MMM-euro2024
Hi guys,
I cannot get this module to run…I also opened an issue in the repo: https://github.com/0m4r/MMM-euro2024/issues/2
Can somebody from here help me? @0m4r ?
Thanks in advance
@leafarenuk I replied to you on Git Hub a week ago or so.
As I have not heard back from you since then, I assume the problem is resolved.If not, feel free to get in touch again.
@0m4r Hello and thank you for your great module.
after installing it, it appears on my mirror, but stays on “loading…”.
Do you maybe know this issue?
Thanks in advance for your helps.
Kind regards
Hello Mirrorenthusiasts,
it is possible to use this module für the WorlCup 2026? Thx
you can either use: https://github.com/0m4r/MMM-SoccerLiveScore and add 2000 to the leagues config parameter: https://github.com/0m4r/MMM-SoccerLiveScore#config
or you can update the file:
https://github.com/0m4r/MMM-euro2024/blob/main/MMM-euro2024.js
to use the worldcup code: 2000(https://docs.football-data.org/general/v4/lookup_tables.html#_league_codes)
Thank You! It’s working like a charm.
I play around with the MMM-SoccerLiveScore module. I used the module at a Full HD Touchscreen. Is there a way to scroll the Standings by hand? The Screen is to small to show the full table.
THX
@Niggich it should scroll by itself if the config value scrollVertical is set to true.
I never tried it on a touch screen…
@0m4r No, it doesn’t scroll by itself when i set the value scrollVertical to true. It’s just scrolling the title bar but not the table.
@Niggich ok… I will need to take a look at it, but it may take some time…
