    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 25.0k Views 7 Watching
    • V
      Volkae
      My MM works fine but I have a problem using MMM-PIR-Sensor-Lite. The modul is running, the countdown is shown on the MM but when the countdown shows 0 it does not switch HDMI off so the monitor is still alive.
      What can I do??
        sdetweil @Volkae
        @Volkae this module requires python3, which is not installed by default… and not listed in the requirements
        • V
          Volkae @sdetweil
          Python3 was already installed (up to date).
          Module seems to work fine but does not switch HDMI off…
            sdetweil @Volkae
            @Volkae so have u tried the command it uses, on the terminal window
            from the code
            /usr/bin/vcgencmd display_power 0
            make sure to do this over ssh, so you can turn it back on
            /usr/bin/vcgencmd display_power 1
            • V
              Volkae @sdetweil
              then it shows me:
              display_power=1
              HDMI is still alive…
                sdetweil @Volkae
                @Volkae those two were off and on
                if you do off
                does it turn off?
                • V
                  Volkae @sdetweil
                  No, it does not switch HDMI off
                    sdetweil @Volkae
                    @Volkae works perfectly on my pi 4…
                    what pi version are you using?
                    • V
                      Volkae @sdetweil
                      I´m using a pi3.
                      Maybe that´s the problem??
                        sdetweil @Volkae
                        @Volkae worked on my pi3 as well…
                        • J
                          JoeFranz @sdetweil
                          @sdetweil same here https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi?page=1
                            sdetweil @JoeFranz
                            @JoeFranz @Volkae this appears to be a problem related to the raspi os kernel level
                            https://forums.raspberrypi.com/viewtopic.php?t=339079
                            • J
                              JoeFranz @sdetweil
                              Thanks @sdetweil for the link :-)
                              It is probably due to the current firmware 5.15
                              With
                              rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                              I installed version 5.10. It now works again with the standby on the HDMI connection.
                              Greetings Joerg
                              • B
                                blouzbee
                                all these modules and all these guides you can find online all fail to tell you that at some point a kernel or driver update broke vcgencmd and tvservice commands for the newer pis or Rasberry OS. I spent so many hours making mine work.
                                xrandr --output HDMI-1 --off
                                xrandr --output HDMI-1 --auto
                                these worked for me, maybe they’ll work for you, I dunno.
                                  sdetweil @blouzbee
                                  @blouzbee cool…
                                  yeh tvservice went away in bullseye
                                  they are trying to get rid of all the old ‘raspberry pi’ unique stuff to maintain
                                  • V
                                    Volkae @sdetweil
                                    Seems that there is no way for me to swich off HDMI via PIR-Sensor :-(
                                    Maybe I will find a way to do this with a python-Scrip out of MagicMirror but I´m a just a beginner and it seems to be not easy…
                                      sdetweil @Volkae
                                      @Volkae did u see @JoeFranz post about changing the OS firmware down a couple levels?
                                      https://forum.magicmirror.builders/topic/17202/mmm-pir-sensor-lite-does-not-switch-hdmi-off/13?_=1662126560261
                                      • V
                                        Volkae @sdetweil
                                        I will try to downgrade
                                        • G
                                          grena Module Developer
                                          Hello all,
                                          I think I have restored the compatibility of MMM-PIR-Sensor-Lite with Bullseye (lastest firmware). See issue on GitHub and more information in ReadMe
                                          Can you install the testing version to confirm the resolution of this issue?
                                          cd ~/MagicMirror/modules/MMM-PIR-Sensor-Lite
                                          git pull
                                          git checkout testing
                                          Thanks for your feedback!
                                          • G grena referenced this topic on
                                          • V
                                            Volkae @grena
                                            @grena
                                            Hey grena,
                                            seems to work fine on my Raspi 3!!!
                                            Thank you, great support!!!
                                            V 1 Reply Last reply Reply Quote 1
                                            • 1 / 3
