    MMM-OpenWeatherForecast
    92 Posts 14 Posters 64.5k Views 14 Watching
      megagprime @sdetweil
      This post is deleted!
        sdetweil @megagprime
        @megagprime comment out the apibase, let the module set it
          MarcLandis Module Developer @sdetweil
          @sdetweil MMM-OpenWeatherForecast has V2.5 as default.
          M M 2 Replies Last reply Reply Quote 0
            megagprime @MarcLandis
            @MarcLandis yes we need 3.0
              MarcLandis Module Developer @MarcLandis
              @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
                sdetweil @MarcLandis
                @MarcLandis shocking, Tom is usually not behind like that
                i haven’t checked, is the url unchanged except for the version number?
                  @sdetweil tom has new url in readme apiBaseURL for opencall3
                    @sdetweil yes - all that is needed is …/2.5/… -> …/3.0/…
                      @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
                      without debugging hard to tell. i expect the fetch would fail 401. authentication failed
                      • O Offline
                        OldGuyBerlin @sdetweil
                        It seems the default API was changed from 2.5 to 3.0 with the recent update. Even it is (not yet) in the documentation.
                        Here is what I did:
                        I inserted in the config.js
                        apiVersion: "2.5",
                        Since the problem occurred after the recent MM2 Update (and worked fine until then) it was clear, that the update has some doing in that.
                        Even if the 2.5 API should be down, it is working just fine.
                        After this change, it works (again) like charm.
                        S H 2 Replies Last reply Reply Quote 1
                          sdetweil @OldGuyBerlin
                          @OldGuyBerlin the doc for 2.29 today
                          • O Offline
                            Didn’t see this until now.
                            That is why the workaround with the API Version works. ;-)
                              Ray
                              So let me add one more thing here if I can
                              if I give these guys my credit card just in case I go over
                              where in MMM-OpenWeatherForecast will it tell me how many calls it made
                              M S 2 Replies Last reply Reply Quote 0
                                MarcLandis Module Developer @Ray
                                @Ray the number of calls depend on the update intervall you set in your config. For example if you have it update every 10 minutes it will be 144 calls a day.
                                R 2 Replies Last reply Reply Quote 0
                                  Ray @MarcLandis
                                  @MarcLandis 000 I did not know that thanks for the update that makes a big difference
                                    sdetweil @Ray
                                    @Ray they do have an activity page
                                      Ray @sdetweil
                                      @sdetweil okay that’s good to know to
                                        megagprime
                                        we still dont have a fix here, ive tried all this and still wont load
                                          Ray @MarcLandis
                                          @MarcLandis okay so forgive me for being ignorant here
                                          I’m having problem with the math here
                                          if I sit for 15 minutes that would be 96 calls is that correct
                                            sdetweil @Ray
                                            @Ray 24x4, yes
                                            • 2 / 5
