Module calendar - whole day event
@MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
@MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
Example: checkered-flag to F1 time, calendar to appointment, etc.
I’ve looked in the manual, but I think I miss it. Do you have an example? -
{ module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics" symbol: "car", // <==this. }, ], } },
You can find other symbols in font-awesome.
https://fontawesome.com/ -
@MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
@htilburgs I edited original post (my bad, typed on iPhone)
@MMRIZE So now my F1 Calendar looks like this.
Do you know if it’s possible to get the date and time underneed an item instead of behind?
@htilburgs
By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
You might have 3 options.- modifying original source. But you will have some annoying issues on next update.
- Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
- Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
@MMRIZE
Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment. -
@MMRIZE Thank you very much, I have overlooked it. You make my day :-)
