    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 420.4k Views 32 Watching
    • luisestradaL Offline
      luisestrada @MMRIZE
      @MMRIZE I changed the module weatherProvider to “openweathermap”, for the type “forecast” and now it works.
      I kept “envcanada” for the type “current”, though.
      • BKeyportB Offline
        BKeyport Module Developer @luisestrada
        @luisestrada said in MMM-CalendarExt3Agenda:
        Show the days only which has event on the day.
        .CX3A .agenda .cell[data-events-counts=“0”] {
        display: none;
        Perfect. Thank you.
          MMRIZE @luisestrada
          @luisestrada
          Hmmm. maybe the Locale issue. Could you send me your whole configuration(But to make things simple, drop out all other modules except MMM-CX3 and Weather(envCanada)) (eouia0819@gmail.com)
          By the way, What’s the Tesla module?
          BKeyportB luisestradaL 2 Replies Last reply Reply Quote 0
          • BKeyportB Offline
            BKeyport Module Developer @MMRIZE
            @MMRIZE I’m not quite sure how to do this -
            I want to filter one calendar source only. This source is the schedule of an entire league, and I only want to include the “Seattle” Team. Can you help me with the filter code so I can do so?
            Thanks!
              MMRIZE @BKeyport
              @BKeyport
              How can you distinguish? The target team name is included in the title of the event?
              • BKeyportB Offline
                @MMRIZE 🏈 in the title for the one I want, and/or calendar name is “XFL”
                  sdetweil @BKeyport
                  @BKeyport
                  eventFilter: (ev) => {
                  	if (ev.title.search('XFL') > -1) {Set color, whatever; }
                  	return true
                  • BKeyportB Offline
                    @sdetweil XFL isn’t in the title - just the calendar name.
                      sdetweil @BKeyport
                      @BKeyport said in MMM-CalendarExt3Agenda:
                      which is it,?
                      • BKeyportB Offline
                        @sdetweil finish reading my statement. What’s unique abou that calendar is two things:
                        1. In the title, the football emoji. (stripped by a transform)
                        2. The calendar name is “XFL”
                          MMRIZE @BKeyport
                          @BKeyport
                          You may use “calendarSet: [ … ]” in configuration to allow specific calendars only.
                          Or you can use “calendarName” property in the transformer function.
                            luisestrada @MMRIZE
                            @MMRIZE Sorry I could not reply sooner.
                            The Tesla module is the module below
                            MMM-TeslaLogger https://github.com/spitzlbergerj/MMM-TeslaLogger
                            I use Teslamate to extract the data from the car.
                            I will send you my calendar code to your email.
                            I also realized the last event (Saturday, Feb 18, in my screenshot) shows in my calendar but not in the agenda, If I take less days it does not show the last event. I did not see the issue when the last day was the 23rd, probably because the event started on the 22nd.
                              MMRIZE
                              1.2.0 (2023-04-25)
                              • ADDED: weatherNotification, eventNotification - To get data from 3rd party module which is not compatible with default modules.
                              • ADDED: weatherPayload, eventPayload - To manipulate or to convert received payload itself on time. (e.g. Convert Celcius unit to Fahrenheit unit)
                              • ADDED: Hiding day cell which has no event : onlyEventDays: n
                              • CHANGED : Display whole month events in miniCalendar regardless of agenda showing (despite endDayIndex or onlyEventDays)
                              • CHANGED: Shared library to fix many issues.
                              • CHANGED: Timing of eventFilter and eventTransformer is delayed for better-handling event data after regularized
                              • FIXED : Pooling events with multi-calendar modules’ notification
                              • FIXED: position issue (I hope so…)
                              • FIXED: some typo.
                              • FIXED: flickering for many reasons (logic error to treat notifications)
                              sc
                              • BKeyportB Offline
                                @MMRIZE
                                Broke: My install… Nothing is coming up. I’ve attempted removing my custom CSS, which doesn’t help, so I’m figuring it’s something in my config. Here’s one of the 3 instances.
                                Nothing showing up in the logs, which are set for info, log, warn, error, and debug.
                                			module: "MMM-CalendarExt3Agenda", // https://github.com/MMRIZE/MMM-CalendarExt3Agenda
                                				instanceId: "1",
                                				showMiniMonthCalendar: false,
                                				firstDayOfWeek: 0,
                                				startDayIndex: 0,
                                				endDayIndex: 99,
                                				minimalDaysOfNewYear: 1,
                                				animationSpeed: 0,
                                				useSymbol: false,
                                				useWeather: false,
                                				calendarSet: ["Main", "Utility"],
                                				eventTransformer: (ev) => {
                                					if (ev.title.search("⚾") > -1) {
                                						ev.title = ev.title.replace("⚾️ ","");
                                					if (ev.title.search("Bowling") > -1) {
                                						ev.color = 'yellow';
                                					if (ev.title.search("🏈") > -1) {
                                						ev.title = ev.title.replace("🏈 ","");
                                					return ev
                                  sdetweil @BKeyport
                                  @BKeyport its all in the browser, so open the developers window, console tab
                                  put ext3 in the filter field
                                  • BKeyportB Offline
                                    @sdetweil You really think I forgot to check that?
                                    I did forget to look at the console, though:
                                      sdetweil
                                      no idea that the ‘not prepared yet’ means
                                      • BKeyportB Offline
                                        @sdetweil Same. I figure there’s an option somewhere that’s preventing me from loading it fully. I’m sure @MMRIZE will have it fixed right away.
                                          MMRIZE @BKeyport
                                          @BKeyport
                                          I refactored all the duplicated logics in these modules and separate it with sub module named ‘CX3_Shared’.
                                          That message happens when that submodule is not loaded(with certain reason). Most suspicious thing would be that submodule is not installed properly. Could you check it again?
                                          https://github.com/MMRIZE/MMM-CalendarExt3Agenda#update-to-120
                                          • N Named54 referenced this topic on
                                          • BKeyportB Offline
                                            @MMRIZE Oh, doh! you gave in and had to install a dependancy/submodule! 🤣🤣🤣
                                            Missed that.
                                            • 6
                                            • 7
                                            • 11
                                            • 12
                                            • 5 / 12
