    MMM-Pnews
    47 Posts 9 Posters 43.2k Views 10 Watching
      DeanoAus
      Ah, so you did! :D I read that as you’ll look into multiple instances. It’s late. ;)
      All good my friend. I’ve somehow killed my MM install after an update.
      • cowboysdudeC Offline
        cowboysdude Module Developer @DeanoAus
        @DeanoAus OH mannnnnnn I hate that… I just redid my bathroom mirror as I killed that one too … I feel your pain.
        It’s late for you, I just woke up LOL So let me know if there is a specific category you’re looking for or just taking out the newsource will work for you because if you do that it will return ALL news. :)
        Future implementation will be different languages: en, de, fr
          DeanoAus @cowboysdude
          @cowboysdude said in MMM-Pnews:
          There may be a quickie fix I can do if you tell me what you’re looking for…
          business, entertainment, gaming, general, music, politics, science-and-nature, sport or technology.
          Was after one tech, one Australian news. And seeing as I can’t reply before 120 seconds… sigh… i’ll combine my replies.
          pi@Pi:~/MagicMirror $ DISPLAY=:0 npm start
          > magicmirror@2.1.1 start /home/pi/MagicMirror
          > sh run-start.sh
          run-start.sh: 4: run-start.sh: electron: not found
          npm ERR! Linux 4.9.25-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          npm ERR! node v6.10.2
          npm ERR! npm  v3.10.10
          npm ERR! file sh
          npm ERR! code ELIFECYCLE
          npm ERR! errno ENOENT
          npm ERR! syscall spawn
          npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
          npm ERR! spawn ENOENT
          I’ve tried updating, installing, you name it.
          npm install electron
          npm install
          etc. :/
            @DeanoAus said in MMM-Pnews:
            electron: not found
            electron is not installed… i had an issue as well so I just reinstalled the mirror… that fixed the electron issues.
              DeanoAus
              Ugh, I think i found it. You need to do npm install as root…
              Wait, nope!
              pi@Pi:~/MagicMirror $ sudo npm install
              > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              /home/pi/MagicMirror/node_modules/electron/install.js:47
                throw err
              Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                  at Error (native)
              npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
              npm ERR! electron@1.6.6 postinstall: `node install.js`
              npm ERR! Exit status 1
              Ugh, I give up. Going to bed. Thanks for your help, i’ll fix in the morning. :)
                Good Night :)
                  DeanoAus
                  Hey mate, I think I have a bug for you. :bug:
                  In MMM-PNews.js you hard code in the sorting method (latest) for the source.
                  this.url = "https://newsapi.org/v1/articles?source=" + this.config.newsSource + "&sortBy=Latest&apiKey=";
                  Latest isn’t a valid sorting method for some sources.
                  Example is the https://newsapi.org/abc-news-au-api
                  If you hit that with the url they provide with Latest in there for sorting, it fails and gives
                  {"status":"error","code":"sourceUnavailableSortedBy","message":"The news source you've selected (abc-news-au) isn't available sorted by latest"}
                  But if you change Latest to Top in the url, works fine. :)
                  This is causing some feeds to not work.
                    DeanoAus
                    This post is deleted!
                      DeanoAus
                      Also, mine doesn’t seem to be updating the feed. (Sorry!)
                      Seeing this in the log?
                      fatal: unable to access ‘https://github.com/cowboysdude/MMM-PNews/’: GnuTLS recv error (-54): Error in the pull function.
                        sourceUnavailable
                        I’ve updated the url so that should fix that…
                        The other error is a git error … “: Error in the pull function”
                          DeanoAus
                          Awesome, thanks! :D
                          • L Offline
                            lucallmon
                            @cowboysdude Just installed this for the first time. Looks GREAT! However, it seems to take up a lot of space at the bottom bar; I am using a somewhat smaller screen. Is there a way I can limit the module to more of the center leaving space on both sides at the bottom for smaller modules? Also, I’d like to center the pic and text. It seems that it only aligns to the left. Any help would be greatly appreciated.
                              cowboysdude Module Developer @lucallmon
                              @lucallmon I’ll take a look at it later when I get home :) We’ll see what we can do!
                                Johans
                                hi Cowboysdude,
                                I like your modules, nice work.
                                I was wondering if you could modify or make a separate module for the dutch (belgian) newsfeeds.
                                take a look at this side: http://feeds.nieuwsblad.be/nieuws/snelnieuws
                                they provide for each headline, a pircture and short description.
                                It would be nice if you could also incorparate this into the module.
                                Johan
                                  cowboysdude Module Developer @Johans
                                  @Johans said in MMM-Pnews:
                                  hi Cowboysdude,
                                  Johan
                                  Johan, Thank you! I will certainly take a peek at that this evening!! :)
                                    @Johans
                                    Here you go:
                                    https://github.com/cowboysdude/MMM-DNews
                                    Mykle1M J G 3 Replies Last reply Reply Quote 1
                                      Mykle1 Project Sponsor Module Developer @cowboysdude
                                      Here you go:
                                      So, all I have to do is ask and you’ll make me a module?
                                      You’re awesome! :^)
                                        cowboysdude Module Developer @Mykle1
                                        @Mykle1 said in MMM-Pnews:
                                        Here you go:
                                        You’re awesome! :^)
                                        Sure, why not? LOL
                                          Johans @cowboysdude
                                          @cowboysdude
                                          You are amazing.
                                          Never thought it would be realized.
                                          Had a hard day on the job today, but this makes my day.
                                          I’m going to install now.
                                          Johan
                                          • G Offline
                                            goprojojo @cowboysdude
                                            @Johans
                                            Here you go:
                                            Isnt Johan looking for Dutch instead of Danish news? :P
                                            • 2 / 3
