    MMM-Pnews
    47 Posts 9 Posters 37.8k Views 10 Watching
      Johans @cowboysdude
      @cowboysdude
      just installed, but got an error -
      Load script: modules/MMM-Dnews//MMM-Dnews.js
      MMM-Dnews.js Failed to load resource: the server responded with a status of 404 (Not Found)
      loader.js:190 Error on loading script: modules/MMM-Dnews//MMM-Dnews.js
      script.onerror @ loader.js:190
      Would like to make a printscreen, but i can’t manage to do that on the raspberry.
      (indeed Dutch news, not Danish - thanks goprojojo )
      Edit: added screenprints
      cowboysdudeC 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer
        Sorry about that… right now I just don’t have time. I am SUPER busy… I will look at it when I can.
          cowboysdude Module Developer @Johans
          @Johans said in MMM-Pnews:
          MMM-Dnews.js
          The config was wrong…
          Should be:
                 module: 'MMM-DNews',
                position: 'bottom_bar',
                  rotateInterval: 20 * 1000
            cowboysdude Module Developer @goprojojo
            @goprojojo Yes I believe you are right!! OPPS…I’m fixing that right now!
            @Johans
            There NOW if your config.js is ‘nl’ then the translation file should work now :)
            The other issue was my fault because on github I put ‘MMM-Dnews’… should be ‘MMM-DNews’… all fixed!
            do a git pull to update :) Should work now.
            PS you may have to adjust translation file… I used google translate .
              @cowboysdude
              As for the weather error…it does that every now and then and it’s the weather api …it fixes itself so no worry there :)
                Johans @cowboysdude
                @cowboysdude
                works like a charm now.
                Thank you very much for this and all the great work you are doing.
                much appriciated !!
                Johans
                cowboysdudeC 1 Reply Last reply Reply Quote 1
                  @Johans You’re welcome and I’m glad it works for you :)
                  • 5 / 5
