    node problem : I can't update my MM and MM disappears from my screen after reboot
    28 Posts 4 Posters 9.1k Views 4 Watching
      sdetweil @bugsounet
      @bugsounet if the module is installed in the base folder, but not referenced In package.json it will be removed on next npm install for security
      I check for rebuild not refresh… will fix upgrade
      bugsounetB 1 Reply Last reply Reply Quote 0
      • bugsounetB Offline
        bugsounet Banned @sdetweil
        @sdetweil sure, that why i use my “Installer core”. All script are inside, I just have to call it ;)
          sdetweil @bugsounet
          @bugsounet @RIKKO14
          can either of you run this on your French systems
          LC_ALL=C  free -m
          should output in english
            RIKKO14
            @sdetweil Hello,
            it scares me, my MM has been working perfectly lately. I’m worried that by making this script it will upset something. what is it to do and should it be done directly in the terminal or in the MM folder?
              sdetweil @RIKKO14
              @RIKKO14 just one command run in terminal
              returns amount of memory being used
              my scripts use this an depend on the English text,
              trying to make sure it comes out in English is all.
              has no affect on system
                MMRIZE @RIKKO14
                @RIKKO14
                If your MM worked fine and you don’t have any MUST-UPDATE needs, Just don’t update . Leave it as it was.
                  RIKKO14
                  here it is :
                    sdetweil @RIKKO14
                    @RIKKO14 thank you! perfect
