    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 463.3k Views 31 Watching
      sdetweil @DarkV
      @DarkV it takes a little bit of info
      a url contains
      a protocol type secure(https) or not (http)
      a server name or address
      a port
      a path
      and optionally some parameters
      for MMM-Config
      just protocol, server, port and path
      on your local network, we dont need to build our everything for secure encrypted communications
      if the machine you are opening the browser on is the same machine as MagicMirror is running, then you can use localhost
      otherwise you need to know the MagicMirror server ip address or network name
      the port value comes from the MagicMirror config.js, default is 8080
      (if you dont see a port specified in a url, then the browser uses the default for the protocol, 80 or 443 not/secure, as appropriate)
      and then the path, for MMM-Config there are two :
      for configuration
      /configure
      and for module installation
      /installer
      http://ip:port/configure
      on the same machine, using defaults
      http://localhost:8080/configure
      • I Offline
        IamWayne
        Hello, Newbie here, how do you go about using this? What do I need to get started? Do I need Node.js? Have it installed, yet completely lost. How about a guide or video. Thanks
          sdetweil @IamWayne
          @IamWayne did you add the module to config.js?
          and restart MagicMirror?
          if so then the url from the doc
          http://ip:mm_port/configure
          but by default the MagicMirror config only allows apps from inside the same system to connect, so you would have to minimize MagicMirror then launch a browser to
          or for the module installer
          http://localhost:8080/installer
          • I Offline
            IamWayne
            Oh I think that I understand now. I have to add this to the MM installer in the correct folder, correct?
              sdetweil @IamWayne
              @IamWayne this is an add on module, not part of the base
              see the 1st link in my signature below for short topic about installing modules
              • citizendevpiC Offline
                citizendevpi
                this module works very well , thanks for the hard work and time . makes this project simple and fun !!
                  DarkV @sdetweil
                  @sdetweil Still no joy, I am going to reinstall.I cannot display the QR code as I do not have any zones left and cannot load the web page1.png Screenshot 2025-04-03 155111.png
                    sdetweil @DarkV
                    @DarkV you dont need the qr code
                    can you show the messages from npm start?
                    if using pm2 then
                    pm2 logs --lines=100
                      DarkV @sdetweil
                      @sdetweil How do I get logs? I am a noob regarding MM
                      I found this
                      [08.01.2025 00:49.42.199] [ERROR] Failed to retrieve repo info for MMM-Tools: Error: Command failed: cd /home/junior/MagicMirror/modules/MMM-Tools && git fetch -n --dry-run
                      fatal: unable to access ‘https://github.com/bugsounet/MMM-Tools/’: Could not resolve host: github.com
                        DarkV @sdetweil
                        This post is deleted!
                          sdetweil @DarkV
                          @DarkV way back further in the log, back 50 lines maybe
                          as using pm2 the good and error lines are separated into two lists
                          none of the bugsounet repos are online any more
                          so if you dont want to see those errors, you can exclude them from the updatenotification module scans
                            DarkV @sdetweil
                            @sdetweil SyntaxError: Unexpected identifier 'config’
                             at internalCompileFunction (node:internal/vm:73:18)
                             at wrapSafe (node:internal/modules/cjs/loader:1185:20)
                             at Module._compile (node:internal/modules/cjs/loader:1227:27)
                             at Object…js (node:internal/modules/cjs/loader:1326:10)
                             at Module.load (node:internal/modules/cjs/loader:1126:32)
                             at node:internal/modules/cjs/loader:967:12
                             at Function._load (node:electron/js2c/node_init:2:13357)
                             at Module.require (node:internal/modules/cjs/loader:1150:19)
                             at require (node:internal/modules/cjs/helpers:121:18)
                             at loadConfig (/home/junior/MagicMirror/js/app.js:118:14)
                             at App.start (/home/junior/MagicMirror/js/app.js:248:18)
                             at Object. (/home/junior/MagicMirror/js/electron.js:192:7)
                             at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                            [27.03.2025 09:44.46.126] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            Warning: vkCreateInstance: Found no drivers!
                            Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                            at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                            at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                            at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                            at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                            at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                            [27.03.2025 09:46.55.825] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:122
                            [27.03.2025 09:47.26.134] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            [27.03.2025 09:53.43.417] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            [27.03.2025 09:59.04.576] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            [27.03.2025 10:02.53.766] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            [27.03.2025 10:15.08.770] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                            SyntaxError: Unexpected token '{'
                            [27.03.2025 10:15.58.981] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            /home/junior/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                            [27.03.2025 10:22.57.762] [WARN] Version is incorrect. Skip module: ‘MMM-Config’
                            [27.03.2025 10:29.29.494] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                            [27.03.2025 10:30.26.627] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/junior/MagicMirror/config/config.js:130
                              sdetweil @DarkV
                              @DarkV mmm-config requires MagicMirror version 2.28 or higher
                              also, you have some syntax error around line 122 in config.js
                              pm2 flush to empty the logs
                              and see what hsppens after you fix that config.js error
                                DarkV @sdetweil
                                @sdetweil, I’m sorry. Can you please highlight where I have the error? I am considering reinstalling it as I cannot even update Magic Mirror. I want to back up Config.js, but if it contains faults, then I will be back to square one.
