    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 438.3k Views 28 Watching
    • L Offline
      Lepracon68
      I am also from the netherlands, and started my first RPI one week ago.
      I just finished configuring the MM to my likings (only half a day work).
      THANK YOU so much for making this project so easy !
      If Peter wants to get in contact with me , he can, maybey we can help eachother. (i am 49 years old, center Holland)
        Mykle1 Project Sponsor Module Developer @Peter
        @Peter said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
        Thanks to you and Michael Teeuw the MM is the best project for RPI I have ever seen.
        That is, without a doubt, the nicest and coolest thing anyone has ever said to me here. However, MT deserves all the credit.
        I just succeeded in adding a MMM (Earth)( happy me!).
        Things that do not work up till now: MM does not start automatically and I still have to find out how to combine two Calendars.
        	disabled: f,
        	module: 'calendar',
        	position: 'top_left',
        		urgency: 0,
        		getRelative: 0,
        		fadePoint: 0.25, // Start on 1/4th of the list.
        				symbol: 'calendar-check-o ',
        				url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
        				url: 'YOUR SECOND CALENDAR ICS FILE GOES HERE'
        Auto starting MM
        Follow these directions precisely
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        • P Offline
          Peter @Lepracon68
          @Lepracon68 that would be nice!
          Peter
          • P Offline
            Peter @Mykle1
            @Mykle1 Thanks for the Calendar; I will try that.
            Autostart: I followed the instructions several times, but it does not work.
            It will work one day …
            Isn’t this what makes a project so nice to work on: trying until the magic happens?
            Peter
              @Peter
              Pay particular attention to this line:
              PM2 will now show you a command you need to execute.
              Most people miss this step. You have to execute the command that appears.
              And lastly, you have to save the PM2 state
                Hello Lucy! (my granddaughter)
                And here are the modifications I’ve made in Lucy’s name so far.
                https://youtu.be/M9C0ppGFJik
                1 Reply Last reply Reply Quote 4
                • ChrisC Offline
                  Chris
                  Hello,
                  Superb work, as usual :)
                  Could you point me to how to put this system in place?
                  Having already installed the open-jarvis solution, I do not know if it would create a conflict or if I have to adapt your solution via jarvis voice recognition.
                  Thank you in advance, truthfully yours,
                  Mykle1M 2 Replies Last reply Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @Chris
                    @Chris
                    This is my own personal project at the moment. It involves many, many modifications to the MMM-voice module and any module that will be used in conjunction with it. I only just recently got it working to some satisfaction but I am still working on it. It’s going to take some time before I am done with it because I hope to add more features to it. I’ll keep you posted.
                    It may create a conflict for you and jarvis voice when all is said and done.
                    ChrisC 1 Reply Last reply Reply Quote 0
                    • ChrisC Offline
                      Chris @Mykle1
                      @Mykle1
                      Hello,
                      This seems very promising,
                      I would follow with great interest this project,
                      Good luck to you for the future,
                        @Chris said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                        Hi Chris,
                        I put together a repo with directions on how to use this system. I don’t know if you’re going to run into any problems with jarvis but this will work with any module you choose with some modifications on your part. It’s all in the directions.
                        https://github.com/mykle1/Hello-Lucy
                        And the most recent video with sound enhancement to the system
                        https://youtu.be/ZXWf7s3K3as
                        strawberry 3.141S ChrisC 2 Replies Last reply Reply Quote 0
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 19
                        • 20
                        • 12 / 20
