    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • M
      MarcLandis Module Developer @sdetweil
      @sdetweil the command now works. Now I need to figure out why the socket.io connection isn’t working.
      Failed to load resource: net::ERR_CONNECTION_REFUSED
      M 1 Reply Last reply
      • M
        MarcLandis Module Developer @MarcLandis
        @MarcLandis said in Are you tired of editing config.js, or have trouble doing it, see my new module:
        Wrong URL :)
        All is working now. Thanks for the help.
          sdetweil @MarcLandis
          @MarcLandis what url were you trying? that didn’t work?
          • M
            @sdetweil /modules/MMM-Config/config.html without the port parameter that gets added when using /modules/MMM-Config/review
              @MarcLandis got it… thx
                SteakExpert
                Any chance this is still being worked on? Read through this entire thread in hopes I’d be able to solve my problem without bugging (see what I did there?) you, but alas, I did not.
                Simply returning the “builder encountered a problem, see MagicMirror messages for info” when I navigate via the QR code.
                Would appreciate any help you might be able to supply.
                Thank you!
                S 2 Replies Last reply
                  sdetweil @SteakExpert
                  @SteakExpert yes , so you need to look in the output of npm start
                    SteakExpert @sdetweil
                    @sdetweil The only feedback it produces is:
                    [WARN] You're using a full whitelist configuration allow for all IPs
                      @SteakExpert are you using pm2?
                      if so, pm2 logs --lines=xxx
                      xxx is the most recent lines
                      there should be a lot more output
                        @SteakExpert this is my startup
                        (base) sam@sams:~/MagicMirror.old$ npm start
                        > magicmirror@2.31.0-develop start
                        > npm run start:x11
                        > magicmirror@2.31.0-develop start:x11
                        [2025-01-03 17:46:17.197] [LOG]   Starting MagicMirror: v2.31.0-develop
                        [2025-01-03 17:46:17.209] [LOG]   Loading config ...
                        [2025-01-03 17:46:17.209] [LOG]   config template file not exists, no envsubst
                        [2025-01-03 17:46:17.348] [INFO]  Checking config file /home/sam/MagicMirror.old/config/config.js ...
                        [2025-01-03 17:46:17.382] [INFO]  Your configuration file doesn't contain syntax errors :)
                        [2025-01-03 17:46:17.382] [INFO]  Checking modules structure configuration ...
                        [2025-01-03 17:46:17.409] [INFO]  Your modules structure configuration doesn't contain errors :)
                        [2025-01-03 17:46:17.409] [LOG]   Loading module helpers ...
                        [2025-01-03 17:46:17.462] [LOG]   Initializing new module helper ...
                        [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-Wallpaper
                        [2025-01-03 17:46:17.463] [LOG]   No helper found for module: clock.
                        [2025-01-03 17:46:17.463] [LOG]   Initializing new module helper ...
                        [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-EmbedURL
                        [2025-01-03 17:46:17.527] [LOG]   Initializing new module helper ...
                        [2025-01-03 17:46:17.527] [LOG]   Module helper loaded: MMM-Config
                        [2025-01-03 17:46:17.534] [LOG]   Initializing new module helper ...
                        [2025-01-03 17:46:17.534] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                        [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-CalendarExt3.
                        [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-page-indicator.
                        [2025-01-03 17:46:17.535] [LOG]   init module helper SampleModule
                        [2025-01-03 17:46:17.535] [LOG]   Module helper loaded: SampleModule
                        [2025-01-03 17:46:17.535] [LOG]   No helper found for module: MMM-pages.
                        [2025-01-03 17:46:17.572] [LOG]   Initializing new module helper ...
                        [2025-01-03 17:46:17.572] [LOG]   Module helper loaded: calendar
                        [2025-01-03 17:46:17.572] [LOG]   All module helpers loaded.
                        [2025-01-03 17:46:17.574] [LOG]   Starting server on port 8090 ...
                        [2025-01-03 17:46:17.575] [WARN]  You're using a full whitelist configuration to allow for all IPs
                        [2025-01-03 17:46:17.867] [LOG]   Server started ...
                        [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Wallpaper
                        [2025-01-03 17:46:17.867] [LOG]   Starting node helper for: MMM-Wallpaper
                        [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-EmbedURL
                        [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Config
                        [2025-01-03 17:46:17.868] [INFO]  MMM-Config restart parm ='none'
                        [2025-01-03 17:46:17.868] [LOG]   command =/home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                        [2025-01-03 17:46:17.868] [LOG]   Starting module helper:MMM-Config
                        [2025-01-03 17:46:17.868] [LOG]   execing /home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                        [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                        [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: SampleModule
                        [2025-01-03 17:46:17.875] [LOG]   Starting module helper:SampleModule
                        [2025-01-03 17:46:17.876] [LOG]   Connecting socket for: calendar
                        [2025-01-03 17:46:17.876] [LOG]   Starting node helper for: calendar
                        [2025-01-03 17:46:17.876] [LOG]   Sockets connected & modules started ...
