    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 120.7k Views 16 Watching
      Shaitan @goedh452
      @goedh452 I don’t know how to remove the authentication on domoticz, I just added its IP to the whitelist and I got this:Nouvelle ie bitmap.png
      G S 2 Replies Last reply Reply Quote 0
      • G
        goedh452 @Shaitan
        @shaitan
        Just remove the username en password and save the settings.Schermafbeelding 2021-12-06 om 13.47.23.png
          Shaitan @goedh452
          @goedh452 Same screen
            sdetweil @Shaitan
            @shaitan said in MMM-Domoticz-ext: interact with Domoticz:
            I just want to add for this and other folks…
            when integrating multiple systems , 1st thing to do is disable all ip filtering/firewalls
            in MagicMirror this is
            address:"0.0.0.0", // let any outside system connect , "localhost" means ONLY apps INSIDE this same machine can connect
            ipWhitelist:[],   // no restrictions on specific systems connecting.
            once working, then u can add back whatever u might need… ,
            and if it impacts the integration, then u will know as it is the last change…
            • F
              Fabaude
              Hello and thank you for this great module,
              The installation and the settings went well but I can’t see my action buttons on my touch mirror.
              The overview change buttons work well!
              I integrated it into a page of MMM-Caroussel and MMM-GoogleAssistant operates my devices well but I cannot control the lights and others with touch buttons!
              I hope to be clear and in the right place.
              If you have any ideas…
              Fab
              • G
                goedh452 @Fabaude
                @fabaude
                Could you post your config of the module please? And are buttons not displayed at all or aren’t they working when you click them?
                • F
                  Fabaude @goedh452
                  @goedh452
                  I don’t know where the buttons should be? Are these the icons on my dashboard?
                  Here is my config and thank you.
                  				    module: 'MMM-Domoticz-ext' ,
                  				    header: "DOMOTICZ" ,
                  				    position: "middle_center" ,
                  					    apiBase: "xxx.xxx.x.xx" ,
                  					    apiPort: "xxxx" ,
                  					    updateInterval: 10 ,
                  					    animationSpeed: 0 ,
                  					    displayType: "actions" ,
                  					    alwaysShowDashboard: false ,
                  					    alwaysShowActions: true ,
                  					    showButtons: true ,
                  					    showTotals: true ,
                  					    showIcons: true ,
                  					    dashboardRooms: [ "1","2","3","4","5","6","7","8","9","10","11","12","13" ],
                  					    buttonAllLabel: "Tous" ,
                  					    buttonTypeLabel: "Par Types d'appareils" ,
                  					    buttonRoomLabel: "Par Pièces" ,
                  				        buttonBothLabel: "Par Types/Pièces" ,
                  					    buttonFloorLabel: "Par Types/Niveaux" ,
                  					    buttonDashboardLabel: "Tableau de Bord" ,
                  					    horizontal: true ,
                  					    columnCount: 15 ,
                  					    dashboardColumnCount: 15 ,
                  					    maxTitleLenght: 25 ,
                  					    switchLabel: "Lumières" ,
                  					    dimmerLabel: "Interrupteurs" ,
                  					    temperatureLabel: "Température Intérieure" ,
                  					    humidityLabel: "Humidité" ,
                  					    usageLabel: "Electricité Maison" ,
                  					    rooms: [
                  						    { idx: "7" , name: "Cellier" },
                  						    { idx: "6" , name: "Buanderie" },
                  						    { idx: "1" , name: "Salon" },
                  						    { idx: "2" , name: "Salle à Manger" },
                  						    { idx: "3" , name: "Cuisine" },
                  						    { idx: "8" , name: "Ch.Parents" },
                  						    { idx: "9" , name: "Ch.Adèle" },
                  						    { idx: "10" , name: "Ch.Louis" },
                  						   	{ idx: "4" , name: "Bureau" },
                  						    { idx: "11" , name: "Salle de Bain" },
                  						    { idx: "12" , name: "Salle d'Eau" },
                  						    { idx: "13" , name: "Couloir-Entrée" },
                  						    { idx: "5" , name: "Terrasse" },
                  					    floors: [
                  						     { name: "Rez de Chaussée" ,
                  							    rooms: [ "1" , "2" , "3" , "6" , "7" , "8" , "11" , "13" ]
                  						     { name: "Etage" ,
                  							    rooms: [ "4" , "9" , "10" , "12" ]
                  						     { name: "Extérieurs" ,
                  							    rooms: [ "5" ]
                  					    utilities: {
                  						    utilityLabel: "Electricité Générale Maison" ,
                  						    showLabel: true ,
                  						    devices: [
                  						    { idx: "119" ,
                  						      deviceHeader: "Consommation Electrique" ,
                  						      useHeaderSymbol: false ,
                  						      headerSymbol: "plug" ,
                  						      counterTodayLabel: "Aujourd'hui" ,
                  						      counterTodayAppendText: "Kwh" ,
                  						      gaugeMinValue: -3000 ,
                  						      gaugeMaxValue: 3000 ,
                  						      gaugeAppendText: "Watts" ,
                  						      gaugeWidth: 190 ,
                  						      lineWidth: 20 ,
                  						      markerWidth: 20 ,
                  						      markerColor: "#F4D03F"
                  						    { idx: "121" ,
                  						      deviceHeader: "Consommation Electrique Nette" ,
                  						      gaugeWidth: 190 ,
                  						      lineWidth: 20 ,
                  						      markerWidth: 20 ,
                  						    { idx: "117" ,
                  						      deviceHeader: "Production Solaire" ,
                  						      headerSymbol: "sun" ,
                  						      gaugeMinValue: 0 ,
                  						      gaugeWidth: 190 ,
                  						      lineWidth: 20 ,
                  						      markerWidth: 20 ,
                  						      markerColor: "#70db70"
                  						    { idx: "43" ,
                  						      deviceHeader: "Production Eau Chaude" ,
