    absolute date in calendar module
    19 Posts 9 Posters 16.4k Views 9 Watching
    • Q Offline
      qqqqqqqq
      I want the calendar to display the exact day of the event(birthdays), instead of saying “in 3 days” or “The day after tomorrow” since it takes up too much of space.
      I tried changing it in the main config file & the calendar.js file (both), but no change is reflected.
      strawberry 3.141S P 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
        @qqqqqqqq can you post your config?
        • Q Offline
          qqqqqqqq
          Here is my main config file
          			module: 'calendar',
          			header: 'Your Calendar',
          			position: 'top_left',
          				timeformat: 'absolute',
          						symbol: 'calendar-check-o ',
          						url: 'webcal://calendar.google.com/calendar/ical/....ics'
          						symbol: 'facebook-official ',
          						url: 'webcal://localhost:8080/modules/Cals/FbBirthday.ics'
          						symbol: 'calendar ',
          						url: 'webcal://calendar.google.com/c.....ics'
          			module: 'compliments',
            broberg Project Sponsor
            You should also set urgency to 0
            • Y Offline
              yawns Moderator
              Please try to write timeFormat instead of timeformat, this is case sensitive :)
              Also try to play around with urgency
              https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar
              • Q Offline
                qqqqqqqq
                Okay, made both the changes, fixed the case in “timeFormat” and added
                urgency: '0',
                right next to the timeFormat tag.
                But, now the events appear like this
                event 1 The day after tomorrow
                event 2 Feb 19th
                event 3 Feb 21st
                Still need to fix event 1
                • Y Offline
                  yawns Moderator
                  Please replace '0' with 0
                  Numbers should not be written with quotation marks
                  • Q Offline
                    qqqqqqqq
                    Nope, still the same.
                    Btw, i should let you know that I am start the MagicMirror by using the command
                    npm start
                    Should I be using some other method to start it? Do I need to clear cache or something like that? :slight_frown:
                    • Y Offline
                      yawns Moderator @qqqqqqqq
                      @qqqqqqqq
                      Starting your mirror for testing purpose is just fine.
                      Please try this:
                      		timeFormat: 'absolute',
                      		urgency: 0,
                      		getRelative: 0,
                      • Q Offline
                        qqqqqqqq
                        I’ve updated the values in both, the main config file & the calendar.js (in the modules folder) but it’s still the same.
                        Here is the image. http://pasteboard.co/z6KcmVgLB.jpg
                          @qqqqqqqq with the current implementation this is the expected behaviour
                          } else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) {
                            if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") {
                              timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW"));
                            } else {
                              timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
                          it will be always relative
                          EDIT: this is only for fullday events
                          Q 1 Reply Last reply Reply Quote 1
                          • Y Offline
                            yawns Moderator
                            I tested it yesterday and my calendar showed “tomorrow at 15:30” and “Saturday at 14:00”
                            That is as absolute as it gets, imho
                            • Q Offline
                              qqqqqqqq @strawberry 3.141
                              @strawberry-3.141
                              Most of my events are Fullday events. So, yeah.
                              Right now, I guess it gets relative for next 3/4 days, and absolute thereafter.
                              • W Offline
                                wered
                                I was running into the same issue with not being able to disable the relative days, My issue was that when something was set to “The day after tomorrow” it made the module far to wide and overwrote other modules(Im using an older low res screen). To fix this I edited the file at MagicMirror/modules/default/calendar/calendar.js and replaced line 237 with the entry below, I changed it to two days which is much shorter but you can change it to whatever you want.
                                timeWrapper.innerHTML = this.capFirst(this.translate(“Two Days”));
                                The line originally was.
                                timeWrapper.innerHTML = this.capFirst(this.translate(“DAYAFTERTOMORROW”));
                                  MarkNygaard
                                  Is it a big task to change so that it displays weekdays for the current week and then dates when the event is further away?
                                  So lets say it is Wednesday. The calendar would then display it like:
                                  Event Today
                                  Event Thursday
                                  Event Saturday
                                  Event Sunday
                                  Event Oct 9
                                  Event Oct 11
                                  Edit: Can see that the urgency option takes x amount of days. Would be nice if the urgency function returns the days(Monday, Tuesday…) in stead of the amount of days away.
                                  • Alex2020A Offline
                                    Alex2020
                                    E’ possibile impostare un simbolo diverso da un altro a secondo dell’evento?In caso la risposta fosse SI potreste dirmi come dovrei fare ?Grazie.
                                    english
                                    Is it possible to set a different symbol from another according to the event? If the answer was YES could you tell me how I should do it? Thanks.
                                    • Alex2020A Offline
                                      Alex2020
                                      Come si fa a mettere un simbolo diverso per ogni giorno della settimana?Grazie.
                                      english
                                      How do you put a different symbol for each day of the week? Thanks.
                                      • P Offline
                                        pablo_z @qqqqqqqq
                                        @qqqqqqqq
                                        You must use:
                                        timeFormat: ‘absolute’,
                                        getRelative: 0,
                                        urgency: 0,
                                        in the config.js
                                        uros76U 1 Reply Last reply Reply Quote 0
                                        • uros76U Offline
                                          uros76 @pablo_z
                                          @pablo_z said in absolute date in calendar module:
                                          @qqqqqqqq
                                          You must use:
                                          getRelative: 0,
                                          urgency: 0,
                                          in the config.js
                                          I wanted the same, to have just dates of events shown. This helped me, thanks.
                                          My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
