    Module calendar - whole day event
    19 Posts 5 Posters 5.5k Views 5 Watching
    • htilburgsH Offline
      htilburgs @MMRIZE
      @MMRIZE what I ment are the truck, recycling and other symbols in front of each row.
      Never seen this before.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        MMRIZE @htilburgs
        @htilburgs
        Add “symbol” to each calendar in your calendar config.
        https://docs.magicmirror.builders/modules/calendar.html#configuration-options
        The icon symbol derives from “font-awesome”.
        htilburgsH 1 Reply Last reply Reply Quote 0
          MMRIZE @Babene1
          @Babene1
          Use timeFormat: “dateheaders”, in your calendar config.
            htilburgs @MMRIZE
            @MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
              htilburgs @htilburgs
              @MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
              Example: checkered-flag to F1 time, calendar to appointment, etc.
              I’ve looked in the manual, but I think I miss it. Do you have an example?
                MMRIZE @htilburgs
                @htilburgs
                			header: "US Holidays",
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        symbol: "car", // <==this.
                You can find other symbols in font-awesome.
                https://fontawesome.com/
                  htilburgs @MMRIZE
                  @MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
                    MMRIZE @htilburgs
                    @htilburgs I edited original post (my bad, typed on iPhone)
                      htilburgs @MMRIZE
                      @MMRIZE So now my F1 Calendar looks like this.
                      Do you know if it’s possible to get the date and time underneed an item instead of behind?
                        MMRIZE @htilburgs
                        @htilburgs
                        By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
                        You might have 3 options.
                        • modifying original source. But you will have some annoying issues on next update.
                        • Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
                        • Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
                          htilburgs @MMRIZE
                          @MMRIZE
                          Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment.
                            Babene1 Project Sponsor @MMRIZE
                            @MMRIZE Thank you very much, I have overlooked it. You make my day :-)
