    birthdaylist - discontinued ?
    63 Posts 2 Posters 18.0k Views 2 Watching
      sdetweil @rkorell
      @rkorell you are using the analog clock, not digital
      this for digital
      displaySeconds	Display seconds.
      Possible values: true or false
      Default value: true
      and I didn’t see this change
      sendNotifications	Enable notifications for elapsed time. Used to be always done send prio to v2.23
      Possible values: true, or false
      Default value: false
        @sdetweil Yeah…
        You’re right.
        I’ve set this - my type of clock is set to “both” because I like sunset and day of week information.
        This causes an error in your module…
        birthdaylist.js:398 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'startsWith')
            at Class.getBD_DAY_from_Date (birthdaylist.js:398:9)
            at Class.getDom (birthdaylist.js:462:154)
            at main.js:132:35
            at new Promise (<anonymous>)
            at updateDom (main.js:112:10)
            at Object.updateDom (main.js:669:4)
            at Class.updateDom (module.js:341:6)
            at Class.socketNotificationReceived (birthdaylist.js:328:9)
            at module.js:240:9
            at Socket.<anonymous> (socketclient.js:32:4)
        Not sure if this corresponds with the displaySeconds parameter but seen this error first time…
        Regards,
        Ralf
        R S 2 Replies Last reply Reply Quote 0
          rkorell Module Developer @rkorell
          No, obviously NOT…
          I’ve now added “sendNotifications: true” to config.
          Mirror reloads and your module starts without this error message.
            sdetweil @rkorell
            @rkorell can i see your birthdaylist config
            and the date portion of one birthday from the list, which order the date info is in
            and this error is trying to check if tye month part starts w a 0
            and i figure out which date separator you used
            /, or :, or just not ,
            and then i split the date with the separator i discovered, they all HAVE to be the same separator and order
              @sdetweil yes, for sure
              birth, name
              17/01/1965,Carola
              31/12/1963, Ralf
              27/01/1993, Lennart
              11/07/1987, Levin
              28/07/1985, Katharina
              4/1/1953,Norbert L.
              18/3/1939,Jürgen
              22/3/1996,Chrizzy
              27/3/1985,Hochzeitstag
              31/3/2012,Hannah
              31/3/2022,Nilo
              11/4/1974,Claas
              26/4/1965,Ralf B.
              30/4/1989,Rahel
              7/5/2020,Mathilda
              27/5/1994,Elaine
              10/6/1960,Melanie
              5/2/1965,Stefan
              26/5/2002,Leonie
              4/1/2004,Carolin
              10/6/95, 2.Hochzeitstag
              10/6/1964,Petra B
              23/6/1984,Colin
              29/7/1995,Jassi
              29/7/1955,Shirley P.
              20/7/2001,Helene
              5/8/1963,Harald
              16/9/1997,Shirley Pi.
              20/9/1965,Heiko D.
              15/8/1967,Uta
              23/8/2019,Emil
              17/11/68,Susanne
              27/9/1987,Severin
              9/11/1948,Marianne
              12/11/1967,Silvia
              27/11/1956,Martina L.
                Ahh…
                in the code listing it shows up a difference …
                “10/6/95, 2. Hochzeitstag”
                with an additional space and a dot…
                is this a problem?
                I can change the taxt and delete space if nacessary (althoug I mean I’ve read that you are truncing entries …
                But the dot could be eliminated if useful.
                Ralf
                  interesting enough the error shows up first time as I reported - the list is always the same - literally unchanged until first day of installation…
                    sdetweil @rkorell
                    @rkorell nvm i see it… let me look at it
                      sdetweil @rkorell
                      @rkorell I don’t see the error… can you show me the bdlist config
                      also, that line of code would only happen is there WAS a birthday to display
                      and your list doesn’t have one for tomorrow or later (in this month)
                      are for next month…
                      still don’t see the error…
                      my code strips off the extra leading space on the name field.
                        @sdetweil indeed - should have done this at the begin, sorry:
                        // Geburtstagsliste
                        // Gelesen wird: ~/MagicMirror/modules/birthdaylist/data/bdl.csv
                        	        module: "birthdaylist",
                        	        disabled: false,
                        	        position:'top_right',
                        						dimmEntries: false,  // true: dims entries and the associated symbol when the date has expired. false: dont display entries and the associated symbol when the date has expired.
                        						initialLoadDelay: 0, // How many seconds to wait on a fresh start up.
                        						updateDelay: 5,      // How many seconds after midnight before a refresh
                        						currentMonthOnly: false,  // will show birthdays for the current month only if true
                        						maxEntries: 3,	     // maximum entries to show, default is all
                        						dateFormat: '',	     // date format for birthday (default is none), could be 'Do' for 'Sep 12th'
                        						ageFormat:'',	     // some format string for the persons age, '[ n ]'  n will be replace by age value
                        						withMonth: true ,    // then true, add the month display as part of the date field,
                        						debug:true,
                        warmest regards,
                        Ralf
                          Stefan, Jürgen and Chrizzy are shown - which is correct, as far as I understand the parameters.
                            sdetweil @rkorell
                            @rkorell correct, same as what i see. no fault tho
                            the init message appears to be an MagicMirror bug
                            i opened https://github.com/MagicMirrorOrg/MagicMirror/issues/3708
                              @sdetweil OK; thanks.
                              this is regarding the init error.
                              Yesterday night birthdaylist disappeared again.
                              And my initial finding is at least reproducable:
                              Birthdaylist disappears from physical screen (connected via HDMI) and from VNC remote session.
                              BUT: In webbrowser it disappears NOT:
                              If I do a reload in Webbrowser - instantly the birthdaylist appears on screen as well as in VNC session.
                              console log shows:
                              birthdaylist received a system notification: MODULE_DOM_UPDATED
                              I had assumed that I can find all of the console logs in the logfiles in $HOME/.pm2/logs but this is not true.
                              Any idea regarding this discrepancy?
                              Thanks again a LOT for your kind and great support!
                              Warmest regards,
                              Ralf
                              (sorry for the rubbish Browser - rendering but I’m not able (or too stupid) to scale this correctly)
                                sdetweil @rkorell
                                @rkorell ok, that message comes in response to a module updating its content. but I see a bug in my code i cant get to today
                                to work around it add another config parm for the module
                                debugging:true,
                                you will get additional messages during setup and nightly refresh (5 seconds after midnight by default)
                                maybe its not a bug, but a document error
                                  @sdetweil OK; cool.“workaround” is OK for me :-)
                                  so
                                  debug: true,
                                  AND
                                  debugging:true,
                                  both in your module?
                                  Again: Thanks a LOT.
                                  Ralf
                                    sdetweil @rkorell
                                    @rkorell yes, both
                                      @sdetweil OK, thanks.
                                      Have done.
                                        sdetweil @rkorell
                                        @rkorell you should have a couple days on redraw now, does it still disappear?
                                        Can you show the new debug info
                                          Dear Sam , @sdetweil - tahns for following up!!!
                                          No. With the “debugging” switch I did not see a disappearing again .
                                          Yes, for sure, I can see nothing “spectacular”…
                                          Can you derive something from this information?
                                          Warmest regads,
                                          Ralf
                                            sdetweil @rkorell
                                            @rkorell I don’t see the update just after midnight
                                            • 2 / 4
