    birthdaylist
    module
    41 Posts 3 Posters 40.4k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror said in birthdaylist:
      is a blank needed before “Suzie”?
      no, I trim off blanks… allow for sloppy editing/pasting
      all entries have to have the same date format
        sdetweil @MyMirror
        @MyMirror the csv file format is
        the header row,
        birth  ,  name
        and then
        rows for each person
        birthday , name
        the birthday format can be in whatever format you like
        MM/DD/YYYY
        DD/MM/YYYY
        YYYY/DD/MM
        YYYY/MM/DD
        using whatever separator you choose
        the layout and separator have to be the same for all birthday rows
          MyMirror @sdetweil
          OK, my mistake :worried_face:
          I misinterpreted currentMonthOnly: and assumed that all maxEntries would then be displayed (for more than 2 month).
          But with “false”, the current and the following month are displayed.
          Sorry for the trouble :flushed_face:
          (There was no entrie for January in my data file)
            sdetweil @MyMirror
            @MyMirror yes, I already had support for next month dec=>jan
            just sort was broken.
              sdetweil @MyMirror
              @MyMirror I just pushed a change to display a message
              when no birthdays are found to display given the current settings
              I also added support to translate that message into the language set in the MM config…
              I provided files for english, french, german, italian and spanish
                MyMirror
                One more request/question:
                Could you add the month as a picture?
                If you set this option “currentMonthOnly: false” (which I find very good), then a month without an entry can lead to misunderstandings.
                Example:
                We have January and no entry for January in the bdl.csv.
                But on February 10.
                This would look like the next birthday is now on January 10, right?
                In this respect, is it possible to display the month as well?
                Jens
                  sdetweil @MyMirror
                  @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
                  let me think about this
                    sdetweil @MyMirror
                    @MyMirror ok, git pull again
                    add
                    withMonth: true,
                    to the config parms…
                    note that the image is 27px square, so the space for text is small…
                    to fit, I made new css classes with a smaller font size when showing month
                      MyMirror @sdetweil
                      Excellent - 5 stars for you!
                      Great job!
                      Jens
                      • P Offline
                        pulser
                        thanks for this module, first of all.
                        upcoming months are sorted correctly, but current month is on the bottom. how can we get current month on top?
                          sdetweil @pulser
                          @pulser I’ll look at it
                            sdetweil @pulser
                            @pulser do
                            git pull
                            in the module folder
                            M P 3 Replies Last reply Reply Quote 0
                              MyMirror @sdetweil
                              Maybe other idea for “day/month”?
                              Possible?
                                sdetweil @MyMirror
                                @MyMirror not without some redesign.
                                the image we picked originally was only supposed to hold the day number
                                there is no up/down room, each line would have to get taller
                                and for US the month would have to come first…
                                so it gets harder and harder…
                                anyone that wants to try, fork the module and go for it…
                                • P Offline
                                  pulser @sdetweil
                                  work smoothly. thanks.
                                    MyMirror @sdetweil
                                    Hmm, but now something is wrong with the calculation of the age.
                                    I have the following bdl.csv:
                                    birth, name
                                    08/01/1940,aaa 84
                                    10/01/1963,bbb 61
                                    15/01/1964,ccc 60
                                    05/02/1964,Oliver 60
                                    06/02/1974,Frank 50
                                    and the result (made via my cell phone, as I can’t currently get the MagicMirror to start on my PC (mstsc)):
                                    The birthdays from the coming month are now 1 year “too young”.
                                      sdetweil @MyMirror
                                      @MyMirror ok, will look. I didn’t change any of that, just sort
                                        @MyMirror fixed… git pull in the module folder to update
                                        I was only comparing the day of the month (as its the current month, right!!.. nope…!)
                                        so if the bd month is > then the current month OR they are the same month but the bd DAY is > than today… show the projected age then …
                                          MyMirror @sdetweil
                                          Unfortunately not quite :disappointed_face:
                                          Now the age from the current month is no longer correct
                                          Same bdl.csv as above
                                            sdetweil @MyMirror
                                            @MyMirror git pull again… I made two changes… hoped I would update before you pulled… oops
                                            • 2 / 3
