    Bad question
    64 Posts 5 Posters 70.0k Views 4 Watching
    • F Offline
      Fonfon
      I start my project for magic mirror but i have a question
      witch os must be installed before ? raspian ?
      You say that : Want to install MagicMirror² on your freshly installed Raspbery Pi? Just run the following bash command:
      Thanks…
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Yes Raspian would be the choice :)
        Install Raspian then “Want to install MagicMirror² on your freshly installed Raspbery Pi? Just run the following bash command:”…
        • F Offline
          Fonfon
          ok perfect i try it now
          thanks cowboysdude ;)
          cowboysdudeC 1 Reply Last reply Reply Quote 1
            cowboysdude Module Developer @Fonfon
            @Fonfon You are most welcome!
            • F Offline
              Fonfon
              HI !!
              Is it important to adjust sreen resolution on the raspbian ?
              or the bash script do it ?
                I’m not sure. I have never changed mine.
                • F Offline
                  Fonfon
                  OK THANKS so another question !
                  how you manage your pie when it is in the mirror ??
                  thanks ;)
                    Mykle1 Project Sponsor Module Developer @Fonfon
                    @Fonfon said in Bad question:
                    This is how I do/did it:
                    Go to your Pi Application Menu, scroll down to Preferences, scroll down to Raspberry Pi Configuration. In the window that opens click the Interfaces button. Enable VNC. Click OK. Your done with the Pi.
                    On the computer that you want to manage your Pi from, go to https://www.realvnc.com/download/viewer/windows/ (In this case it’s for Windows. Choose your platform). Download VNC Viewer. This will allow you to remotely administer your Pi, and your MM, without having to take your mirror down or bring a mouse and keyboard to your mirror. I was doing that for a while until I learned this.
                    There might be other ways but this is the way I do it.
                    Peace
                    • F Offline
                      Fonfon
                      Thanks very much Mykle1 for your answering.!!
                      good way !
                        @Fonfon - You’re welcome. Peace. :peace:
                        • F Offline
                          Fonfon
                          Ok work great !!
                          Now new questions how it’s possible to traduce module in french for french mirror of course ?
                          thanks
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @Fonfon
                            @Fonfon you can set your language in the config file, if the modules have french translations they will be displayed in french. If they don’t have translation you can either add them and create a pull request on github or send the author the translations, so he can add them.
                            • F Offline
                              Fonfon
                              ok ok i understand thanks strawberry-3-141
                              • F Offline
                                Fonfon
                                Help me please
                                 ERR! Linux 4.4.34-v7+
                                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                npm ERR! node v6.9.5
                                npm ERR! npm  v3.10.10
                                npm ERR! path /home/pi/package.json
                                npm ERR! code ENOENT
                                npm ERR! errno -2
                                npm ERR! syscall open
                                npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                npm ERR! enoent This is most likely not a problem with npm itself
                                npm ERR! enoent and is related to npm not being able to find a file.
                                npm ERR! enoent
                                npm ERR!     /home/pi/npm-debug.log
                                  @Fonfon you are in the wrong directory cd ~/MagicMirror
                                  • F Offline
                                    Fonfon
                                    for sure i’m so confuse !
                                    • F Offline
                                      Fonfon
                                      Another one !! ;)
                                      WARNING! Could not find config file. Please create one. Starting with default configuration.
                                      why he say that ?
                                      thanks
                                        @Fonfon
                                        Your config was working and now it’s not? If you just added something to a working config then that’s probably the culprit. Post your config here so we can have a look at it
                                        • F Offline
                                          Fonfon
                                          /* Magic Mirror Config Sample
                                          • By Michael Teeuw http://michaelteeuw.nl
                                          • MIT Licensed.
                                          var config = {
                                          port: 8080,
                                          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.1.1/24”],
                                          language: 'fr',
                                          timeFormat: 24,
                                          units: 'metric',
                                          		module: 'alert',
                                          		module: "updatenotification",
                                          		position: "top_bar"
                                          		module: 'calendar',
                                          		header: 'US Holidays',
                                          		position: 'top_left',
                                          					symbol: 'calendar-check-o ',
                                          					url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                                          		module: 'compliments',
                                          		position: 'lower_third'
                                          		module: 'currentweather',
                                          		position: 'top_right',
                                          			locationID: '',  //ID from http://www.openweathermap.org
                                          			appid: 'YOUR_OPENWEATHER_API_KEY'
                                          		module: 'weatherforecast',
                                          		header: 'Weather Forecast',
                                          			locationID: '5128581',  //ID from http://www.openweathermap.org
                                          		module: 'newsfeed',
                                          		position: 'bottom_bar',
                                          			feeds: [
                                          					title: "New York Times",
                                          			showSourceTitle: true,
                                          			showPublishDate: true
                                          if (typeof module !== ‘undefined’) {module.exports = config;}
                                          Mykle1M 2 Replies Last reply Reply Quote 0
                                            This post is deleted!
                                            • 1 / 4
