    Module calendar - whole day event
    19 Posts 5 Posters 5.6k Views 5 Watching
    • htilburgsH Offline
      htilburgs @MMRIZE
      @MMRIZE how do you get different icons in front of the calendar items?
      Is this a default feature? Btw which calendar module are u using?
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        MMRIZE @htilburgs
        @htilburgs
        Basically, default calendar module can hold icons (symbol) and even multiple, and all CX3* support multi-icons also.
        But in this case, that is just an emoji included in the event title. :D (If what you mented is the flag symbol)
        htilburgsH 1 Reply Last reply Reply Quote 0
          Babene1 Project Sponsor
          @MMRIZE I like your calendar view, how does it work with the date and under it the individual calendar entries?
            htilburgs @MMRIZE
            @MMRIZE what I ment are the truck, recycling and other symbols in front of each row.
            Never seen this before.
              MMRIZE @htilburgs
              @htilburgs
              Add “symbol” to each calendar in your calendar config.
              https://docs.magicmirror.builders/modules/calendar.html#configuration-options
              The icon symbol derives from “font-awesome”.
                MMRIZE @Babene1
                @Babene1
                Use timeFormat: “dateheaders”, in your calendar config.
                  htilburgs @MMRIZE
                  @MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
                    htilburgs @htilburgs
                    @MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
                    Example: checkered-flag to F1 time, calendar to appointment, etc.
                    I’ve looked in the manual, but I think I miss it. Do you have an example?
                      MMRIZE @htilburgs
                      @htilburgs
                      			header: "US Holidays",
                      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        symbol: "car", // <==this.
                      You can find other symbols in font-awesome.
                      https://fontawesome.com/
                        htilburgs @MMRIZE
                        @MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
                          MMRIZE @htilburgs
                          @htilburgs I edited original post (my bad, typed on iPhone)
                            htilburgs @MMRIZE
                            @MMRIZE So now my F1 Calendar looks like this.
                            Do you know if it’s possible to get the date and time underneed an item instead of behind?
                              MMRIZE @htilburgs
                              @htilburgs
                              By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
                              You might have 3 options.
                              • modifying original source. But you will have some annoying issues on next update.
                              • Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
                              • Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
                                htilburgs @MMRIZE
                                @MMRIZE
                                Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment.
                                  Babene1 Project Sponsor @MMRIZE
                                  @MMRIZE Thank you very much, I have overlooked it. You make my day :-)
