    MMM-Chores - Manage and keep track of your household Chores
    104 Posts 19 Posters 36.6k Views 20 Watching
      JohnGalt @mischag
      @mischag – Are you using the port described in the documentation [5003]?
      See:
      Admin Interface
      Go to http://yourmirrorIP:5003/ #page will be reachable within same network.
      Caution
      DO NOT expose application with portforward
        mischag @JohnGalt
        @JohnGalt
        Yeah, I am. But I’m wondering if it’s because I am remoting in on a different port, that I can’t then access that port? I’ve checked the documentation heaps and can’t work it out. I even tried opening the html admin file within the ‘public’ folder, and I can open it but I can’t edit it. I can write the names and click on dates and everything, but when I press ‘add’ nothing happens. I’ve updated and it says it’s all up to date.
        plainbrokeP 1 Reply Last reply Reply Quote 0
        • plainbrokeP Offline
          plainbroke @mischag
          @mischag
          This is what I get when I login to MMMChores admin
          http://192.168.1.223:5003
          https doesn’t work for me. I don’t have it setup to work in my config.js.
          Are you trying to reach it from work or from home and it is in another building???
            mischag @plainbroke
            @plainbroke
            Yeah ok. I might have to try another way… but it’s definitely not working at the moment for me…
            The port doesn’t bring anything up for me other than the page saying it does not exist.
            I was hoping not to have it setup through the config folder but it was the only way I could find the admin interface. But then I couldn’t add people or tasks to it…
            plainbrokeP S 2 Replies Last reply Reply Quote 0
              plainbroke @mischag
              @mischag
              So are you trying to change things by going into MM/modules/MMM-Chores/data.json and editing it? I just tried that and it does not work.
              I think it is because the module assigns each grouping a specific ID that way beyond my paygrade… Wish I could be of more help…
              So are you accessing it remotely i.E. from a different network?
              Hope you figure it out…
              • PierreGodeP Offline
                PierreGode Module Developer @mischag
                @mischag
                Hi the ip adress id 192.168.1.whatevertheipofghepi:5003
                  PierreGode Module Developer @sarote
                  @sarote
                  It is done
                    sdetweil @PierreGode
                    @PierreGode .1 is typically the router , not the pi
                    on the MagicMirror system do
                    ip addr
                    PierreGodeP 1 Reply Last reply Reply Quote 0
                      PierreGode Module Developer @sdetweil
                      What?? 🤭
                      Like I said I think it is 192.168.subdomain.yourip ❤️
                      So yes you are right 1 could be 0 depending on your router. I mention http://yourmirrorip:5003/ in my readme for the reason that it can vary, it could even be 10. 24.x.x
                        @PierreGode yes. all my routers set their ip address to.1 of the assigned address range
                        home is 192.168.2.(1)
                        a test network i have it 10.0.2.(1)
                        all the devices start at .2
                        on linux
                        ip addr
                        will give this machine’s address
                        on windows its
                        ipconfig /all
                          supascoopa74 @mischag
                          @mischag I’m having the exact same problems that you describe here. Cannot connect to admin page via ip address/trying to use the admin.html page directly is non-responsive. Did you make any progress?
                            PierreGode Module Developer @supascoopa74
                            @supascoopa74 @mischag
                            I created a wiki on the repository I hope it helps.
                            https://github.com/PierreGode/MMM-Chores/wiki/MMM‐Chores-Wiki
                            KristjanESPERANTOK K S 3 Replies Last reply Reply Quote 1
                            • KristjanESPERANTOK Offline
                              KristjanESPERANTO Module Developer @PierreGode
                              @PierreGode The wiki page is empty :-(
                              S PierreGodeP 2 Replies Last reply Reply Quote 1
                                sdetweil @KristjanESPERANTO
                                @KristjanESPERANTO i see the link to the front page
                                  PierreGode Module Developer @KristjanESPERANTO
                                  @KristjanESPERANTO
                                  Thank you, updated
                                  • K Offline
                                    khayfer @PierreGode
                                    @PierreGode Hello, I’m having the same issues as supascoopa74 and mischag. I went through all the points in the wiki page and still unable to get to the admin page. Checked my firwalls and they were “open”… unsure how to proceed.
                                    S PierreGodeP 2 Replies Last reply Reply Quote 0
                                      sdetweil @khayfer
                                      @khayfer what is the address: setting in config.js
                                      it CANNOT be localhost. as thst mesns only apps INSIDE the same system can connect (a browser on the same system)
                                        supascoopa74 @PierreGode
                                        @PierreGode Thank you for the wiki. I didn’t realize the MagicMirror needs to be running for the admin page to work. Doh! It works now trying to access myPIip:5003 from another computer on my network.
                                          PierreGode Module Developer @khayfer
                                          @khayfer Hi!
                                          Could you tell me about your setup?
                                          Is it ”vanilla” raspberry pi setup?
                                          What is pm2 logs saying?
                                          • K Offline
                                            khayfer @sdetweil
                                            @sdetweil my apologies for the late reply, the stomach flu ravaged our home this past week.
                                            As for the address in config it is set to “local host” and it lists the raspberry pi 's ip address.
                                            • 6
                                            • 3 / 6
