    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 463.9k Views 28 Watching
      Oh, it’s gonna happen
        Cue the confetti. =:-)
          Seems so quiet in here. :-)
          • cowboysdudeC Offline
            There…better? LOL
            https://www.youtube.com/watch?v=thIVtEOtlWM
              Peter
              Mykle1, your project is an inspiration for this other old man (62) in the Netherlands.
              The RPI is running, old monitor is found, so I can start the project!
              It will take a lot of reading and searching!
              Peter
                Mykle1 Project Sponsor Module Developer @Peter
                @Peter
                Hello from NYC, Peter!
                You can do it. It takes a little time and patience but it is a lot of fun and very rewarding. Let me know if I can help you
                  Peter
                  Thanks to you and Michael Teeuw the MM is the best project for RPI I have ever seen.
                  I appreciate your interest and help.
                  I just succeeded in adding a MMM (Earth)( happy me!).
                  Things that do not work up till now: MM does not start automatically and I still have to find out how to combine two Calendars.
                  Peter
                  • L Offline
                    Lepracon68
                    I am also from the netherlands, and started my first RPI one week ago.
                    I just finished configuring the MM to my likings (only half a day work).
                    THANK YOU so much for making this project so easy !
                    If Peter wants to get in contact with me , he can, maybey we can help eachother. (i am 49 years old, center Holland)
                      @Peter said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                      That is, without a doubt, the nicest and coolest thing anyone has ever said to me here. However, MT deserves all the credit.
                      	disabled: f,
                      	module: 'calendar',
                      	position: 'top_left',
                      		urgency: 0,
                      		getRelative: 0,
                      		fadePoint: 0.25, // Start on 1/4th of the list.
                      				symbol: 'calendar-check-o ',
                      				url: 'YOUR SECOND CALENDAR ICS FILE GOES HERE'
                      Auto starting MM
                      Follow these directions precisely
                      https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                        Peter @Lepracon68
                        @Lepracon68 that would be nice!
                        Peter
                          Peter @Mykle1
                          @Mykle1 Thanks for the Calendar; I will try that.
                          Autostart: I followed the instructions several times, but it does not work.
                          It will work one day …
                          Isn’t this what makes a project so nice to work on: trying until the magic happens?
                          Peter
                            @Peter
                            Pay particular attention to this line:
                            PM2 will now show you a command you need to execute.
                            Most people miss this step. You have to execute the command that appears.
                            And lastly, you have to save the PM2 state
                              Hello Lucy! (my granddaughter)
                              And here are the modifications I’ve made in Lucy’s name so far.
                              https://youtu.be/M9C0ppGFJik
                              1 Reply Last reply Reply Quote 4
                              • ChrisC Offline
                                Chris
                                Superb work, as usual :)
                                Could you point me to how to put this system in place?
                                Having already installed the open-jarvis solution, I do not know if it would create a conflict or if I have to adapt your solution via jarvis voice recognition.
                                Thank you in advance, truthfully yours,
                                  Mykle1 Project Sponsor Module Developer @Chris
                                  @Chris
                                  This is my own personal project at the moment. It involves many, many modifications to the MMM-voice module and any module that will be used in conjunction with it. I only just recently got it working to some satisfaction but I am still working on it. It’s going to take some time before I am done with it because I hope to add more features to it. I’ll keep you posted.
                                  It may create a conflict for you and jarvis voice when all is said and done.
                                  ChrisC 1 Reply Last reply Reply Quote 0
                                  • ChrisC Offline
                                    Chris @Mykle1
                                    @Mykle1
                                    This seems very promising,
                                    I would follow with great interest this project,
                                    Good luck to you for the future,
                                      @Chris said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                                      Hi Chris,
                                      I put together a repo with directions on how to use this system. I don’t know if you’re going to run into any problems with jarvis but this will work with any module you choose with some modifications on your part. It’s all in the directions.
                                      https://github.com/mykle1/Hello-Lucy
                                      And the most recent video with sound enhancement to the system
                                      https://youtu.be/ZXWf7s3K3as
                                      strawberry 3.141S ChrisC 2 Replies Last reply Reply Quote 0
                                      • strawberry 3.141S Offline
                                        strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                        @Mykle1 looks good
                                        • ChrisC Offline
                                          Chris @Mykle1
                                          @Mykle1
                                          Very good work,
                                          I will be happy to test it on PI sometime this week as soon as I have time and you will return,
                                          thank you very much
                                            Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                            @strawberry-3.141
                                            I don’t know about that, but it does work, even if it’s not done the proper way. I’m happy with it. It does what I want it to do and it works amazingly well on an old laptop.
                                            • 10
                                            • 6 / 10