                                * MagicMirror² Config Sample
                                 * By Michael Teeuw https://michaelteeuw.nl
                                 * MIT Licensed.
                                 * see https://docs.magicmirror.builders/configuration/introduction.html
                                 * and https://docs.magicmirror.builders/modules/configuration.html
                                let config = {
                                	address: "localhost", 	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                	ipWhitelist: [], 	// Set [] to allow all IP addresses
                                															// or add a specific IPv4 of 192.168.2.49 :
                                	language: "en",
                                	locale: "en-US",
                                	timeFormat: 24,
                                	units: "metric",
                                	module: 'MMM-MovieListings',
        position: 'bottom_center',   // This can be any of the regions. Best results in left or$
                                					apiKey: '',
                                					region: 'GB',
                                					language: 'en-UK',
                                					interface: 'poster', //'list', 'poster', 'detailed'
                                					includeMoviePlot: false,
                                					maxPlotLength: 198,
                                					header: 'Kinofilme',
                                					moviesPerPage: 0,
                                					refreshInterval: 1000 * 60 * 60 * 24, //Once a day
                                					baseUrl: 'https://api.themoviedb.org/3/movie/now_playing',
                                					animationSpeed: 2.5 * 1000,
                                					pageChangeInterval: 35 * 1000
                                        module: 'MMM-Globe',
                                	position: 'bottom_left',
                                		style: 'geoColor',
                                		imageSize: 300,
                                		ownImagePath:'',
                                		updateInterval: 10*60*1000
                                  module: 'MMM-Tools',
                                  position: 'bottom_right',
                                    refresh: 1000 * 5,
                                    containerSize: null,
                                    itemSize: null
                                    module: "MMM-EyeCandy",
                                    position: "top_center",
                                        maxWidth: "75%",       // Sizes the images. Retains aspect ratio.
                                        style: '1',            // Style number or use ownImagePath to override style
                                        ownImagePath: '',      // 'modules/MMM-EyeCandy/pix/name-graphics-lisa-596441.jpg'
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_right"
                                			header: "UK Holidays",
                                						symbol: "calendar-check-o ",
                                                        url: "https://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"
                                			module: "compliments",
                                			position: "top_bar"
                                			module: "MMM-OpenmapWeather",
                                		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                                		header: "Current Weather", //Location is the default value if header is empty or not defined.
                                			locationID: "2651817", //Location ID from http://openweathermap.org/help/city_list.txt
                                			appid: "",  //openweathermap.org API key
                                      			colorIcon: true
                                		module:"MMM-Config",
                                		position:"top_left",
                                			// the QR code (if requested) will appear here
                                		config:{
                                                        showQR: true
                                			module: "weather",
                                			header: "Weather Forecast",
                                				type: "forecast",
                                				locationID: "2651817", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                				apiKey: ""
                                			module: "newsfeed",
                                			position: "bottom_bar",
                                				feeds: [
                                						title: "BBC UK News",
                                						url: "http://feeds.bbci.co.uk/news/uk/rss.xml"
                                				showSourceTitle: true,
                                				showPublishDate: true,
                                				broadcastNewsFeeds: true,
                                				broadcastNewsUpdates: true
                                  sdetweil @DarkV
                                  @DarkV i do not SEE anything, but i am away from my computer all day, driving.
                                  so i cannot run it thru the
                                  cd ~/MagicMirror
                                  npm run config:check
                                  command
                                    DarkV @sdetweil
                                    @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                    [04.04.2025 16:09.03.683] [INFO] Checking file… /home/junior/MagicMirror/config/config.js
                                    [04.04.2025 16:09.03.781] [INFO] Your configuration file doesn’t contain syntax errors :)
                                    junior@MAGIC-MIRROR:~/MagicMirror $
                                      sdetweil @DarkV
                                      @DarkV ok
                                      now do
                                      cd ~/MagicMirror/MMM-Config
                                      ./test-convert.sh override
                                      you should get one message
                                      completed
                                        DarkV @sdetweil
                                        Results
                                        junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test-convert.sh override
                                        -bash: ./test-convert.sh: No such file or directory
                                        I used a fresh SD card for the reinstallation, but some of her modules are incompatible with the new setup. Consequently, my wife has firmly decided to stick with the current version until her modules stop functioning. Unfortunately, since one of the modules doesn’t work with the old MagicMirror version, I’m at an impasse. It is a pity, I wanted this as due to dyslexia, this would have been perfect for my situation
                                          sdetweil @DarkV
                                          @DarkV ok,my fault
                                          cd ~/MagicMirror/modules/MMM-Config
                                          ./test_convert.sh  override
                                            DarkV @sdetweil
                                            junior@MAGIC-MIRROR:~/MagicMirror/modules/MMM-Config $ ./test_convert.sh overri de
                                            --------------------MMM-Config
                                            module updatenotification-defaults has an error in the construction of its defau lts section
                                            the error line is disabled: true;
                                            please change it to the literal value of the referenced variable
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
