    Module calendar - whole day event
    19 Posts 5 Posters 5.6k Views 5 Watching
      MMRIZE @Babene1
      @Babene1
      Use timeFormat: “dateheaders”, in your calendar config.
      https://docs.magicmirror.builders/modules/calendar.html#configuration-options
      • htilburgsH Offline
        htilburgs @MMRIZE
        @MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        htilburgsH 1 Reply Last reply Reply Quote 0
          htilburgs @htilburgs
          @MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
          Example: checkered-flag to F1 time, calendar to appointment, etc.
          I’ve looked in the manual, but I think I miss it. Do you have an example?
            MMRIZE @htilburgs
            @htilburgs
            			header: "US Holidays",
            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                                            symbol: "car", // <==this.
            You can find other symbols in font-awesome.
            https://fontawesome.com/
              htilburgs @MMRIZE
              @MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
                MMRIZE @htilburgs
                @htilburgs I edited original post (my bad, typed on iPhone)
                  htilburgs @MMRIZE
                  @MMRIZE So now my F1 Calendar looks like this.
                  Do you know if it’s possible to get the date and time underneed an item instead of behind?
                    MMRIZE @htilburgs
                    @htilburgs
                    By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
                    You might have 3 options.
                    • modifying original source. But you will have some annoying issues on next update.
                    • Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
                    • Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
                      htilburgs @MMRIZE
                      @MMRIZE
                      Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment.
                        Babene1 Project Sponsor @MMRIZE
                        @MMRIZE Thank you very much, I have overlooked it. You make my day :-)
