    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 120.7k Views 16 Watching
    • G
      goedh452 @Shaitan
      @shaitan
      The errors indicate that Domiticz cannot be reached. Would it be possible to temporarily disable the authentication in Domoticz and test it again?
        Shaitan @goedh452
        @goedh452 I don’t know how to remove the authentication on domoticz, I just added its IP to the whitelist and I got this:Nouvelle ie bitmap.png
        G S 2 Replies Last reply Reply Quote 0
        • G
          goedh452 @Shaitan
          @shaitan
          Just remove the username en password and save the settings.Schermafbeelding 2021-12-06 om 13.47.23.png
            Shaitan @goedh452
            @goedh452 Same screen
              sdetweil @Shaitan
              @shaitan said in MMM-Domoticz-ext: interact with Domoticz:
              I just want to add for this and other folks…
              when integrating multiple systems , 1st thing to do is disable all ip filtering/firewalls
              in MagicMirror this is
              address:"0.0.0.0", // let any outside system connect , "localhost" means ONLY apps INSIDE this same machine can connect
              ipWhitelist:[],   // no restrictions on specific systems connecting.
              once working, then u can add back whatever u might need… ,
              and if it impacts the integration, then u will know as it is the last change…
              • F
                Fabaude
                Hello and thank you for this great module,
                The installation and the settings went well but I can’t see my action buttons on my touch mirror.
                The overview change buttons work well!
                I integrated it into a page of MMM-Caroussel and MMM-GoogleAssistant operates my devices well but I cannot control the lights and others with touch buttons!
                I hope to be clear and in the right place.
                If you have any ideas…
                Fab
                • G
                  goedh452 @Fabaude
                  @fabaude
                  Could you post your config of the module please? And are buttons not displayed at all or aren’t they working when you click them?
                  • F
                    Fabaude @goedh452
                    @goedh452
                    I don’t know where the buttons should be? Are these the icons on my dashboard?
                    Here is my config and thank you.
                    				    module: 'MMM-Domoticz-ext' ,
                    				    header: "DOMOTICZ" ,
                    				    position: "middle_center" ,
                    					    apiBase: "xxx.xxx.x.xx" ,
                    					    apiPort: "xxxx" ,
                    					    updateInterval: 10 ,
                    					    animationSpeed: 0 ,
                    					    displayType: "actions" ,
                    					    alwaysShowDashboard: false ,
                    					    alwaysShowActions: true ,
                    					    showButtons: true ,
                    					    showTotals: true ,
                    					    showIcons: true ,
                    					    dashboardRooms: [ "1","2","3","4","5","6","7","8","9","10","11","12","13" ],
                    					    buttonAllLabel: "Tous" ,
                    					    buttonTypeLabel: "Par Types d'appareils" ,
                    					    buttonRoomLabel: "Par Pièces" ,
                    				        buttonBothLabel: "Par Types/Pièces" ,
                    					    buttonFloorLabel: "Par Types/Niveaux" ,
                    					    buttonDashboardLabel: "Tableau de Bord" ,
                    					    horizontal: true ,
                    					    columnCount: 15 ,
                    					    dashboardColumnCount: 15 ,
                    					    maxTitleLenght: 25 ,
                    					    switchLabel: "Lumières" ,
                    					    dimmerLabel: "Interrupteurs" ,
                    					    temperatureLabel: "Température Intérieure" ,
                    					    humidityLabel: "Humidité" ,
                    					    usageLabel: "Electricité Maison" ,
                    					    rooms: [
                    						    { idx: "7" , name: "Cellier" },
                    						    { idx: "6" , name: "Buanderie" },
                    						    { idx: "1" , name: "Salon" },
                    						    { idx: "2" , name: "Salle à Manger" },
                    						    { idx: "3" , name: "Cuisine" },
                    						    { idx: "8" , name: "Ch.Parents" },
                    						    { idx: "9" , name: "Ch.Adèle" },
                    						    { idx: "10" , name: "Ch.Louis" },
                    						   	{ idx: "4" , name: "Bureau" },
                    						    { idx: "11" , name: "Salle de Bain" },
                    						    { idx: "12" , name: "Salle d'Eau" },
                    						    { idx: "13" , name: "Couloir-Entrée" },
                    						    { idx: "5" , name: "Terrasse" },
                    					    floors: [
                    						     { name: "Rez de Chaussée" ,
                    							    rooms: [ "1" , "2" , "3" , "6" , "7" , "8" , "11" , "13" ]
                    						     { name: "Etage" ,
                    							    rooms: [ "4" , "9" , "10" , "12" ]
                    						     { name: "Extérieurs" ,
                    							    rooms: [ "5" ]
                    					    utilities: {
                    						    utilityLabel: "Electricité Générale Maison" ,
                    						    showLabel: true ,
                    						    devices: [
                    						    { idx: "119" ,
                    						      deviceHeader: "Consommation Electrique" ,
                    						      useHeaderSymbol: false ,
                    						      headerSymbol: "plug" ,
                    						      counterTodayLabel: "Aujourd'hui" ,
                    						      counterTodayAppendText: "Kwh" ,
                    						      gaugeMinValue: -3000 ,
                    						      gaugeMaxValue: 3000 ,
                    						      gaugeAppendText: "Watts" ,
                    						      gaugeWidth: 190 ,
                    						      lineWidth: 20 ,
                    						      markerWidth: 20 ,
                    						      markerColor: "#F4D03F"
                    						    { idx: "121" ,
                    						      deviceHeader: "Consommation Electrique Nette" ,
                    						      gaugeWidth: 190 ,
                    						      lineWidth: 20 ,
                    						      markerWidth: 20 ,
                    						    { idx: "117" ,
                    						      deviceHeader: "Production Solaire" ,
                    						      headerSymbol: "sun" ,
                    						      gaugeMinValue: 0 ,
                    						      gaugeWidth: 190 ,
                    						      lineWidth: 20 ,
                    						      markerWidth: 20 ,
                    						      markerColor: "#70db70"