                        [2025-01-03 17:46:17.876] [LOG]    got port=8300
                        [2025-01-03 17:46:18.047] [LOG]   Launching application.
                        [2025-01-03 17:46:18.224] [INFO]  System information:
                        ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                        ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-125-generic
                        ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                        ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                        [3484285:0103/174618.683913:ERROR:nss_util.cc(345)] After loading Root Certs, loaded==false: NSS error code: -8018
                        [2025-01-03 17:46:18.707] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840963687&to=1666862563687&panelId=6 with error: ERR_NAME_NOT_RESOLVED
                        (Use `electron --trace-warnings ...` to show where the warning was created)
                        [2025-01-03 17:46:18.708] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840776401&to=1666862376402&panelId=2 with error: ERR_NAME_NOT_RESOLVED
                        [2025-01-03 17:46:18.711] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                        [2025-01-03 17:46:18.799] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_13_MMM-HomeAssistantDisplay' ]
                        [2025-01-03 17:46:18.830] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_7_MMM-HomeAssistantDisplay' ]
                        [2025-01-03 17:46:18.833] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 120000
                        [2025-01-03 17:46:18.834] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-b01395933cda72021e36fae98c07a186/basic.ics - Interval: 120000
                        [2025-01-03 17:46:18.834] [LOG]   SampleModule received a socket notification: CONFIG - Payload: [object Object]
                        [2025-01-03 17:46:18.844] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                        [2025-01-03 17:46:18.862] [INFO]  [MMM-HomeAssistantDisplay] [
                          'Conected to Home Assistant for module_13_MMM-HomeAssistantDisplay after 0 retries'
                        [2025-01-03 17:46:18.865] [INFO]  [MMM-HomeAssistantDisplay] [
                          'Conected to Home Assistant for module_7_MMM-HomeAssistantDisplay after 0 retries'
                        [2025-01-03 17:46:18.873] [LOG]   connection started = connect
                        [2025-01-03 17:46:18.874] [LOG]   path=/home/sam/MagicMirror.old/modules/MMM-Config/schema3_16467085098090.json
                        [2025-01-03 17:46:19.102] [INFO]  Calendar-Fetcher: Broadcasting 25 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                        [2025-01-03 17:46:19.635] [INFO]  Calendar-Fetcher: Broadcasting 156 events from https://calendar.google.com/calendar/ical/6/basic.ics.
                        [2025-01-03 17:46:20.749] [LOG]   stdout: completed
                        I have MMM-Config debug enabled
                          @SteakExpert said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                          yeh, that message was put there to tell you what to do instead of being dead
                          that means the error trap worked…
                          Reply Quote 1
                            @sdetweil Just emailed you the log! Thanks, Sam.
                              @SteakExpert there is more after that that I need…
                                @SteakExpert we are looking for content in the MagicMirror runtime messages (from npm start ) that might look like this (forced an error just to get the content)
                                 [LOG]   stdout: --------------------MMM-Config
                                module MMM-Carousel has an error in the construction of its defaults section
                                the error line is     transitionTimeout: somevalue,
                                please change it to the literal value of the referenced defaults variable
                                and restart MagicMirror
                                the browser message is the last part setup of the error handler
                                • D
                                  DarkV
                                  I am a noob at this, how do I set the port to use the browser and how do I show the QR code on my MM?
                                    sdetweil @DarkV
                                    @DarkV the default port is 8080
                                    you can edit in config.js and change the number, or change it in the form
                                    and in the MMM-Config config set showQR to true
                                    the doc mentions how to open the form directly in a browser
                                    note on the QR you MUST change config.js to support outside MagicMirror system access, per the doc
                                    D 1 Reply Last reply
                                    • D
                                      DarkV @sdetweil
                                      @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                      config set showQR
                                      So, should I add “showQR = True” to the configj.s?
                                      As I said earlier, I do not have the skill of the format.
                                      • D
                                        DarkV @DarkV
                                        @DarkV
                                          sdetweil @DarkV
                                          @DarkV the doc (README.md) says the url
                                          • D
                                            DarkV @sdetweil
                                            @sdetweil Apologies for my lack of knowledge, but I didn’t fully understand your response about the URL. Please keep in mind that I’m not very experienced with coding.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
