    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      sdetweil
      For any that want to look at the multi-module form layout and give feedback
      checkout the multi-module branch
      git checkout multi-module
      there is a file that contains the list of module names that CAN be used multiple times in the same config.js
      modules_list.txt
      you cannot submit the form, only view it…
      to go back to the operating version
      git checkout main
      or
      (with the .... fixes)
      git checkout newform
        stoffel @sdetweil
        i did it. WOW, all works well. thanks, great job and fast :thumbs_up:
        but it works only when i open …/review or must add ‘?port=8300’ at …/config.html
        thank you very much :-)
          sdetweil @stoffel
          @stoffel said in Are you tired of editing config.js, or have trouble doing it, see my new module:
          well, i need a free port to have the two parts communicate.
          I had ‘guessed’ at a free port, but some other users had stuff running there
          so, I have it get a free port, but now I have to pass that to the form side…
          use the review URL , it will always redirect to the correct url
          it will probably never change on your system , so once u know what the number is, use that url…
            stoffel @sdetweil
            ok, thanks for you support. great job !
            i follow this tread and test your module. but in the next days i am a little bit busy.
            so, @ all have a nice WE
              sdetweil @stoffel
              @stoffel thanks for your help!..
              I need people like you to help improve the module. every bug found now helps…
                stoffel @sdetweil
                thanks ;-)
                and i like people like you who spent a lot of time for creating useful modules like this !!
                again thanks a lot
                • BKeyportB
                  BKeyport Module Developer
                  So, I’m getting the header and nothing else.
                  fresh install of MagicMirror using the script, PM2. Here’s my config, as you can see, the only changes are the listening address, the ipWhitelist, and the addition of the module as shown in the readme.
                  modules I installed (but didn’t configure for testing) were MMM-Config, MMM-Multimonth, and MMM-OpenWeatherForecast.
                  var config = {
                          address: "0.0.0.0",     // Address to listen on, can be:
                          port: 8080,
                          basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                          ipWhitelist: [],        // Set [] to allow all IP addresses
                          useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
                          httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
                          httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
                          language: "en",
                          locale: "en-US",
                          timeFormat: 24,
                          units: "metric",
                                  module:"MMM-Config",
                                  position:"top_right",  // the QR code (if requested) will appear here
                                  config:{
                  ... (no changes after this point)
                    sdetweil @BKeyport
                    @bkeyport if u open the developers window, ctrl-shift-i, and select the console tab. are there errors shown
                    also if u look in the pm2 logs, are there problems.
                    do a
                    and try again. lots of fixes there
                    the latest code requires a port number to be passed to the form page… use the review link
                    http://mm_ip:mm_port/modules/MMM-Config/review
                    (thats the url on the qr image)
                    BKeyportB 1 Reply Last reply
                    • BKeyportB
                      Failed to load resource (Connection refused) http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkO1_
                      DevTools failed to load SourceMap: Could not load content for http://IP:8080/modules/MMM-Config/node_modules/jsonform/deps/opt/bootstrap.css.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                      Then repeated
                      (anonymous) @ VM6:1
                      create @ polling-xhr.js:198
                      Request @ polling-xhr.js:115
                      request @ polling-xhr.js:62
                      doPoll @ polling-xhr.js:90
                      poll @ polling.js:74
                      doOpen @ polling.js:23
                      open @ transport.js:44
                      open @ socket.js:194
                      Socket @ socket.js:119
                      ./node_modules/engine.io-client/lib/index.js.module.exports @ index.js:3
                      open @ manager.js:112
                      (anonymous) @ manager.js:342
                      VM6:1 GET http://IP:8200/socket.io/?EIO=4&transport=polling&t=NchkPo7 net::ERR_CONNECTION_REFUSED
                        sdetweil @BKeyport
                        @bkeyport did u use the review link, its probably port 8300 now
                        see the instructions here
                        https://github.com/sdetweil/MMM-Config/issues/8
                        • BKeyportB
                          @sdetweil review link as shown redirects to:
                          http://raspberrypi:8080/modules/MMM-Config/config.html?port=8301
                          which fails because it’s not in DNS - changing raspberrypi to my IP address results in same header as before. Did update newform, and restarted MM.
                          S 3 Replies Last reply
                            sdetweil @BKeyport
                            @bkeyport i have cors allow all …
                              sdetweil @BKeyport
                              @bkeyport I asked the machine for its IP address /name…
                              most routers now -a-days register the DHCP requests to names…
                              • BKeyportB
                                Yeah, my router setup is stupid in my testing area. :)
                                  sdetweil @BKeyport
                                  @bkeyport and npm install after checkout newform?
                                  • BKeyportB
                                    @sdetweil Yeah, that did it… Forgot to npm install. D’oh!
                                    S 2 Replies Last reply
                                      sdetweil @BKeyport
                                      @bkeyport I construct the review url like this
                                            // thi is the name in the preferences pi
                                            this.hostname = os.hostname();
                                            this.config.url =
                                              "http://" +
                                              (this.config.address == "0.0.0.0"
                                                ? this.hostname
                                                : this.config.address) +
                                              this.config.port;
                                      so, lacking the dns entry, I would configure to use one of the specific ip addresses
                                        sdetweil @BKeyport
                                        @bkeyport
                                        @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                        Yeah, that did it…
                                        does that mean you system is working now?
                                        • BKeyportB
                                          @sdetweil Yeah. playing with it now making sure it works with my module and modules I’ve taken up support for.
                                            sdetweil @BKeyport
                                            @bkeyport cool… there are SO many variations… and guesses to make…
                                            the upcoming multi-module version, will add on a new capability…
                                            generate a new file that can be used to REALLY describe the parms, and take away any abiguity on my part.
                                            I generate it ANYHOW to make the form work… so, its a nit to save it… I’m working thru USING the file, instead of recreating every time…
                                            and then the author can tune it, to make selection lists, instead of text fields, etc…
                                            optional sets of fields, depending on selection
                                            the author packages that file with the module and voila, if its there my module uses it…
                                            described here
                                            https://github.com/sdetweil/MMM-Config/issues/11
                                            • 14
                                            • 15
                                            • 3 / 15
