    Taking The Leap! Need MM Family Help
    8 Posts 4 Posters 4.3k Views 3 Watching
      SoleLo
      Finally decided to take the leap. Which mirror should I do it with? I need your help.0_1487614367716_IMG_1535.JPG
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @SoleLo
        @SoleLo said in Taking The Leap! Need MM Family Help:
        Are they both 2-way mirrors?
        • brobergB
          broberg Project Sponsor
          Construction wise a framed mirror is the best choice if you want to hide the monitor/computer behind it.
            SoleLo @Mykle1
            @Mykle1 nah they are not. Just single sided mirrors for now.
            @broberg I’ll probably do the framed one. I’ll try and start working on it this weekend if I can squeeze some time in. How long would you say it takes to load stuff on the Pi…?
            • Mykle1M
              Oh, you meant the style. I went with the frame as well. I’m thinking the frameless mirror would have to be recessed for full effect. I don’t know what to tell you about how long it will take to load the Pi. I had to learn virtually everything, having had no experience with much of what I as dealing with. If, however, you’re comfortable with linux and such, you’ll certainly have less trouble and devote less time to it than I did.
              slametpsS S 2 Replies Last reply
              • slametpsS
                slametps @Mykle1
                @Mykle1 I prefer frameless with the back installed deep into the wall (if possible).
                regards,
                Slamet PS
                  SoleLo @Mykle1
                  @Mykle1 and @slametps I was looking at some other’s that were done before and the frame less does look extra clean and I don’t really use that medicine cabinet it’s pretty much empty right now. So we’ll see I’ll do some more research.
                  • Mykle1M
                    Nice! Then some of the work is already done for you, if you decide to “bury” it.
