    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
    • BKeyportB
      @sdetweil OK, it seems to be horribly broken on my side. From save to save, it’s not keeping the modules in config.js - example, my MMM-Multimonth won’t stay configured.
      I can’t disable default modules. (Calendar, which I don’t use due to incompatibility with my agenda provider)
      You want the config files to look though and see what’s happening?
        sdetweil @BKeyport
        @bkeyport yes please…
          sdetweil
          I have updated the module now to support multiple instances of the same module,
          a little config (adding name to a file) … altho the module will auto detect if multiples are being used NOW, regardless of the file
          ALSO, one lacking feature of this solution is being able to get the form exactly right… as the info is missing in the module data…
          BUT i am creating the form info ANYHOW, so it can be saved and manually edited to improve the module experience, and I will use THAT instead of constructing the info every time…
          this means u can add selection lists, and other features (very easily)
          see the two issues for instructions
          multi-module
          https://github.com/sdetweil/MMM-Config/issues/2
          and save and use schema file
          https://github.com/sdetweil/MMM-Config/issues/11
          Mykle1M 1 Reply Last reply
          Reply Quote 2
          • Mykle1M
            @sdetweil said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            Oh, this is quite a feature, and much appreciated. :thumbsup:
              sdetweil
              if u downloaded to test out multi-module, do another git pull…
              I had turned off rename of config.js while I tested save… oops… forgot to turn it back on
              corrected now
                sdetweil
                I have promoted the multi-module version to be the only version…
                no need for any git checkout now
                • Mykle1M
                  65 emails from your repo. Come on man!
                  :laughing:
                  S BKeyportB 2 Replies Last reply
                  Reply Quote 1
                    sdetweil @Mykle1
                    @mykle1 nah… you got a pool… I am jealous!!
                    • BKeyportB
                      BKeyport Module Developer @Mykle1
                      @mykle1 We’re working hard. wanna help? 🤣🤣🤣
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @BKeyport
                        @bkeyport said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                        Where were you at the very beginning of development of this module? I don’t remember seeing you anywhere. You were probably off policing the forum. :-)
                        BKeyportB 1 Reply Last reply
                        Reply Quote 1
                        • BKeyportB
                          @mykle1 When it was under early development I was in the very VERY busy part of my job.
                          I’m a tax guy.
                          • BKeyportB
                            BKeyport Module Developer @BKeyport
                            I’ve now added support for MMM-Config to the modules I’m working with actively.
                            Was rather easy, all things considered - if you write a module, I would strongly recommend working with MMM-Config, who knows where this will go!
                            • A
                              anima
                              hello i have a question, i am running MagiMirror ² in Docker on my Unraid Server, i have installed the module but cant open the config form site. do i need to make some special configurations because it runs in docker ?
                                sdetweil @anima
                                @anima what is your config.js setting for address:
                                you would have to use the container IP address and port on the form url. because it it not mapped to the docker host port
                                A 1 Reply Last reply
                                • A
                                  anima @sdetweil
                                  @sdetweil do you mean this https://imgur.com/a/jzi0Idj ?
                                    sdetweil @anima
                                    @anima only needed the line with address:“0.0.0.0”
                                    ok, so we need to find out the ip address of the MM container
                                    docker ps
                                    will give u a line like this
                                    11e836525b8d   xxxyyyzzz   "/usr/bin/supervisord"   4 months ago   Up 3 weeks   0.0.0.0:82->81/tcp, :::82->81/tcp, 0.0.0.0:5901->5900/tcp, :::5901->5900/tcp, 0.0.0.0:8280->8080/tcp, :::8280->8080/tcp
                                    the 1st token is the container id
                                    then do this
                                    docker inspect 11e836525b8d
                                    and in the stream of info is
                                                "IPAddress": "172.17.0.2",
                                    then use that from the system running the docker container
                                    http://172.17.0.2:8300
                                    to get that as one line of output, u can create this one line bash script
                                    docker inspect $(docker ps -q | awk '{print $1}') | grep -m 1 '"IPAddress"' | awk -F\" '{print $4}'
                                    you can’t use it from another system as there is no path to the container from outside
                                    now, you could fix the startup of the MM container by adding
                                    -p 8300:8300
                                    to the docker run command
                                    this map the container port 8300 to the host port 8300
                                    then from your pc or non-docker-host machine
                                    http://docker_host_ip:8300
                                    should bring up the form
                                    • A
                                      anima @sdetweil
                                      @sdetweil ok thx, but then it should be better to run it from a pi (i have a spare one) because the container port is used by another service which i need.
                                        sdetweil @anima
                                        @anima well, each container has its own set…
                                        the code looks for a free port from 8300 - 8500… but in a container it will be fresh, so 8300
                                        the code hard codes 8300, so you can’t map it to anything else
                                        uros76U 1 Reply Last reply
                                        • uros76U
                                          uros76 @sdetweil
                                          Hi. I am trying to implement it on my MM and get only get below header in the browser. I am trying to open it with this address http://raspberrypi:8080/modules/MMM-Config/review
                                          The same happens if I open MM via IP address.
                                          Did I miss something? I saw on page6 of this thread someone else had same problem but that solution didn’t help me.
                                          Doing ctrl+shift+I and looking at console output I get this error:
                                          My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
                                          S 2 Replies Last reply
                                            sdetweil @uros76
                                            @uros76 can u show me the config.js for the module?
                                            does it show on the MM screen?
                                            is your config.js address:“localhost”
                                            if so, you can only access from the PI system itself (localhost means only apps INSIDE the pi can access that app)
                                            Reply Quote 1
                                            • 6
                                            • 14
                                            • 15
                                            • 4 / 15
