    [MMM-Remote-Control] Cannot GET /remote.html
    17 Posts 5 Posters 7.8k Views 5 Watching
    • M
      mvrlogins
      On a new installation
      var config =
        address: '0.0.0.0',
        ipWhitelist: [
          '127.0.0.1',
          '::ffff:127.0.0.1',
          '::1',
          '10.0.1.1/24'
            module: 'MMM-Remote-Control',
              secureEndpoints: false
      The entire section is copied from another instance of MM where Remote-Control is working fine.
      On this new install I get
      Help!
      • Y
        Ypsimm @kasperb
        @kasperb
        In case you’re still interested…
        After fighting with this for I don’t know how long, for poops and giggles I changed the permissions on my modules/MMM-Remote-Control folder to full r/w for all users…
        Now I can access the remote control.
        YMMV, change permissions at your own risk, etc.
          sdetweil @mvrlogins
          @mvrlogins set
          ipWhitelist=[],
          '127.0.0.1',
          '::ffff:127.0.0.1',
          '::1',
          '10.0.1.1/24'
          the 1st 3 mean ONLY the same machine as MM is running on
          and then also ONLY from address 10.0.1.1
          • M
            mvrlogins @sdetweil
            Interesting
            I’ve had that on an instance of MM I’ve been running for 5-6 years with Remote -Control and it’s always worked fine.
            I’ve been able to access the display and remote from anywhere on the network.
            So I just copied it over to the new one
            • M
              mvrlogins @sdetweil
              I’ve now changed it to
              var config =
                address: '0.0.0.0',
                ipWhitelist: [],
              Same problem with Canot GET /remote.html
              http://10.0.1.87:8080/ works fine and I see the MM display
              http://10.0.1.87:8080/remote.html leads to the error
              • M
                mvrlogins @mvrlogins
                I removed the Remote-Control installation using
                rm -r -f  MMM-Remote-Control/
                Installed it using the instructions on the github repository
                cd ~/MagicMirror/modules
                git clone https://github.com/Jopyth/MMM-Remote-Control
                cd MMM-Remote-Control
                npm ci --omit=dev
                I now get the following - which doesn’t seem fatal at first glance -
                npm warn ERESOLVE overriding peer dependency
                npm warn While resolving: react-inspector@6.0.2
                npm warn Found: react@19.1.1
                npm warn node_modules/swagger-ui/node_modules/react
                npm warn   react@">=16.8.0 <20" from swagger-ui@5.29.0
                npm warn     swagger-ui@"^5.29.0" from the root project
                npm warn   2 more (react-dom, react-immutable-pure-component)
                npm warn
                npm warn Could not resolve dependency:
                npm warn peer react@"^16.8.4 || ^17.0.0 || ^18.0.0" from react-inspector@6.0.2
                npm warn node_modules/swagger-ui/node_modules/react-inspector
                npm warn   react-inspector@"^6.0.1" from swagger-ui@5.29.0
                npm warn
                npm warn Conflicting peer dependency: react@18.3.1
                npm warn node_modules/react
                  sdetweil @mvrlogins
                  @mvrlogins do
                  npm install
                  Instead of
                  npm ci
                  Will ONLY do exactly watch matches package-lock.json which is rarely correct
                  • M
                    mvrlogins @sdetweil
                    Redid the install using
                    npm install
                    No errors during install
                    Same problem
                    • M
                      Below from the pm2 log
                      0|MagicMir | [2025-09-21 16:44:59.284] [ERROR] Error when loading MMM-Remote-Control: require() of ES Module /home/pi/MagicMirror/modules/MMM-Remote-Control/node_modules/uuid/dist-node/index.js from /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js not supported.
                      0|MagicMir | Instead change the require of index.js in /home/pi/MagicMirror/modules/MMM-Remote-Control/API/api.js to a dynamic import() which is available in all CommonJS modules.
                      See https://stackoverflow.com/questions/70541068/instead-change-the-require-of-index-js-to-a-dynamic-import-which-is-available
                      S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                        sdetweil @mvrlogins
                        @mvrlogins yes, someone will have to update the module or downgrade the dependency in package.json
                        • KristjanESPERANTOK
                          KristjanESPERANTO Module Developer @mvrlogins
                          @mvrlogins said in [MMM-Remote-Control] Cannot GET /remote.html:
                          To make it clear here as well: “require() of ES Module ... not supported” shows that you are using a very old (unsupported) Node version. Like I said in the GitHub issue, you have to update Node.
                          I recommend using NVM to update Node (like recommended on the Node website).
                          K 1 Reply Last reply Reply Quote 1
                          • K
                            kasperb @KristjanESPERANTO
                            @KristjanESPERANTO said in [MMM-Remote-Control] Cannot GET /remote.html:
                            the Node website
                            Experiencing the same issue… Created a clean install of MM over the weekend and am getting the same error. NVM is updated. :-(
                              sdetweil @kasperb
                              @kasperb in config.js
                              address:”0.0.0.0”,
                              ipWhitelist:[],
                              • K
                                kasperb @sdetweil
                                @sdetweil Yup, that’s what I have - sample of config here:
                                let config = {
                                	address: "0.0.0.0",	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/",	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                	ipWhitelist: [],	// Set [] to allow all IP addresses
                                • Y
                                  Ypsimm @kasperb
                                  @kasperb
                                    sdetweil @Ypsimm
                                    @Ypsimm interesting. Git clone should set the permissions that way.
                                    Did you install the module some other way than git?
                                    • Y
                                      Ypsimm @sdetweil
                                      @sdetweil Originally? Quite possibly something other than git, but it’s been such a long time since I first installed that I couldn’t tell you for sure.
                                      Most recently, yes, git clone was one of the methods I tried after completely removing the module and attempting reinstalls. Not sure if the module install doesn’t do it like the full application clone would or what, but it’s been running just dandy since the manual change. I’m curious to see if anything changes after the next update or three.
                                        sdetweil @Ypsimm
                                        @Ypsimm ok, please make sure NOT to use sudo with any MagicMirror commands