                    						    { idx: "43" ,
                    						      deviceHeader: "Production Eau Chaude" ,
                    						      headerSymbol: "faucet" ,
                    						      gaugeMinValue: 0 ,
                    						      gaugeMaxValue: 2800 ,
                    						      gaugeWidth: 190 ,
                    						      lineWidth: 20 ,
                    						      markerWidth: 20 ,
                    						      markerColor: "#1E90FF"
                    						    { idx: "46" ,
                    						      deviceHeader: "Pompe à Chaleur" ,
                    						      headerSymbol: "hot-tub" ,
                    						      gaugeMinValue: 0 ,
                    						      gaugeMaxValue: 2000 ,
                    						      gaugeWidth: 190 ,
                    						      lineWidth: 20 ,
                    						      markerWidth: 20 ,
                    						      markerColor: "#f4763f"
                    						    custonGauges: {
                    								    headerLabel: "Autres" ,
                    								    showLabel: true ,
                    								    devices: [
                    									    { idx: "25" ,
                    							  deviceHeader: "Voltage" ,
                    							  useHeaderSymbol: true ,
                    							  headerSymbol: "bolt" ,
                    							  gaugeAppendText: "volts" ,
                    							  gaugeMinValue: 210 ,
                    							  gaugeMaxValue: 260 ,
                    							  gaugeWidth: 150 ,
                    							  lineWidth: 16 ,
                    							  markerWidth: 16 ,
                    							weather: {
                    										devices: [ "140" ],
                    										weatherLabel: "Températures",
                    										gaugewidth: 60,
                    										gaugeAppendText: "°C",
                    									Actions: [
                    											{ label: "Lumiere Exter Cuisine Shelly",
                    											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=On"
                    											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=Off"
                    											{ label: "Lumiere Exter Entree Shelly",
                    											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=On"
                    											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=Off"
                    											{ label: "Prise Commandée 1",
                    											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=69&switchcmd=Toggle"
                    • G
                      goedh452 @Fabaude
                      @fabaude
                      I’m not sure if this is the problem, but there are two typos in the config: custonGauges should be customGauges en Actions should be actions (lower case a).
                      • F
                        Fabaude @goedh452
                        @goedh452
                        moron that I am, a fresh expert’s eyes and the problem is solved.
                        Big thanks
                        Fab
                        • G
                          goedh452 @Fabaude
                          @fabaude
                          Great! Enjoy the module!
                          F 2 Replies Last reply Reply Quote 0
                          • F
                            Fabaude @goedh452
                            @goedh452
                            I just have to order all that! ;-)
                            • F
                              Fabaude @goedh452
                              @goedh452
                              Sorry to come back,
                              I have 2 buttons for each “action / label” I created, is this normal?
                              Fab
                              • G
                                goedh452 @Fabaude
                                @fabaude
                                No, that’s not normal. In the config I see 5 buttons. Am I correct that the module displays 10?
                                • F
                                  Fabaude @goedh452
                                  @goedh452
                                  yes, when I pass “displayType: actions”, I have all the buttons in duplicate (on 2 lines) but in “all”, I have the list of devices and a line of buttons below … (can be the second line is hidden for lack of space!)
                                  I couldn’t go on tonight.
                                  Sorry.
                                  Fab
                                  • G
                                    goedh452 @Fabaude
                                    @fabaude
                                    I think this is a bug. At the moment I do not have a pi running the mirror and module, so debugging is a bit difficult. If I find some time, I’ll see if I can install it and debug. If you only want to display the actions, there should be other modules that do this.
                                      Shaitan @Shaitan
                                      @sdetweil Hi, I will try this after my travel, i’m not at home… Thank you !
                                        Bliepie
                                        Does anyone know if it is possible to show the values of a smart meter without using a Gauge?
                                        I would like to show the values in a different layout, for example a room layout, I can’t manage to do this now without using a Gauge.
                                        I hope someone can help me!
                                        Regards, Bliepie
                                        • A
                                          ArturB @Bliepie
                                          Does anyone know if it is possible to show different gauge colors depending on the value, for example:
                                          • temperature in the range of -10 to 10 degrees in blue
                                          • temperature in the range of 11 to 20 degrees in green
                                          • temperature in the range of 21 to 30 degrees in yellow
                                            -temperature in the range of 31 to 40 degrees in red
                                          Of course, it would be nice to use such color meters for other measurements.
                                          Hope someone can help me!
                                          I greet Arthur
                                          • G
                                            goedh452 @ArturB
                                            @ArturB I’m the developer of the module. This is not possible at the moment. Since I don’t own a magic mirror anymore I kind of stopped the development of this module. Feel free to clone it and make your own modifications to the code.
                                            • 6 / 7
