					    utilities: {
            						    utilityLabel: "Electricité Générale Maison" ,
            						    showLabel: true ,
            						    devices: [
            						    { idx: "119" ,
            						      deviceHeader: "Consommation Electrique" ,
            						      useHeaderSymbol: false ,
            						      headerSymbol: "plug" ,
            						      counterTodayLabel: "Aujourd'hui" ,
            						      counterTodayAppendText: "Kwh" ,
            						      gaugeMinValue: -3000 ,
            						      gaugeMaxValue: 3000 ,
            						      gaugeAppendText: "Watts" ,
            						      gaugeWidth: 190 ,
            						      lineWidth: 20 ,
            						      markerWidth: 20 ,
            						      markerColor: "#F4D03F"
            						    { idx: "121" ,
            						      deviceHeader: "Consommation Electrique Nette" ,
            						      gaugeWidth: 190 ,
            						      lineWidth: 20 ,
            						      markerWidth: 20 ,
            						    { idx: "117" ,
            						      deviceHeader: "Production Solaire" ,
            						      headerSymbol: "sun" ,
            						      gaugeMinValue: 0 ,
            						      gaugeWidth: 190 ,
            						      lineWidth: 20 ,
            						      markerWidth: 20 ,
            						      markerColor: "#70db70"
            						    { idx: "43" ,
            						      deviceHeader: "Production Eau Chaude" ,
            						      headerSymbol: "faucet" ,
            						      gaugeMinValue: 0 ,
            						      gaugeMaxValue: 2800 ,
            						      gaugeWidth: 190 ,
            						      lineWidth: 20 ,
            						      markerWidth: 20 ,
            						      markerColor: "#1E90FF"
            						    { idx: "46" ,
            						      deviceHeader: "Pompe à Chaleur" ,
            						      headerSymbol: "hot-tub" ,
            						      gaugeMinValue: 0 ,
            						      gaugeMaxValue: 2000 ,
            						      gaugeWidth: 190 ,
            						      lineWidth: 20 ,
            						      markerWidth: 20 ,
            						      markerColor: "#f4763f"
            						    custonGauges: {
            								    headerLabel: "Autres" ,
            								    showLabel: true ,
            								    devices: [
            									    { idx: "25" ,
            							  deviceHeader: "Voltage" ,
            							  useHeaderSymbol: true ,
            							  headerSymbol: "bolt" ,
            							  gaugeAppendText: "volts" ,
            							  gaugeMinValue: 210 ,
            							  gaugeMaxValue: 260 ,
            							  gaugeWidth: 150 ,
            							  lineWidth: 16 ,
            							  markerWidth: 16 ,
            							weather: {
            										devices: [ "140" ],
            										weatherLabel: "Températures",
            										gaugewidth: 60,
            										gaugeAppendText: "°C",
            									Actions: [
            											{ label: "Lumiere Exter Cuisine Shelly",
            											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=On"
            											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=Off"
            											{ label: "Lumiere Exter Entree Shelly",
            											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=On"
            											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=Off"
            											{ label: "Prise Commandée 1",
            											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=69&switchcmd=Toggle"
            • G Offline
              goedh452 @Fabaude
              @fabaude
              I’m not sure if this is the problem, but there are two typos in the config: custonGauges should be customGauges en Actions should be actions (lower case a).
              • F Offline
                Fabaude @goedh452
                @goedh452
                moron that I am, a fresh expert’s eyes and the problem is solved.
                Big thanks
                Fab
                • G Offline
                  goedh452 @Fabaude
                  @fabaude
                  Great! Enjoy the module!
                  F 2 Replies Last reply Reply Quote 0
                  • F Offline
                    Fabaude @goedh452
                    @goedh452
                    I just have to order all that! ;-)
                    • F Offline
                      Fabaude @goedh452
                      @goedh452
                      Sorry to come back,
                      I have 2 buttons for each “action / label” I created, is this normal?
                      Fab
                      • G Offline
                        goedh452 @Fabaude
                        @fabaude
                        No, that’s not normal. In the config I see 5 buttons. Am I correct that the module displays 10?
                        • F Offline
                          Fabaude @goedh452
                          @goedh452
                          yes, when I pass “displayType: actions”, I have all the buttons in duplicate (on 2 lines) but in “all”, I have the list of devices and a line of buttons below … (can be the second line is hidden for lack of space!)
                          I couldn’t go on tonight.
                          Sorry.
                          Fab
                          • G Offline
                            goedh452 @Fabaude
                            @fabaude
                            I think this is a bug. At the moment I do not have a pi running the mirror and module, so debugging is a bit difficult. If I find some time, I’ll see if I can install it and debug. If you only want to display the actions, there should be other modules that do this.
                              Shaitan @Shaitan
                              @sdetweil Hi, I will try this after my travel, i’m not at home… Thank you !
                                Bliepie
                                Does anyone know if it is possible to show the values of a smart meter without using a Gauge?
                                I would like to show the values in a different layout, for example a room layout, I can’t manage to do this now without using a Gauge.
                                I hope someone can help me!
                                Regards, Bliepie
                                  ArturB @Bliepie
                                  Does anyone know if it is possible to show different gauge colors depending on the value, for example:
                                  • temperature in the range of -10 to 10 degrees in blue
                                  • temperature in the range of 11 to 20 degrees in green
                                  • temperature in the range of 21 to 30 degrees in yellow
                                    -temperature in the range of 31 to 40 degrees in red
                                  Of course, it would be nice to use such color meters for other measurements.
                                  Hope someone can help me!
                                  I greet Arthur
                                  • G Offline
                                    goedh452 @ArturB
                                    @ArturB I’m the developer of the module. This is not possible at the moment. Since I don’t own a magic mirror anymore I kind of stopped the development of this module. Feel free to clone it and make your own modifications to the code.
                                    • 6 / 7
