    Magic Mirror doesn't work after a boot
    27 Posts 2 Posters 9.4k Views 2 Watching
    • E Offline
      eightbit
      I need some serious help. I’ve probably spent the last 12 hours messing with PM2 and the mm.sh script for a Magic Mirror to display google photos.
      When I do a pm2 start mm.sh it works perfectly. It loads the pictures up and cycles through them. When I reboot the raspberry pi Magic Mirror will attempt to launch but it just sits at this infinite white screen and never loads the pictures to cycle through. If I ssh into the system and do another pm2 start mm.sh -f it works and if I do a pm2 restart mm.sh it works.
      What am I missing here? No other start up method seems to get this thing to successfully display pictures after a reboot. Please help…
      Here is the guide I’m trying to follow
      https://docs.magicmirror.builders/configuration/autostart.html#using-pm2
        sdetweil @eightbit
        @eightbit ok…
        cd ~/MagicMirror
        npm install electron@26.2.4
        and try again, manually w
        npm start
          sdetweil @eightbit
          @eightbit because you’ve done a lot of pm2 commands and run, the log is large, so lets clear that
          pm2 flush
          then reboot
          alt-spacebar, n
          to minmize the white screen mm, or ssh in
          pm2 logs --lines=nnnn
          nnnn is some number, default 15
          another thing you can do is use my script for pm2 setup
          see https://github.com/sdetweil/MagicMirror_scripts
          last script on the page is fixuppm2
          but first we need to clear the pm2 config
          pm2 stop all
          pm2 delete all
          pm2 save -f
          then run my script…
          it uses the ~/MagicMirror/installers/mm.sh
          • E Offline
            eightbit @sdetweil
            @sdetweil Should I delete the mm.sh in my home dir before i run your pm2 fix?
              sdetweil @eightbit
              @eightbit no… if it all works then later yes
                sdetweil @eightbit
                @eightbit its only called ‘fix’ cause during my install script you can add pm2 support, or not… so its a separate script if u change your mind later
                • E Offline
                  eightbit @sdetweil
                  @sdetweil Shoot. No luck! When I ran your script it loaded up and started perfectly and after the reboot it is hung on a white screen. In the logs it looks like it’s really trying to do something with the chromium browser but it just hangs and hangs. When it works on a pm2 start mm.sh (or using fixuppm2.sh) the log looks the same but then there are a couple lines after “starting chromium browser now”. I’ll post the log in another post.
                  S E 2 Replies Last reply Reply Quote 0
                    sdetweil @eightbit
                    @eightbit I just forgot, did you remove the autostart setup u added in the services?
                    • E Offline
                      eightbit @eightbit
                      /home/secretsanta/.pm2/logs/MagicMirror-error.log last 15 lines:
                      /home/secretsanta/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [14.12.2023 07:44.23.049] [LOG] No helper found for module: alert.
                      0|MagicMir | [14.12.2023 07:44.23.234] [LOG] Initializing new module helper ...
                      0|MagicMir | [14.12.2023 07:44.23.248] [LOG] Module helper loaded: updatenotification
                      0|MagicMir | [14.12.2023 07:44.46.958] [LOG] Initializing new module helper ...
                      0|MagicMir | [14.12.2023 07:44.46.963] [LOG] Module helper loaded: MMM-GooglePhotos
                      0|MagicMir | [14.12.2023 07:44.46.988] [LOG] All module helpers loaded.
                      0|MagicMir | [14.12.2023 07:44.47.103] [LOG] Starting server on port 8080 ...
                      0|MagicMir | [14.12.2023 07:44.47.496] [LOG] Server started ...
                      0|MagicMir | [14.12.2023 07:44.47.499] [LOG] Connecting socket for: updatenotification
                      0|MagicMir | [14.12.2023 07:44.47.503] [LOG] Starting module helper: updatenotification
                      0|MagicMir | [14.12.2023 07:44.47.525] [LOG] Connecting socket for: MMM-GooglePhotos
                      0|MagicMir | [14.12.2023 07:44.47.527] [LOG] Sockets connected & modules started ...
                      0|MagicMir | [14.12.2023 07:44.47.529] [LOG]
                      0|MagicMir | Ready to go! Please point your browser to: http://localhost:8080
                      0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                      • E Offline
                        eightbit @sdetweil
                        @sdetweil Yea I cleared out the systemd services I tried to enabled. They are disabled and stopped. I also tried an rc.local startup file to run the .sh file which never worked. I know that’s depreciated but desperate times and desperate measures lol.
                          sdetweil @eightbit
                          @eightbit what device is this… you are using my install script which launches
                          run-start.sh
                          this is reserved for armv6 devices…
                          can u check the autostart
                          did you do this??? (answer should be no)
                          https://docs.magicmirror.builders/configuration/autostart.html#using-systemd-systemctl
                            sdetweil @eightbit
                            @eightbit also do a
                            free -m
                            see how big the swap space is and total memory
                            • E Offline
                              eightbit @sdetweil
                              @sdetweil Raspberry Pi 3 Model B Rev 1.2
                              I did try to use systemd but it did not work so I disabled and deleted all the systemd attempts.
                              • E Offline
                                eightbit @sdetweil
                                secretsanta@raspberrypi:~ $ free -m
                                               total        used        free      shared  buff/cache   available
                                Mem:             921         265          94           6         561         594
                                Swap:           1861           1        1860
                                  sdetweil @eightbit
                                  @eightbit can u show me the “start”: from package.json
                                  E 1 Reply Last reply Reply Quote 1
                                  • E Offline
                                    eightbit @sdetweil
                                       "start":"./run-start.sh $1",
                                                   "server": "node ./serveronly",
                                                   "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev",
                                                   "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier",
                                                   "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                                   "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier",
                                                   "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"",
                                                   "test": "NODE_ENV=test jest -i --forceExit",
                                                   "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit",
                                                   "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit",
                                                   "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit",
                                                   "test:unit": "NODE_ENV=test jest --selectProjects unit",
                                                   "test:prettier": "prettier . --check",
                                                   "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                                   "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json",
                                                   "test:calendar": "node ./modules/default/calendar/debug.js",
                                                   "config:check": "node js/check_config.js",
                                                   "lint:prettier": "prettier . --write",
                                                   "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi>
                                                   "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix",
                                                   "lint:staged": "lint-staged",
                                                   "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
                                      sdetweil @eightbit
                                      @eightbit
                                      delete one of them and replace the other with
                                      		"start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js",
                                      also do uname -a
                                      E 2 Replies Last reply Reply Quote 1
                                      • E Offline
                                        eightbit @sdetweil
                                        @sdetweil said in Magic Mirror doesn't work after a boot:
                                        “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                                                "name": "magicmirror",
                                                "version": "2.25.0",
                                                "description": "The open source modular smart mirror platform.",
                                                "main": "js/electron.js",
                                                "scripts": {
                                                "repository": {
                                                        "type": "git",
                                                        "url": "git+https://github.com/MichMich/MagicMirror.git"
                                        • E Offline
                                          eightbit @sdetweil
                                          Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
                                            sdetweil @eightbit
                                            @eightbit you didn’t need to delete all the rest of the scripts
                                              sdetweil @eightbit
                                              @eightbit ok, armv7 and memory >512… hm
                                              can u send me the ~/install.log
                                              I want to see why it picked the run-statrt approach…
                                              same userid at gmail
