    Problems restarting MagicMirror (Port 8080 in use ...)
    20 Posts 7 Posters 15.3k Views 7 Watching
    • MichMichM
      MichMich
      I’ve recently reinstalled my Pi and installed the latest built of the develop branch.
      I have a small update script which eventually restarts MagicMirror using pm2 restart mm.
      Unfortunately, it won’t restart because it says port 8080 is already in use.
      The only solution is rebooting the Pi.
      Before I spend some time on solving this, I’m curious: does restarting work on your pi? And are you running the latest develop branch as well?
      • SnilleS
        Snille Module Developer
        Hi! Yes, restarting works. This usually happens when a module has failed to work (have some error in it). Even though you fix the problem, as long as you have not restarted it seems the port still is “in use”.
        By the way, thank you for this GREAT project! :)
        Best regards Snille
        If you cant find it, make it and share it
        MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
        • cowboysdudeC
          cowboysdude Module Developer
          Here I was thinking it was just me LOL No biggie restarting seems to solve it.
          So until it gets figured out we’ll live with it :)
          MichMichM 1 Reply Last reply Reply Quote 0
          • MichMichM
            MichMich @cowboysdude
            @cowboysdude Ah, so you’re experiencing the same? In that case it’s worth diving into …
            P 1 Reply Last reply Reply Quote 2
            • P
              PindaPower @MichMich
              @MichMich I’m not running the develop branch, but I do know the background off the feedback (port 8080 is use). I’m not sure if your looking for this information, other ways let me know.
              • B
                binderth
                Same for me, if you mean this Messages (I’m using the main 2.1):
                pi@MagicMirror:~/MagicMirror $ DISPLAY=:0 npm restart &
                [1] 29215
                > magicmirror@2.1.0 start /home/pi/MagicMirror
                > electron js/electron.js
                Starting MagicMirror: v2.1.0
                Loading config ...
                Loading module helpers ...
                No helper found for module: MMM-Globe.
                No helper found for module: MMM-Callmonitor-Current-Call.
                All module helpers loaded.
                Starting server op port 8080 ...
                Server started ...
                Connecting socket for: MMM-PIR-Sensor
                Staring module helper: MMM-PIR-Sensor
                Connecting socket for: MMM-Wunderlist
                Connecting socket for: MMM-FRITZ-Box-Callmonitor
                Starting module: MMM-FRITZ-Box-Callmonitor
                Connecting socket for: MMM-DWD-WarnWeather
                MMM-DWD-WarnWeather helper started...
                Connecting socket for: MMM-NetworkScanner
                Starting module: MMM-NetworkScanner
                Starting module: newsfeed
                { Error: listen EADDRINUSE :::8080
                    at Object.exports._errnoException (util.js:1026:11)
                    at exports._exceptionWithHostPort (util.js:1049:20)
                    at Server._listen2 (net.js:1253:14)
                    at listen (net.js:1289:10)
                    at net.js:1399:9
                    at _combinedTickCallback (internal/process/next_tick.js:77:11)
                    at process._tickCallback (internal/process/next_tick.js:98:9)
                    at Module.runMain (module.js:592:11)
                    at run (bootstrap_node.js:402:7)
                    at startup (bootstrap_node.js:157:9)
                  code: 'EADDRINUSE',
                  errno: 'EADDRINUSE',
                  syscall: 'listen',
                  address: '::',
                  port: 8080 }
                Launching application.
                • R
                  roramirez Core Contributors
                  Ups, there a bug for pm2 config. I pushed a fix
                  https://github.com/MichMich/MagicMirror/pull/640
                  The restart is work for me. Are you try stop/start?
                  pi@raspberrypi:~/MagicMirror $ pm2 status MagicMirror
                  │ App name    │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
                  │ MagicMirror │ 0  │ fork │ 7689 │ online │ 1       │ 3h     │ 0%  │ 2.4 MB   │  enabled │
                   Use `pm2 show ` to get more details about an app
                  pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
                  Restarts are now immutable, to update environment or conf use --update-env
                  [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                  [PM2] [MagicMirror](0) ✓
                  │ MagicMirror │ 0  │ fork │ 6447 │ online │ 2       │ 0s     │ 7%  │ 2.3 MB   │  enabled │
                  By the way, there a interesting notice in restart process by pm2
                  Here I’m using 2.1.5 version
                  pi@raspberrypi:~/MagicMirror $ pm2 -version
                  2.1.5
                  Easy module development with MagicMirror Module Template
                  B O 2 Replies Last reply Reply Quote 0
                  • B
                    binderth @roramirez
                    @roramirez said in Problems restarting MagicMirror (Port 8080 in use ...):
                    2.1.5
                    Do I need pm2?
                    pi@MagicMirror:~ $ pm2 -version
                    -bash: pm2: Kommando nicht gefunden.
                    (translates: command not found)
                    • O
                      ostfilinchen @roramirez
                      @roramirez what i have to do to get the fix from github? I have installed MM v2.1.0
                      • MichMichM
                        MichMich
                        This seem to have fixed the issue. Thanks @roramirez!
                        • R
                          roramirez Core Contributors @binderth
                          @binderth said in Problems restarting MagicMirror (Port 8080 in use ...):
                          Do I need pm2?
                          Is optional. If you installed by script and choice. After that you can configurate mannually.
                          • R
                            roramirez Core Contributors @ostfilinchen
                            @ostfilinchen That version don’t have the feature for use pm2 for process control by installer script. What is your problem in 2.1.0?
                            • O
                              @roramirez my Problem is this error
                              8080 at Object.exports._errnoException (util.js:1026:11) at exports._exceptionWithHostPort (util.js:1049:20) at Server._listen2 (net.js:1253:14) at listen (net.js:1289:10) at net.js:1399:9 at _combinedTickCallback (internal/process/next_tick.js:77:11) at process._tickCallback (internal/process/next_tick.js:98:9) at Module.runMain (module.js:592:11) at run (bootstrap_node.js:402:7) at startup (bootstrap_node.js:157:9) code: 'EADDRINUSE', errno: 'EADDRINUSE', syscall: 'listen', address: '::', port: 8080 }
                              when i restart the mirror via pm2
                              • cowboysdudeC
                                Thanks guys!
                                • R
                                  @ostfilinchen What pm2 version are using?. There are other process to start control of MagicMirror?
                                  Please, send some log lines of pm2 and what show you
                                  pm2 status
                                  • O
                                    @roramirez i think the Problem is the pm2. My in Memory Version is 2.0.19 and my local Version is 2.3.0.
                                    if i do pm2 update it updates the Version, but if i restart the pi, i have 2 Versions again.
                                    • R
                                      @ostfilinchen So stranger. What is for you memory version?
                                      Note: The last stable release of pm2 is 2.2.1.
                                      I recomend use the last version stable. In my case, the 2.1.5, work fine the restart action.
                                      • O
                                        @roramirez thanks for the Information. how can i update to 2.1.5?
                                        • R
                                          @ostfilinchen by npm
                                          sudo npm install -g pm2@2.1.5
                                          First remove previous version installed
                                          https://docs.npmjs.com/cli/uninstall
                                          • O
                                            @roramirez i’ve done this and have a look on the restartprocess in the next time. thanks a lot.
