    PIR sensor to turn on LED strip
    35 Posts 6 Posters 14.4k Views 6 Watching
    • E Offline
      Egnos @sdetweil
      @sdetweil said in PIR sensor to turn on LED strip:
      u don’t need the GPIO_Notifications module. as the PIR modules send the USER_PRESENCE notification:
      The module I use for sending notifications when the PIR detects motion is MMM-GPIO-Notifications
      I believe he is sending the “USER_PRESENCE” notification:
      notifications: [
                    notification: 'USER_PRESENCE',
                    payload: true
      Thanks for your patience @sdetweil ! ;-)
        sdetweil @Egnos
        @Egnos ok got it.
        what I was saying is that the
        MMM-PIR-???
        modules, if you use them, THEY send the USER_PRESENCE notification
        the GPIO_Notifcations module is more generic and can send notifications for ANY gpio device
        • E Offline
          Egnos @sdetweil
          @Egnos ok got it.
          MMM-PIR-???
          Ok ok, I just wanted to be sure that, in my case, the MMM-GPIO-Notifications module sends the “USER_PRESENCE” notification.
          I knew that the module I am using is a collector of GPIO devices…
          Thanks @sdetweil
          • O Offline
            OberfragGER @Egnos
            @Egnos Just in case…
            Im using ioBroker @home (thats a free Smart Home Software). WIth that i also have installed MQTT. Any other Smart Home software like Home Assist can do the same.
            I also installed Hyperion on the same Raspyberry i have installed MagicMirror. Inside ioBroker iam using the Hyperion adapter.
            So with any “user_presence” i get the MQTT informartion… and that triggers a scipt inside ioBroker to activate Hyperion.
            If your using any smart home software as well… this should be an easy thing. Feel free to ask…
            • E Offline
              Egnos @OberfragGER
              @OberfragGER thanks for the valuable advice and for your availability, now I’ll read something.
              In the meantime, can you tell me an LED strip (not necessarily RGB …) that is compatible with this project?
              Thank you all.
              • O Offline
                OberfragGER @Egnos
                @Egnos I have to add… i use also the Module https://github.com/olexs/MMM-UserPresenceToMQTT
                For the LED-Strip… i use a WS2812. Its adessable an u can use it with 5V and it preconfigured in Hyperion.
                • E Offline
                  Egnos
                  @OberfragGER said in PIR sensor to turn on LED strip:
                  Where did you buy the LED strip? They seem very expensive …
                  I have seen the connection between RPI and LED strip but I do not understand why the external 5V power supply must also be connected to the RPI, is it not enough to connect it to the LED strip?
                  If I really have to connect the power supply to the RPI as well, how do you do if you have both PINs of the 5V GPIO occupied?
                  • E Offline
                    Egnos @Egnos
                    I found these https://a.aliexpress.com/_EwF3KTV.
                    The WS2813 strip is 5V.
                    Can be fine?
                    • bheplerB Offline
                      bhepler Module Developer @Egnos
                      @Egnos - Those look like they’ll do the job.
                      The reason is that the output of the RPi can drive a handful of LEDs, but the Pi only has so much power flowing through it (specs say 50mA). Powering the LEDs separately will let the Pi handle the logic and the power supply handle the… well, power.
                      • E Offline
                        Egnos @bhepler
                        @bhepler said in PIR sensor to turn on LED strip:
                        Thanks @bhepler I understood that the LEDs must be powered by an external 5V because the RPI generates a few mA and is not able to turn on an LED strip, but from the photo you can see that the external 5V (+ and -) also goes in parallel on the 5V in exit from the RPI.
                        For what reason?
                        Is this connection necessary (I no longer have 5V available on GPIO …)?
                        Thank you very much
                        wishmaster270W S 2 Replies Last reply Reply Quote 0
                        • wishmaster270W Offline
                          wishmaster270 Module Developer @Egnos
                          @Egnos Hi, as the picture says they use the 5V power source of the led strip to power the Pi, too.
                          Instead of powering the pi via USB they use the 5V GPIO pin.
                          If you want to power the Pi via USB instead be sure to connect the Ground of the strip with ground of the pi.
                            sdetweil @Egnos
                            @Egnos no. they are powering the pi from the 5v gpio pins as well as the LEDs.
                            the pin is tall.
                            • E Offline
                              Egnos @wishmaster270
                              @wishmaster270 said in PIR sensor to turn on LED strip:
                              The GPIO ground or the power ground going into USB-C?
                              thanks
                                sdetweil @Egnos
                                @Egnos gpio
                                • E Offline
                                  Egnos @sdetweil
                                  @sdetweil thanks
