    Module calendar - whole day event
    19 Posts 5 Posters 5.8k Views 5 Watching
    • W
      wilco.kuijt @MMRIZE
      @MMRIZE Yes, this is the way I would like to see it!
      Unfortunately (😉) on holiday right now, so I am not able to implement it.
      Best regards and thanks for helping me out!
      Wilco
      • htilburgsH
        htilburgs @MMRIZE
        @MMRIZE how do you get different icons in front of the calendar items?
        Is this a default feature? Btw which calendar module are u using?
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        M 1 Reply Last reply
          MMRIZE @htilburgs
          @htilburgs
          Basically, default calendar module can hold icons (symbol) and even multiple, and all CX3* support multi-icons also.
          But in this case, that is just an emoji included in the event title. :D (If what you mented is the flag symbol)
          htilburgsH 1 Reply Last reply
            Babene1 Project Sponsor
            @MMRIZE I like your calendar view, how does it work with the date and under it the individual calendar entries?
            • htilburgsH
              htilburgs @MMRIZE
              @MMRIZE what I ment are the truck, recycling and other symbols in front of each row.
              Never seen this before.
                MMRIZE @htilburgs
                @htilburgs
                Add “symbol” to each calendar in your calendar config.
                https://docs.magicmirror.builders/modules/calendar.html#configuration-options
                The icon symbol derives from “font-awesome”.
                  MMRIZE @Babene1
                  @Babene1
                  Use timeFormat: “dateheaders”, in your calendar config.
                  B 1 Reply Last reply
                  • htilburgsH
                    htilburgs @MMRIZE
                    @MMRIZE Thanks, I’m currently using MMM-MyCalendar but I’m going to give it a try this evening.
                    • htilburgsH
                      htilburgs @htilburgs
                      @MMRIZE I’ve succesfully configured the calendar, but I’m looking how to add different icons to calendar items.
                      Example: checkered-flag to F1 time, calendar to appointment, etc.
                      I’ve looked in the manual, but I think I miss it. Do you have an example?
                        MMRIZE @htilburgs
                        @htilburgs
                        			header: "US Holidays",
                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
        symbol: "car", // <==this.
                        You can find other symbols in font-awesome.
                        https://fontawesome.com/
                        • htilburgsH
                          htilburgs @MMRIZE
                          @MMRIZE Oke, so if I understand correct, you add a symbol to a calendar and not to a calendar line?
                            MMRIZE @htilburgs
                            @htilburgs I edited original post (my bad, typed on iPhone)
                            • htilburgsH
                              htilburgs @MMRIZE
                              @MMRIZE So now my F1 Calendar looks like this.
                              Do you know if it’s possible to get the date and time underneed an item instead of behind?
                                MMRIZE @htilburgs
                                @htilburgs
                                By default, NO. It is coded as table so you cannot adjust it by only CSS without source modification.
                                You might have 3 options.
                                • modifying original source. But you will have some annoying issues on next update.
                                • Use other module equivalent which has that chance, But only module I know is my “MMM-CalendarExt3Agenda”, and you might need somewhat tweaks on CSS.
                                • Or you can use “MMM-ModuleMonkeyPatch”(the original subject of this thread!!!) to patch source without worrying update issue.
                                • htilburgsH
                                  htilburgs @MMRIZE
                                  @MMRIZE
                                  Oke, thanks for the quick reply. I leave it as is at the moment. It looks great. I’m going to give it a look on an other moment.
                                    Babene1 Project Sponsor @MMRIZE
                                    @MMRIZE Thank you very much, I have overlooked it. You make my day :-)
