    MMM-CalendarExt3
    686 Posts 82 Posters 2.8m Views 86 Watching
    • L Offline
      Lilleberg @MMRIZE
      @MMRIZE My language and locale are Norwegian. Using nb in the config file.
      • L Offline
        Lilleberg @MMRIZE
        @MMRIZE Thanks!
        1 Reply Last reply Reply Quote -1
          sdetweil @Lilleberg
          @Lilleberg said in MMM-CalendarExt3:
          error: Your local changes to the following files would be overwritten by merge:
          MMM-CalendarExt3.css
          MMM-CalendarExt3.js
          looks like u modified the module code, and updated cannot be applied til you fix that.
          generally you never edit the source files of a module.all config goes in config.js and all css updates go is custom.css
            bicolorbore586 @MMRIZE
            Is there an option to hide the week numbers? I’ve managed to remove the ‘cw’ using custom.css (albeit a bit untidy)
              sdetweil @bicolorbore586
              @bicolorbore586 no config option, just set cw to display:none in custom.css
                almightyyoshi
                I finally found a touch module that I could easily use for the glance notification and have the payload step as 1. However, two things are happening:
                1: on the first press it’s going back to June. Second press goes to April. Third press goes to August. Fourth press goes to December (which would be correct, however, due to the other jumps it could just be random)
                2: no events are populating in the glance
                Here’s what I have for the button:
                      module: "MMM-TouchButton",
                          buttons: [
                                icon: "fa fa-calendar-days",
                                notification: "CX3_GLANCE_CALENDAR",
                                payload: {instanceID: [], step: [1]},
                And here’s my CX3 config:
                            module: "MMM-CalendarExt3",
                            position: "middle_center",
                                    mode: "month",
                                    instanceID: "currentMonth",
                                    firstDayOfWeek: 0,
                                    useSymbol: true,
                                    glanceTime: 60000,
                                    calendarSet: [],
                Any thoughts?
                  MMRIZE @almightyyoshi
                  @almightyyoshi
                  Not real tested, but I think your config should be like this;
                  payload: {step: 1},
                  And about no event populating, It would be related to your maximumEntries , maximumNumberOfDays and boradcastPastEvents options of default calendar module.
                    almightyyoshi @MMRIZE
                    @MMRIZE
                    That did it. Thanks!
                    • C Offline
                      chadjohn2
                      First off, I’m a complete and utter noob with coding. I’m capable enough to get MagicMirror installed and start adding in some of the 3rd party modules. I’m now trying to get into the space of modifying CSS and such for a little added customization.
                      I’m trying to something that I think should be simple but I cannot get it work for the life of me. I’ve searched the forum and this topic and found a couple pieces but I’m still struggling. Finally got frustrated enough to create an account and post.
                      I’m trying to change the color of events based on the title of an event coming from a google calendar. The events are coming in fine, just not changing color.
                      Based on what I have read, I need to use the eventTransformer function. I have put the following into the config.js file (including the full module for total information).
                      position: "bottom_bar",
                      			mode: "week",
                      			weekIndex: "0",
                      			weeksInView: "2",
                      			firstDayOfWeek: "1",
                      			maxEventLines: "8",
                      			fontSize: "25px",
                      			eventHeight: "16px"
                      eventTransformer: function(event) {
                      if (event.title.search('Daycare') > -1) {
                      event.className = 'Daycare'
                      then in the custom.css file (Trying hot pink hex so it pops out):
                      .CX3 .Daycare {
                      background-color:#FF69B4;
                      color:#FF69B4;
                      For all I know, that’s completely wrong so any help you can provide will be appreciated!
                      W M 2 Replies Last reply Reply Quote 0
                      • W Offline
                        Wenike @chadjohn2
                        @chadjohn2 Try removing the }, before your event transformer text (it closes that config section but you need the event transformer in that config section). Also, per the github, your code for the event transformer needs to be something like:
                        eventTransformer: (ev) => {
                          if (ev.title.search('Daycare') > -1) ev.color = '#FF69B4'
                          return ev
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 68
                        • 69
                        • 17 / 69
