    [MMM-Buttons] Connect multiple buttons to send configurable notifications
    40 Posts 15 Posters 35.6k Views 14 Watching
    • istepgueuI Offline
      istepgueu
      Does anyone know how to read the initial value of a button (GPIO) before it is run ?
      Thanks.
        Mar
        @Jopyth Moved my post here out from another thread.
        I am having one more issue though. Using a python test program i can see every single instance of my button press is registered instantly. But in the mirror it seems MMM-Buttons doesnt register pushes unless sometimes I double or triple click…then sometimes the button registers 5-6 times. I’m not really sure how to debug this sort of thing.
        Also would it be right to assume the pull up/down resistors were not enabled with MMM-Buttons?
        istepgueuI 2 Replies Last reply Reply Quote 0
          istepgueu @Mar
          @Mar all is here https://forum.magicmirror.builders/topic/211/button
            istepgueu @Mar
            @Mar i have same problem. I run my little script button.py before start MM and its solve the problem
              Mar @istepgueu
              @istepgueu Ive taken your button.py program and modified it for me two buttons 5/6. And while the program reads my button presses perfectly, MM-Buttons doesnt at all. I pretty much have to double click each time to make a button register. It switches my profiles just fine … but just takes lots of clicks to register.
              import RPi.GPIO as GPIO
              import time
              GPIO.setmode(GPIO.BCM)
              GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
              GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
              tries = 0
              while (tries < 200000):
                  if GPIO.input(6):
                      print("Open 6")
                  else:
                      print("Close 6")
                  if GPIO.input(5):
                      print("Open 5")
                  else:
                      print ("Close 5")
                  time.sleep(0.5)
                  tries = tries + 1
                Mar @istepgueu
                @istepgueu Will take a look through this now, but i already have a 1k resistor between pins 5/6 and the respective button. Hopefully something else comes up here.
                Yes my problem seems a bit opposite of what was posted in your link. I dont have any erroneous button presses, it just takes a few clicks until MMM-Buttons registers the click. You button.py registers every click instantly. So must be something in the buttons code?
                  Jopyth Moderator
                  @Mar @istepgueu The library (onoff) I am currently using does not directly allow configuring pull up and pull down resistors, and I was not able to make it consistently work (see Readme).
                  Therefore I myself made use of the “right” pins for my setup, as the readme says:
                  The defaults can be seen in Table 6-31 on pages 102 and 103 of the BCM2835 ARM Peripherals documentation.
                  There I simply used buttons with the correct default pull-up/pull-down resistor configuration (second column of that table), and I wanted a few pins close together on the board, so I chose GPIO 22,23,24 and 25 (connected 4 buttons), since they all have the default of a low input.
                  Helpful sticky: How to troubleshoot
                    Mar @Jopyth
                    @Jopyth Thanks for the response, and that seems to make complete sense. I missed that part in the documentation.
                    Though upon trying PINS 22/23 i am still getting the same result. The button.py program detects each individual click properly, but in the MM I have to double (sometimes triple) click the button so that it registers. I can see it registers as it shows up in the pm2 logs and my profile changes.
                    Im not sure if its an issue with the buttons as they are a standard 4 pin button and the test script works fine with them?
                      Jopyth Moderator @Mar
                      @Mar Well its not, as if it were documented anywhere in my readme. :( Should probably add this somewhere.
                      How long are you pressing the button? For a very short time? Note, that if the press is longer than 500ms it will not be registered as a (short) press (it is the maxShortPressTime and can be configured).
                      If this is not the case, I am sorry, but I have no real idea how to fix it, without having the same situation on my Pi.
                      M 3 Replies Last reply Reply Quote 1
                        Mar @Jopyth
                        @Jopyth I thought this also, and set the short time from 0-1000ms and still will only register the second of a double click.
                        Its very consistent though, i can get it to work 100% of the time with a double click like opening a folder on the computer. one click doesnt do anything, and I don’t believe the longPress worked at all (But i wasnt using it so not that bothered with it).
                        Maybe its just the buttons…i just dont have anything else around that i could use to test as a button.
                        • 4 / 4
