    Avoid "HDMI" splash screen on PIR control
    6 Posts 6 Posters 1.5k Views 6 Watching
    • V
      vongomben
      Re: PIR Sensor - Sleep LCD monitor
      Hello.
      I found this interesting topic on the forum, but couldn’t find a solution to the “HDMI” screen popping up whnever I turn on my Screeen device.
      I’m using the standart board to use old Laptop screens.
      Any advices?
      S cowboysdudeC 2 Replies Last reply Reply Quote 0
        sdetweil @vongomben
        @vongomben did you mean when u turn off?
        this is the energystar compliance in the monitor that says “oh no!, input is turned off, I will power off soon”
        no way to work around this. except to turn the monitor off
        not many ways to do that
        V 1 Reply Last reply Reply Quote 1
        • cowboysdudeC
          cowboysdude Module Developer @vongomben
          @vongomben Mine does it too. It flashes a couple times then goes off.
          @sdetweil is right… no way around that.
          • V
            vongomben @sdetweil
            @sdetweil ok.
            I still have the remote from the board, will check if there is a standby function there.
            Will update you here.
            d
              sdetweil
              there is no solution, other than to find a monitor that doesn’t do it.
              just about every display and tv shows some branding message during power on.
                this why my sleep/wake module hides all the modules instead of turning the display off.
                (and the fact that I can’t get it to turn off by software. but I can turn it on…)
