    Multiple instances of ImagesPhotos module
    20 Posts 2 Posters 16.1k Views 2 Watching
    • N Offline
      Nneuland
      HI there,
      I’ve successfully duplicated MMM-ImagesPhotos to run two different photo sets, however I’m running into a silly issue.
      Despite the “new” module MMM-ImagesPhotos2 working, it is referencing the upload images from the original MMM-ImagesPhotos upload folder. Even though the images are in appropriate locations.
      Is this a caching issue? Any help would be greatly appreciated
        @Nneuland ok, update
        git pull in the module folder
        make sure to set the maxHeight and width in the config
                        module: "MMM-ImagesPhotos",
                        disabled: false,
                        position:"top_left",
                          backgroundColor: "grey",
                          fill: true,
                          blur: 10,
                          sequential: true,
                          path:"foo",
                          debug:true,
                          maxWidth:"50%",
                          maxHeight:"50%"
                        order: "*",
                        bad_position: "fullscreen"
                        disabled: false,
                        position:"top_right",
                          backgroundColor: "blue",
                          fill: true,
                          blur: 10,
                          sequential: true,
                          path:"test1",
                          debug:true,
                          maxWidth:"500px",
                          maxHeight:"500px"
                        order: "*",
        note 50% vs 500px produces different sizes
        there are two different image css classes… one when full screen, one not
          sdetweil @Nneuland
          @Nneuland no, not a caching… the way the module works it creates a url link back into the node_helper to access the images
          in the node_helper.js
          extraRoutes: function() {
          		var self = this;
                           // this url gets the images
          		this.expressApp.get("/MMM-ImagesPhotos/photos", function(req, res) {
          			self.getPhotosImages(req, res);
                            // this url processes THIS image
          		this.expressApp.use("/MMM-ImagesPhotos/photo",   //<-----
           express.static(self.path_images));
          // return photos-images by response in JSON format.
          	getPhotosImages: function(req, res) {
          		directoryImages = this.path_images;
          		let imgs=this.getFiles(directoryImages)
          		var imagesPhotos = this.getImages(imgs).map(function (img) {
          			if(this.config.debug){
          			  	console.log("have image="+img);
          			return {url: "/MMM-ImagesPhotos/photo/" + img}; //<----- url for an image
          		res.send(imagesPhotos);
          and then in the
          MMM-ImagesPhotos.js
          getPhotos: function() {
          		var urlApHelper = "/MMM-ImagesPhotos/photos";    /// path got get images
          		var retry = true;
          		var photosRequest = new XMLHttpRequest();
          		photosRequest.open("GET", urlApHelper, true);  // used here to get images list
          you can change the values, just in one instance
          • N Offline
            Nneuland @sdetweil
            Thanks Sam. I’ll give that a go later tonight/. thank you for your suggestion
            N S 2 Replies Last reply Reply Quote 0
            • N Offline
              Nneuland @Nneuland
              @Nneuland
              Hi Sam. Seeing that my duplicate module is “MMM-ImagesPhotos2”
              Should I be changing all moments within the js files “MMM-ImagesPhotos/photos” or “MMM-ImagesPhotos” to “MMM-ImagesPhotos2/photos” or “MMM-ImagesPhotos2” ?
                sdetweil @Nneuland
                @Nneuland I would do that, yes
                doesn’t matter, as long as both url strings are different. I would add a 2 on the end of both, in all the places
                • N Offline
                  Nneuland @sdetweil
                  Seemed simple enough, but leave it to me. No visuals for this duplicated module.
                  css folder renamed- but empty
                  node-helper.js and MMM-ImagesPhotos.js folders renamed as well as every instance of ImagesPhotos(2) renamed
                  Where can I look to troubleshoot?