                  						      headerSymbol: "faucet" ,
                  						      gaugeMinValue: 0 ,
                  						      gaugeMaxValue: 2800 ,
                  						      gaugeWidth: 190 ,
                  						      lineWidth: 20 ,
                  						      markerWidth: 20 ,
                  						      markerColor: "#1E90FF"
                  						    { idx: "46" ,
                  						      deviceHeader: "Pompe à Chaleur" ,
                  						      headerSymbol: "hot-tub" ,
                  						      gaugeMinValue: 0 ,
                  						      gaugeMaxValue: 2000 ,
                  						      gaugeWidth: 190 ,
                  						      lineWidth: 20 ,
                  						      markerWidth: 20 ,
                  						      markerColor: "#f4763f"
                  						    custonGauges: {
                  								    headerLabel: "Autres" ,
                  								    showLabel: true ,
                  								    devices: [
                  									    { idx: "25" ,
                  							  deviceHeader: "Voltage" ,
                  							  useHeaderSymbol: true ,
                  							  headerSymbol: "bolt" ,
                  							  gaugeAppendText: "volts" ,
                  							  gaugeMinValue: 210 ,
                  							  gaugeMaxValue: 260 ,
                  							  gaugeWidth: 150 ,
                  							  lineWidth: 16 ,
                  							  markerWidth: 16 ,
                  							weather: {
                  										devices: [ "140" ],
                  										weatherLabel: "Températures",
                  										gaugewidth: 60,
                  										gaugeAppendText: "°C",
                  									Actions: [
                  											{ label: "Lumiere Exter Cuisine Shelly",
                  											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=On"
                  											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=Off"
                  											{ label: "Lumiere Exter Entree Shelly",
                  											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=On"
                  											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=Off"
                  											{ label: "Prise Commandée 1",
                  											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=69&switchcmd=Toggle"
                  • G
                    goedh452 @Fabaude
                    @fabaude
                    I’m not sure if this is the problem, but there are two typos in the config: custonGauges should be customGauges en Actions should be actions (lower case a).
                    • F
                      Fabaude @goedh452
                      @goedh452
                      moron that I am, a fresh expert’s eyes and the problem is solved.
                      Big thanks
                      Fab
                      • G
                        goedh452 @Fabaude
                        @fabaude
                        Great! Enjoy the module!
                        F 2 Replies Last reply Reply Quote 0
                        • F
                          Fabaude @goedh452
                          @goedh452
                          I just have to order all that! ;-)
                          • F
                            Fabaude @goedh452
                            @goedh452
                            Sorry to come back,
                            I have 2 buttons for each “action / label” I created, is this normal?
                            Fab
                            • G
                              goedh452 @Fabaude
                              @fabaude
                              No, that’s not normal. In the config I see 5 buttons. Am I correct that the module displays 10?
                              • F
                                Fabaude @goedh452
                                @goedh452
                                yes, when I pass “displayType: actions”, I have all the buttons in duplicate (on 2 lines) but in “all”, I have the list of devices and a line of buttons below … (can be the second line is hidden for lack of space!)
                                I couldn’t go on tonight.
                                Sorry.
                                Fab
                                • G
                                  goedh452 @Fabaude
                                  @fabaude
                                  I think this is a bug. At the moment I do not have a pi running the mirror and module, so debugging is a bit difficult. If I find some time, I’ll see if I can install it and debug. If you only want to display the actions, there should be other modules that do this.
                                    Shaitan @Shaitan
                                    @sdetweil Hi, I will try this after my travel, i’m not at home… Thank you !
                                      Bliepie
                                      Does anyone know if it is possible to show the values of a smart meter without using a Gauge?
                                      I would like to show the values in a different layout, for example a room layout, I can’t manage to do this now without using a Gauge.
                                      I hope someone can help me!
                                      Regards, Bliepie
                                      • A
                                        ArturB @Bliepie
                                        Does anyone know if it is possible to show different gauge colors depending on the value, for example:
                                        • temperature in the range of -10 to 10 degrees in blue
                                        • temperature in the range of 11 to 20 degrees in green
                                        • temperature in the range of 21 to 30 degrees in yellow
                                          -temperature in the range of 31 to 40 degrees in red
                                        Of course, it would be nice to use such color meters for other measurements.
                                        Hope someone can help me!
                                        I greet Arthur
                                        • G
                                          goedh452 @ArturB
                                          @ArturB I’m the developer of the module. This is not possible at the moment. Since I don’t own a magic mirror anymore I kind of stopped the development of this module. Feel free to clone it and make your own modifications to the code.
                                          • 6 / 7
