    Face Recognition with inferred light
    52 Posts 5 Posters 54.4k Views 4 Watching
    • F Offline
      feuerball
      @paviro
      Here it is
      0_1464191008459_config.js
      paviroP 1 Reply Last reply Reply Quote 0
      • paviroP Offline
        paviro @feuerball
        Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
        I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
        We're all stories in the end. Just make it a good one, eh?
        – The Doctor
        • F Offline
          feuerball
          @paviro
          It’s still the same error like above :(
          Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
          • paviroP Offline
            paviro
            I am really not sure what this error is about…
            @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
            – The Doctor
            MichMichM 1 Reply Last reply Reply Quote 0
            • MichMichM Offline
              MichMich @paviro
              module.data.classes should contain the classes set in your config file. (If I remember correctly.)
              • paviroP Offline
                paviro
                Strange I still have no clue how this error could be reproduced…
                – The Doctor
                • P Offline
                  POIMann
                  Had the same issue.
                  Removing the module “localtransport” solved it for me.
                  • paviroP Offline
                    paviro @POIMann
                    @POIMann really? That’s interesting! So it works without problems now?
                    – The Doctor
                    • P Offline
                      POIMann
                      The use of this.data in localtransport.js conflicts with this.data-object from the module instance properties.
                      I patched it by replacing “this.data;” with “this.response;” in all its occurrences in localtransport.js.
                      #enjoy
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        That … would make sense. It’s helpful for module writers to check the documentation on the wiki to see what method, classes, or other naming conventions are being used to avoid conflicts.
                        • paviroP Offline
                          paviro
                          Thank you a lot for figuring that out! :)
                          – The Doctor
                          • F Offline
                            feuerball
                            gonna try it later, thanks
                            • 3 / 3
