    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 420.4k Views 32 Watching
    • H Offline
      hogedir @BKeyport
      @BKeyport I don’t understand how to extend the full day event like you. mine is limited and i have some space available like that
      I want to extend totally the text for fullday event and not having these 3 points “…”
      BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @hogedir
        @hogedir It’s documented in my CSS above… Look closely you’ll find it. “fullday events overflow” is a clue.
        • W Offline
          Wenike @BKeyport
          @BKeyport I appreciate you posting your CSS, it gave me a good base to tweak to make my layout work for me (especially getting each event in the calendar’s color but still dimming when that event is in the past.
            MMRIZE
            Nobody like my default color settings? :(
            BKeyportB W 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @MMRIZE
              @MMRIZE I did, when I was on a dark background. Then I decided I wanted to go with color to tell events apart, so css work it was.
              • W Offline
                Wenike @MMRIZE
                @MMRIZE I did! Except I have like 6 calendars defined and I’ve long been used to telling them apart by color on my Google calendar.
                • luisestradaL Offline
                  luisestrada @hogedir
                  @hogedir
                  I edited the max-width value (50% to 100%) in .CX3A .cellBody .fullday .event and solved the issue
                  • H Offline
                    hogedir @MMRIZE
                    @MMRIZE how do you change the baseball icon please? which one are available to put?
                    • BKeyportB Offline
                      @hogedir icons are changed at the calendar level by adding symbol: <some symbol> to each calendar in the calendar module.
                      https://fontawesome.com/v5/search is where you can look up icons to use. The system can’t use pro icons.
                      	url: "http://cal.events/VReW45.ics",
                      	symbol: "football-ball",
                      is https://fontawesome.com/v5/icons/football-ball?s=solid&f=classic
                      • BKeyportB BKeyport referenced this topic on
                      • H Offline
                        hogedir @BKeyport
                        @BKeyport I searched how to Hide the list of events diary and the AGENDA calendar with all the month with days because I just want to show the 3rd part of the module with all the events.
                        like this : hiding the cross part and the other part with events :
                        S BKeyportB 2 Replies Last reply Reply Quote 0
                          sdetweil @hogedir
                          @hogedir please see this post
                          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1664733698317
                          about using the developers window (ctrl-shift-i) to examine the web page and find the element u want to address
                          this content goes into ~.MagicMirror/css/custom.css
                          .MMM-CalendarExt3Agenda  .?????? {
                                display:none;
                          where ??? is the classname of the month view
                          • BKeyportB Offline
                            @hogedir hiding the minical is simple: showMiniMonthCalendar: false, in your config. I suggest you read the README.md - it’s all documented.
                            Everything other than config options is CSS - Feel free to give ideas, and @mmrize and I can help you work it out.
                            • BKeyportB Offline
                              BKeyport Module Developer @BKeyport
                              hey, @MMRIZE - I can’t figure out how to do something.
                              One of my remotely generated events has taken to advertising in it’s title.
                              (Washington Football vs Arizona - blah blah special event, Presented by Idiot Company)
                              I want to get rid of everything after the dash. Not sure how to word the transform to do it - can you explain?
                              Thanks.
                                DDE12
                                How do I change the order of information events from
                                ___________________________________________________________
                                1:30 PM - 2:30 PM Event Name ________________________
                                to
                                Event Name ________________________1:30 PM - 2:30 PM
                                • BKeyportB Offline
                                  BKeyport Module Developer @DDE12
                                  @DDE12 refer back to https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/24?_=1668752794543
                                  The combo of my work and @MMRIZE 's work results in that. Right around there is where I got all of my settings for my install. Feel free to experiment.
                                  • C Offline
                                    cyberphox
                                    Running MagicMirror in Docker on Synology.
                                    Installed this module and it looks great on my MacBook, but when I try to visit on my mirror with Raspberry Pi 3, the module doesn’t show (just default calendar module). Get a Syntax error, unexpected token.
                                    So weird.
                                      sdetweil @cyberphox
                                      @cyberphox what version of MM are you running, and on pi, what version of OS and what browser?
                                      these modules, like many newer ones, are converting to javascript ES6 idioms that don’t work on older node versions (built into browsers as well)
                                      • C Offline
                                        cyberphox @sdetweil
                                        Chromium 72.0.3626.121
                                        Raspbian Stretch
                                        MagicMirror: v2.21.0
                                          sdetweil @cyberphox
                                          @cyberphox how about node -v
                                          stretch is really old… so probably a downlevel version of javascript…
                                          • C Offline
                                            cyberphox @sdetweil
                                            No doubt…not a huge issue as it was test install…Thanks for the help!
                                            • 11
                                            • 12
                                            • 3 / 12
