    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
      DDE12 @sdetweil
      I’m completely lost now. I thought all of this went in config.js.
        sdetweil @DDE12
        @DDE12 all of THAT goes.in config.js
        but if you want to change the color of the text for the second day of the week
        in custom.css
        . MMM-CalendarExt3  .weekday_1 {
              color:green;
          bicolorbore586
          @fedale @MMRIZE @chadjohn2 I am also trying (unsuccessfully) to have the Calendar event change color depending on which name is in the title.
          With the original magicmirror calendar, I’ve used
          customEvents: [ {keyword: “Ben”, color: “Brown”} ], which shows the event title and associated symbol in Brown.
          In EXT3, using eventTransformer, only the symbol shows in color
          I’ve tried to use
          eventTransformer: function(event) {
          if (event.title.search(“Ben”) > -1) {
          event.className = “Ben”;
          with customer.css
          .CX3 .Ben {
          color: brown;
          However, this then shows a blank calendar
          Have any of you been successful?
          Where am I going wrong?
            MMRIZE @bicolorbore586
            @bicolorbore586
            You have to return event object in eventTransformer function. When you omit ‘return’ statement in a function, implicitly it is same with ‘return null’
              bicolorbore586 @MMRIZE
              @MMRIZE have tried that, still doesn’t show anything.
              return event
              • mumblebajM Offline
                mumblebaj Module Developer @bicolorbore586
                @bicolorbore586 If I am not mistaken, your return goes outside the IF statement
                BKeyportB B 2 Replies Last reply Reply Quote 0
                • BKeyportB Offline
                  BKeyport Module Developer @mumblebaj
                  @mumblebaj
                  Try this:
                  eventTransformer: function(ev) {
                    if (ev.title.search(“Ben”) > -1)  ev.className = “Ben”;
                    return ev
                  directly off the README.md :
                  eventTransformer: (ev) => {
                    if (ev.title.search('John') > -1) ev.color = 'blue'
                    return ev
                    bicolorbore586 @mumblebaj
                    @mumblebaj so that now means I can see the events again, but still not coloured how I want.
                      mike23pizzo
                      I’m having some issues with broadcastPastEvents: true. Past events aren’t showing up on the calendar. Below is the default calendar code and the MMM-CalendarExt3 code. As well as a screenshot.
                      			header: "Events",
                      				fetchInterval: "1000",
                      				colored: true,
                      				broadcastPastEvents: true,
                      						url: //URL//,
                      						symbol: "calendar-check",
                      						color: "#338FFF",
                      						url:  //URL//,
                      						url:  //URL//,
                      						symbol: "utensils",
                      						color: "#FFFB21",
                      			module: "MMM-CalendarExt3",
                      			position: "bottom_right",
                      			weekIndex: "0",
                      				mode: "week",
                      				firstDayOfWeek: "0",
                      				refreshInterval: "10000",
                      				calendarSet: ['us_holidays','mikes_cal','dinners'],
                        sdetweil @mike23pizzo
                        @mike23pizzo it’s only set before the calendars list.
                        what mm version are u on? fix in latest 2.20 for events being truncated
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 67
                        • 68
                        • 19 / 68
