    Changing Module Display Width
    24 Posts 6 Posters 23.7k Views 6 Watching
      selym
      Hi all-
      I found a “today in history” type news feed, but the entries are a tad longer than what is displaying. How would I adjust the viewing area for a module? FYI, not a coder/developer/programmer…just a DIY hobbyist that thought this looked like something fun to try. Thanks!
      • brobergB Offline
        broberg Project Sponsor @selym
        @selym
        in the custom.css
        add
        .MMM-modulename {
            width : 200px;
        Be shure to get the module name exactly right (case sensitive and all).
        Do experiment with the width, 200px might be to small, it’s just an example to get you started.
        johnnyboyJ 1 Reply Last reply Reply Quote 2
        • johnnyboyJ Offline
          johnnyboy @broberg
          @broberg
          … so this will work for any module? Such as clock, calendar etc? Will this keep aspect, or is there another addition for height?
          Im not sure how custom css actually works, so excuse if this sounds dumb… but when entering the code in there do i jist hit save and thats it? Is a reboot needed before the alteration shows?
          , before or after… just exactly as you put it here?
          Tvmia
          • cowboysdudeC Offline
            cowboysdude Module Developer
            If it’s the one I made then it’s this:
            In the config.js it’s a config option:
                module: 'MMM-History',
                position: 'top_right',
            	 maxWidth: "325px"
            johnnyboyJ S 2 Replies Last reply Reply Quote 1
              johnnyboy @cowboysdude
              @cowboysdude
              Perfect thanks
              cowboysdudeC 1 Reply Last reply Reply Quote 1
                cowboysdude Module Developer @johnnyboy
                @johnnyboy said in Changing Module Display Width:
                @cowboysdude
                Perfect thanks
                You’re welcome!
                You can also do this:
                	 maxWidth: "33%"
                johnnyboyJ 1 Reply Last reply Reply Quote 1
                • brobergB Offline
                  broberg Project Sponsor @johnnyboy
                  @johnnyboy It will change the height/width of the module “container”, it will not affect the size of objects, images or fonts. Normally the module “container” will adapt to the size of it’s content. but with the width/height specified you force it to be a set width/height.
                    johnnyboy @broberg
                    @broberg
                    Ahhhhhhhhh… Gotcha ;-)… reduce the % of the container also reduces it’s contents in relation. Thanks.
                    brobergB 1 Reply Last reply Reply Quote 1
                    • brobergB Offline
                      @johnnyboy well, not entirely, the content (text etc.) don’t change in size, all you do is changing the surface that the content can take up.
                      like moving from a big garage to a small, you still have the same amount of stuff but less area to put it in, so the stuff that doesn’t fit spills over and out on to the yard.
                        johnnyboy @broberg
                        @broberg
                        Oh, ok… Well I will play about with it anyway just to see what that does to it… just so I will know for experience as its another learning curve i’ve learned
                        • brobergB Offline
                          @johnnyboy You can do a lot to the Magicmirror and it’s module just by editing the css,
                          Here is a good reference for CSS : https://www.w3schools.com/css/
                          And css for beginners : http://www.htmldog.com/guides/css/beginner/
                            @cowboysdude said in Changing Module Display Width:
                            	 maxWidth: "33%"
                            Oooooo MM didn’t like that :-) So I musta entered something wrong or didn’t enter something I should have? Can you please guide me to what part I did wrong here?
                                module: 'MMM-WunderGround',
                                position: 'top_left',
                            	 maxWidth: "33%"
                            apikey: 'pws: mydetailshere',
                            hourly: '1',
                            fctext: '1'
                            • brobergB Offline
                              @johnnyboy maxWidth isn’t specified for the WunderGround module. So you can’t use the same config option there as you could with MMM-History.
                              Confusing I know, but most modules don’t use size settings in the config since it’s better to set that with css code.
                              Custom css-code is put in the file custom.css that can be found in the css folder.
                                johnnyboy @broberg
                                @broberg
                                Ah, ok… I was jumping ahead of myself there… so I will try
                                .MMM-WunderGround {
                                    width : 200px;
                                200px; or whatever looks good.
                                Thanks again.
                                  johnnyboy @johnnyboy
                                  I changed mines to 250px as that was about maxed out or else it would move the large Moon icon onto top bar and would become 1/3 of its original size and not look right, or look good… so I’m pretty happy at that.
                                  However, I thought to do the same thing to the calendar that’s directly opposite, on the top right…to keep the aspect look… Nope! It wont budge for some reason?
                                  Side effect now is a slight 5 - 7 second load time to WunderGround, Calendar, and News feed on bottom bar… No idea if this is linked or no?No effect at all on Compliments or SimpleLogo.
                                  .Module_calendar {
                                  width : 250px;
                                  No idea if this is relevant, but should I have included the calendar header Uk Holidays? My calendar is also linked to Google Calendar so no idea if that could be a reason either why it wont allow width to be adjusted, but thought to mention
                                  • brobergB Offline
                                    @johnnyboy I think it should be just .calendar not .Module_calendar
                                      johnnyboy @broberg
                                      @broberg
                                      ok will try that now… Yes that did it… I didn’t know not to include .Module there… Thought they all had the same command, apart from MMM
                                        deadherring
                                        I have my MM configured vertically and a lot of the calendar entries get cut off. I’m trying to widen the calendar.
                                        This is what I’ve added to custom.css but I’m not seeing any change. (sorry, I’m not sure how to make the code show up in a special way the way others do)
                                        body {
                                        .MMM-calendar {
                                        width : 350px;
                                        Can someone point me in the right direction in terms of what I’m doing wrong?
                                        Thanks,
                                        Nathan
                                        • brobergB Offline
                                          broberg Project Sponsor @deadherring
                                          @deadherring
                                          .calendar {
                                          width : 350px;
                                          It’s not supposed to be inside the body{} and since it is a default/stock module it doesn’t use the MMM prefix like other modules does so the class name of the module is just .calendar
                                            deadherring
                                            Thanks @broberg, that worked, I can see that changes I make are taking effect now.
                                            I set the calendar to 450px. However, as you can see from this
                                            picture, the date text just shifted over to the right and is now covering the weather forecast, rather than the text from the calendar entry expanding. What I’m trying to accomplish is to get the full calendar item text to show. Is there a way to do that?
                                            Thanks,
                                            Nathan
