    Question about backup script
    30 Posts 3 Posters 9.6k Views 3 Watching
    • N Offline
      nowayto
      Hello,
      I have a question about backup script.
      In these days I’m trying to learn how to configure MM with some modules, after all these tries, I will do a fresh installation with no errors on configuration.
      When I’ll arrive at that point, I’ll wanna backup MM entirely, so I see your script:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)” with any parms
      I don’t want a github private backup, I want just a local backup so does this script will backup every configuration on: $HOME/MM_backup ?
      I assume I’ll just have to copy that folder away and keep it secure?
      When I’ll need a restore I can start with an empty SD card, OS installation, MM installation script and then which of that 2 options?
      1- copy the MM_backup folder in $HOME, install modules I need and run your restore script
      (bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_restore.sh)” with any parms)
      2- copy the MM_backup folder in $HOME and just run the restore script
      Thanks in advance
        sdetweil @nowayto
        @nowayto restore, option 2 . restore will reinstall all the modules and copy any created files saved with them
        (What’s the point of having a restore tool if it doesn’t?)
        And restore will copy the GitHub repo down for you (part 1 of your option 2)
        now, on the github
        its the same as ‘copy the MM_backup folder someplace’
        backup also creates versions
        backup today and next week, and restore either one
        or one from last year
        github is free
        make a private repo
        N 1 Reply Last reply Reply Quote 2
        • N Offline
          nowayto @sdetweil
          Perfect.
          Your right but since I’m not a programmer so sometimes I have some stupid doubts.
          I started with a simple idea and now in my mind I wanna make more than one MM, with differents setup but for now I need to learn the basics configuration, so I’m testing testing and testing more :)
          Reinstall from 0 and test again :)
          For example I hope it will be not to difficult to config css, I like the personalization it will offer but I’m scared about difficulties. But I’ll try for sure!
          Thank you again
          S 2 Replies Last reply Reply Quote 1
            sdetweil @nowayto
            @nowayto also see my MMM-Config, it provides module install and all config
            N 1 Reply Last reply Reply Quote 1
              sdetweil @nowayto
              @nowayto css, learn the developers window.
              see the second link in my signature below
                @sdetweil Dear Sam,
                seen backup/restore days ago and as the question arises here - I struggle with the commend line :-(
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -h
                works - I get some hints - same as on your github repo.
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p
                doesn’t work?
                "illegal option '- ’ " is the error message.
                Where can I place the -p option?
                (inside the brackets I get an errormessage from curl …)
                This is also true if I add repo- and username and the token.
                There is my second question: how to pass the parameters?
                I’ve tried
                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p MagicMirror rkorell ghp_thisismyverylongandcryptictokenforgithub
                But with no luck.
                MagicMirror is a fresh created repo, rkorell is my username on GitHub - token is fresh created private token according your guidance in module description.
                Can you please help?
                Thanks a LOT -as always,
                Ralf
                  rkorell Module Developer @rkorell
                  @sdetweil ,
                  last trial (after digging in your script I understand that -p is not that correct…)
                  So I’ve figured out that reponame and username have their own prefix.
                  A prefix for the token is not present, so I assume user:token could be feasible.
                  So I came to
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh) -p -r MagicMirror -u rkorell:ghpthisismyverylongandcryptictokenforgithub"
                  But this doesn’t work either…
                  So I’m desparately looking for the right place to put in the right parameters in the right manner.
                  Sorry for being this dumb…
                  Regards,
                  Ralf
                    sdetweil @rkorell
                    @rkorell hm… I did
                    and got
                    -h takes optional parameters
                    	 -s MagicMirror_dir
                    		default /Users/sam/MagicMirror
                    	 -b backup_dir
                    		default /Users/sam/MM_backup
                    	 -m backup message
                    		 any message (in quotes) that you would like to attach to this change for later info
                    		default none
                    	 -p auto push to github (will need repo name, username,  user password or token
                    		default false
                    	 -r github repository name (reponame)
                    		typically https://github.com/username/reponame.git
                    		default output of git remote -v (if set)
                    		 -r overrides the git remote setting
                    	 -u github username
                    		default none
                    S R 3 Replies Last reply Reply Quote 0
                      @rkorell there was a typo in the help contents…
                      I NEVER ask for password/token… git will prompt if needed…
                      thus I cannot capture it in my script… a security confidence thing…
                        @rkorell -p by itself gives an error, will fix
                        in both scripts
                        -s is the MagicMirror folder
                        -b is the backup folder
                        -u is the github userid
                        -r is the repo name, short xxxx or long https:…/repo
                        if you use the long url, i will get the userid from there
                        in backup
                        -p is push if not specified script will NOT push to github
                        in restore
                        -f requests fetch the github repo. if not specified, the local -b folder will be used to restore from. if not found the script will abort
                        • N Offline
                          nowayto @sdetweil
                          @sdetweil said in Question about backup script:
                          I give it a try some days ago, after your suggestion but I wanna learn the configuration first, rather than easier ways
                          I’ll read your CSS guide for sure
                            sdetweil @nowayto
                            @nowayto yes, providing helpful tools hides the detail. a double edged sword
                            my objective is to help you get results.
                            • N Offline
                              nowayto @sdetweil
                              @sdetweil and I really thank you for that.
                              Thanks to you even more people will try MM and appreciate your work.
                              On my side I’m there to learn something new.
                              It’ more challenging but it’s also more interesting so I’d prefer manual ways.
                              Thanks a lot for your help, I’ll really appreciate that
                                hm… I did
                                Dear Sam (@sdetweil),
                                yes - this worked for me as well :-)
                                Now figured out how it works:
                                Have issued
                                bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -r https://github.com/rkorell/MagicMirror -p
                                Then I was asked for username and password (twice) and git upload worked…
                                It seems git upload now contains a copy of local directory mm_backup.
                                If I check both, there are only a few directoris in Github as well as locally - much fewer than total number of installed modules…
                                What is the criterium for a module to “earn” a directory or not?
                                Thanks a lot!
                                Warmest regards,
                                Ralf
                                  sdetweil @rkorell
                                  @rkorell the backup copies the url of the module source
                                  where you cloned from,
                                  see git remote -v in any module folder
                                  now some modules create files, token.json for example
                                  if i find extra files i need a place to store them, so the module name for a folder is created
                                  the module_list file contains the list of modules needed
                                  and their urls. they are reinstalled
                                  the readme says this
                                  this is not a binary backup
                                  you can use this to move to a new system or new sd card (changing processor architectures too, pc to pi, pi to pc… whatever)
                                  yes the folder MM_backup by default is a git source repository
                                  and git will track any changes (new backup differences)
                                  each time you back up, i create a marker to label this event, in git called a tag
                                  and you can restore any one of those and compare two tags to see the difference
                                  the private repo is because the files are saved in source form, and contain apikeys and maybe other credentials
                                  S R 2 Replies Last reply Reply Quote 1
                                    @rkorell you got prompted twice for username because git needs to know who you are and how to reach you if there are concerns about your “commit” to the repo. you csn see this in git log
                                    output in the backup folder
                                    this is username and email address
                                    then the push , github needs to know . this is the password prompt from git
                                    you could use git config to save those, and avoid the prompts
                                      Sounds cool.
                                      How can I do this?
                                      Thanks!
                                      Ralf
                                        sdetweil @rkorell
                                        @rkorell google is your friend
                                        how to use git config
                                          Thanks for this explanation - this is what I had assumed.
                                          Regards,
                                          Ralf
                                            OK, thanks.
                                            I had understood that this is a config of your scripts, sorry.
