    7" and 5" displays
    16 Posts 10 Posters 9.9k Views 12 Watching
    • H Offline
      harney
      I’ve been working on these for a few weeks now. The 7 inch screen is for my Pi server, and the 5inch screen is my bedside clock.
      Both screens have brightness controls, and module hiding. The seven inch screen has both a manual screen button for reducing the brightness from 180 to 20, which can override the auto dulling and brightening.
      Seven Inch (screen grabs - Full and Night mode)
      Seven inch Bright mode
      Seven inch in night dull mode( Not as bright as the image in real life. At night, its just bright enough to see the time but not bright enough to light the room. Dimming is the same on both screens)
      And in dull mode
      Five inch
      Screen grab of full five inch screen
      And night mode
      Modules used (and modified)
      Clock
      MMM-ScreenDimmer
      MMM-OpenWeather
      weatherforecast (with modified ico sizes for the 5" screen)
      MMM-network-signal
      MMM-ip
      MMM-ModuleToggle
      MMM-TouchButton
      MMM-ping
      internet-monitor
      MMM-SystemStats
      G Robin GarnerR 2 Replies Last reply Reply Quote 3
        Saabman Project Sponsor
        That looks neat,
        how do you find the brightness in the bedroom of a night. I made a clock out of and Iphone but found the backlight was way too bright.
        do you have absolute control over your back light?
        • H Offline
          harney @Saabman
          @saabman I did some testing and found a brightness that didnt light up the room but still enabled the display to be seem
          The Sun and Moon icons on the left have commands attached to them
          | command: “echo 20 | sudo tee /sys/class/backlight/rpi_backlight/brightness”, |
          I just changed the “echo xxx” number to a value that works for me. I’m using Raspberry screens.
            Saabman Project Sponsor @harney
            @harney Thats good Your on a winner :)
            I shelved my Iphone project till I can get my hands on some dark window tint to bring it under control -
            • C Offline
              carltonb
              @harney These look great. I have built something similar on larger screens.
              Can you please let me know what models of the 5 and 7" screens you are using.
              carltonb
              • G Offline
                Gr1dL0ck @harney
                @harney
                how did you get the sun/moon to come up and in color like that ?
                could you post some of the code to that
                • H Offline
                  harney @carltonb
                  @carltonb the 7inch screen is the raspberry pi unit https://www.raspberrypi.org/products/raspberry-pi-touch-display/
                  and the 5 inch is from DFRobot, https://www.dfrobot.com/product-1784.html
                  i chose both these as they use a flat ribbon cable to hook up instead of HDMI or the GPIO pins
                  • H Offline
                    harney @Gr1dL0ck
                    @gr1dl0ck that is the 5inch screen using MMM-weatherforecast https://github.com/jharttech/MMM-weatherforecast/blob/master/README.md
                    which comes with deviant art icons. I reduced the size of the icins to fit the area i had, and saved them in the CSS file as instructed but used different names. then change the MMM-weatherforcast.css file to point to the icos i wanted shown rather than the default selection. Theres quite a few icons to select from in the icon folder of the git file. I just chose the ones i liked the best based on the fortecast
                    • O Offline
                      osfersa
                      How did you get to use the whole 7’ screen, when I build mine, it cropped the top and bottom?
                        sdetweil
                        mm does not know it’s a touch screen the browser draws on the screen and it so happens that it supports touch events , like mouse events. click here , click there.
                        the thing under the click point reacts to the event or not, depending on what browser element it is.
                        if the screen doesn’t support touch, then there is not click event, but the html widget is the same
                        O 1 Reply Last reply Reply Quote 1
                        • H Offline
                          harney @osfersa
                          @osfersa In the Main.Css file
                          body {
                          margin: 10px;
                          position: absolute;
                          height: calc(100% - 20px); ##Change this to 100% - xx
                          width: calc(100% - 20px);
                          • Robin GarnerR Offline
                            Robin Garner @harney
                            @harney how long did it take you to make this? and does it have any bugs? I’m just curious to how does it work!!
                            • O Offline
                              osfersa @sdetweil
                              @sdetweil Works now Thank you.
                              • H Offline
                                harney @Robin Garner
                                @robin-garner It took longer to print the cases than it did to do the software. Its all relatively straightforward modules. Just follow the instructions and you wont have any problems.
                                Although, for some reason Speedtest module no longer works since Ookla made some changes to their software. This would be the only bug I have fown and that was only recently (since August I think)
                                • freddiewoodsF Offline
                                  freddiewoods
                                  very good efforts
                                  • K Offline
                                    kimcat