                    sdetweil @Nneuland
                    @Nneuland I fixed the code so it can do multiple instances…
                    make sure to set the path: variable to the subset of pics in the uploads folder
                    if path is not set then uploads is the folder
                    oh, and I added recursive folder support a few weeks ago
                    the image drawing may be mangled I had two side by side… top_left/right, filled the screen
                    my config
                            disabled: false,
                              fill: true,
                              blur: 10,
                              sequential: true,
                              path:"foo",   // uploads/foo
                     //         debug:true
                            disabled: false,
                              fill: true,
                              blur: 10,
                              sequential: true,
                              path:"test1",   // uploads/test1
                    //          debug:true
                      sdetweil @Nneuland
                      @Nneuland you didn’t do npm install in the module folder
                      • N Offline
                        Nneuland @sdetweil
                        I don’t know what I did, but I lost my auto restart. Seem to have MagicMirror AND mm running (twice) somehow. My vnc isnt showing what the mirror is showing, MMM-RemoteControl on my phone lost my second instance of ImagesPhotos (which I couldnt get working anyway)…
                        I think I need a break for the night and possibly a fresh install in the near future, I don’t know how you do this
                          sdetweil @Nneuland
                          @Nneuland
                          MagicMirror crashed cause this module was missing a library . that’s why you don’t see anything and can’t connect
                          do this
                          cd ~/MagicMirror/modules/MMM-InagesPhotos
                          npm install
                          cd ~
                          pm2 stop all
                          cd ~/MagicMirror
                          npm start
                            sdetweil @Nneuland
                            @Nneuland you ARE using my fork , right?
                            https://github.com/sdetweil/MMM-ImagesPhotos
                            • N Offline
                              Nneuland @sdetweil
                              Thank you! I hit a large wall last night and needed to stop.
                              I’m back up and running, but still need to reinitiate my auto restart and get back to the task at hand of duplicating two separate ImagesPhotos modules.
                              My attempt at duplicating an additional MMM-ImagesPhotos module has still fallen short. I enjoy using the MMM-RemoteControl to customize the mirror real time. Which included the idea of running two identical MMM-ImagesPhotos modules (different names) to be in the exact same space on the mirror, but only one at a time. One url set showing family photos and the other showing my son’s favorite cartoons.
                              So having two different running modules (MMM-ImagesPhotos, and MMM-ImagesPhotos2, on MMM-RemoteControl is ideal for my purposes.
                              I’ll need some fresh eyes on it tonight. I figured since they were referencing different uploads folders from two different module folders, this wouldn’t be a problem.
                              Unfortunately adding the path to my config file did not allow for the module to run.
                              I’ll need to keep at it
                                sdetweil @Nneuland
                                @Nneuland remove the old separates and copied code, only confuses things.
                                use my new forked code only
                                the module looks for images in the uploads folder inside the module folder
                                you can ADD to that with path (not my design)
                                so some pics are in uploads/foo and some are in uploads/bar
                                each module config needs that path:“foo”, or path:“bar”
                                else it looks in uploads and with my recursive support will get everything .
                                the new fork code adds the module identifier to the url paths to make things unique.
                                took a bit to make all that work tho. mostly in the node helper, as it has to service all the instances at once
                                N 2 Replies Last reply Reply Quote 0
                                • N Offline
                                  Nneuland @sdetweil
                                  Thank you. I’m hoping to look at this tonight
                                  • N Offline
                                    Nneuland @sdetweil
                                    Finally got it up and running. Thank you for your patience.
                                    The only thing, because I’m running two instances, the positioning and photo size is quite off. MaxHeight and MaxWidth in config doesn’t seem to be influencing any and the custom css modifications also are not working as expected. Looking to keep the same posting for both url sets
                                      sdetweil @Nneuland
                                      @Nneuland yes, I said maybe the sizing was wrong. I’ll look at it.in the morning.
                                      I added some special code to fix the sizes so that they kept the original aspect ratio, but never tried in non full screen. I’ll see if I can turn that off easily.
                                      • N Offline
                                        Nneuland @sdetweil
                                        you did. Maybe I can simply rescale my images, but if you have a work around that would be great. Just curious if it were my ignorance, or something else.
                                          sdetweil @Nneuland
                                          @Nneuland all my fault
                                                            disabled: false,
                                                              fill: true,
                                                              blur: 10,
                                                              sequential: true,
                                                              path:"foo",
                                                              debug:true,
                                                              maxWidth:"50%",
                                                              maxHeight:"50%"
                                                            order: "*",
                                                            disabled: false,
                                                              fill: true,
                                                              blur: 10,
                                                              sequential: true,
                                                              path:"test1",
                                                              debug:true,
                                                              maxWidth:"500px",
                                                              maxHeight:"500px"
                                                            order: "*",
                                            • N Offline
                                              Nneuland @sdetweil
                                              This is amazing! Thank you for all of your hard work. Works perfectly
