    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 478.9k Views 28 Watching
    • Mykle1M
      Cue the confetti. =:-)
      • Mykle1M
        Seems so quiet in here. :-)
        • cowboysdudeC
          There…better? LOL
          https://www.youtube.com/watch?v=thIVtEOtlWM
            Peter
            Mykle1, your project is an inspiration for this other old man (62) in the Netherlands.
            The RPI is running, old monitor is found, so I can start the project!
            It will take a lot of reading and searching!
            Peter
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Peter
              @Peter
              Hello from NYC, Peter!
              You can do it. It takes a little time and patience but it is a lot of fun and very rewarding. Let me know if I can help you
                Peter
                Thanks to you and Michael Teeuw the MM is the best project for RPI I have ever seen.
                I appreciate your interest and help.
                I just succeeded in adding a MMM (Earth)( happy me!).
                Things that do not work up till now: MM does not start automatically and I still have to find out how to combine two Calendars.
                Peter
                • L
                  Lepracon68
                  I am also from the netherlands, and started my first RPI one week ago.
                  I just finished configuring the MM to my likings (only half a day work).
                  THANK YOU so much for making this project so easy !
                  If Peter wants to get in contact with me , he can, maybey we can help eachother. (i am 49 years old, center Holland)
                  P 1 Reply Last reply
                  • Mykle1M
                    @Peter said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                    That is, without a doubt, the nicest and coolest thing anyone has ever said to me here. However, MT deserves all the credit.
                    	disabled: f,
                    	module: 'calendar',
                    	position: 'top_left',
                    		urgency: 0,
                    		getRelative: 0,
                    		fadePoint: 0.25, // Start on 1/4th of the list.
                    				symbol: 'calendar-check-o ',
                    				url: 'YOUR SECOND CALENDAR ICS FILE GOES HERE'
                    Auto starting MM
                    Follow these directions precisely
                    https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      Peter @Lepracon68
                      @Lepracon68 that would be nice!
                      Peter
                        Peter @Mykle1
                        @Mykle1 Thanks for the Calendar; I will try that.
                        Autostart: I followed the instructions several times, but it does not work.
                        It will work one day …
                        Isn’t this what makes a project so nice to work on: trying until the magic happens?
                        Peter
                        • Mykle1M
                          @Peter
                          Pay particular attention to this line:
                          PM2 will now show you a command you need to execute.
                          Most people miss this step. You have to execute the command that appears.
                          And lastly, you have to save the PM2 state
                          • Mykle1M
                            Hello Lucy! (my granddaughter)
                            And here are the modifications I’ve made in Lucy’s name so far.
                            https://youtu.be/M9C0ppGFJik
                            Reply Quote 4
                            • ChrisC
                              Chris
                              Superb work, as usual :)
                              Could you point me to how to put this system in place?
                              Having already installed the open-jarvis solution, I do not know if it would create a conflict or if I have to adapt your solution via jarvis voice recognition.
                              Thank you in advance, truthfully yours,
                              Mykle1M 2 Replies Last reply
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Chris
                                @Chris
                                This is my own personal project at the moment. It involves many, many modifications to the MMM-voice module and any module that will be used in conjunction with it. I only just recently got it working to some satisfaction but I am still working on it. It’s going to take some time before I am done with it because I hope to add more features to it. I’ll keep you posted.
                                It may create a conflict for you and jarvis voice when all is said and done.
                                ChrisC 1 Reply Last reply
                                • ChrisC
                                  Chris @Mykle1
                                  @Mykle1
                                  This seems very promising,
                                  I would follow with great interest this project,
                                  Good luck to you for the future,
                                  • Mykle1M
                                    @Chris said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                                    Hi Chris,
                                    I put together a repo with directions on how to use this system. I don’t know if you’re going to run into any problems with jarvis but this will work with any module you choose with some modifications on your part. It’s all in the directions.
                                    https://github.com/mykle1/Hello-Lucy
                                    And the most recent video with sound enhancement to the system
                                    https://youtu.be/ZXWf7s3K3as
                                    strawberry 3.141S ChrisC 2 Replies Last reply
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                      @Mykle1 looks good
                                      • ChrisC
                                        Chris @Mykle1
                                        @Mykle1
                                        Very good work,
                                        I will be happy to test it on PI sometime this week as soon as I have time and you will return,
                                        thank you very much
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                          @strawberry-3.141
                                          I don’t know about that, but it does work, even if it’s not done the proper way. I’m happy with it. It does what I want it to do and it works amazingly well on an old laptop.
                                          • Mykle1M
                                            thank you very much
                                            You’re welcome, mate. Let me know how it goes
                                            • 10
                                            • 6 / 10
