    Default Calendar Not Loading Events After New MM Update
    69 Posts 8 Posters 21.0k Views 8 Watching
      sdetweil @angeliKITTYx
      @angeliKITTYx so much fun. I hate when the tools only do half a job
      sudo apt install npm
      Then
      npm -v
      Then
      sudo npm install -g n
      sudo n 22.21.1
      hash -r
      node -v
      A 1 Reply Last reply
      • A
        angeliKITTYx @sdetweil
        it is just refusing to take 22.21.1
        Setting up node-es-abstract (1.20.4+~cs26.27.47-1) ...
        Setting up node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
        Setting up node-util (0.12.5+~1.0.10-1) ...
        Setting up node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
        Setting up node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
        Setting up node-assert (2.0.0+~cs3.9.8-2) ...
        Setting up webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
        Setting up node-parse-json (5.2.0+~cs5.1.7-1) ...
        Setting up node-read-pkg (5.2.0-2) ...
        Setting up node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
        Setting up node-tape (5.6.1+~cs8.20.19-1) ...
        Setting up node-css-loader (6.7.2+~cs14.0.11-1) ...
        Setting up node-tap (16.3.2+ds1+~cs50.8.16-1+deb12u1) ...
        Setting up node-deep-equal (2.1.0+~cs31.12.80-1) ...
        Setting up npm (9.2.0~ds1-1) ...
        Processing triggers for man-db (2.11.2-2) ...
        kittypi@KITTYpi:~/MagicMirror $ npm -v
        11.13.0
        kittypi@KITTYpi:~/MagicMirror $ sudo npm install -g n
        sudo n 22.21.1
        hash -r
        node -v
        added 1 package in 2s
          installing : node-v22.21.1
               mkdir : /usr/local/n/versions/node/22.21.1
               fetch : https://nodejs.org/dist/v22.21.1/node-v22.21.1-linux-arm64.tar.xz
             copying : node/22.21.1
           installed : v22.21.1 (with npm 10.9.4)
        Note: the node command changed location and the old location may be remembered in your current shell.
                 old : /usr/bin/node
                 new : /usr/local/bin/node
        If "node --version" shows the old version then start a new shell, or reset the location hash with:
        hash -r  (for bash, zsh, ash, dash, and ksh)
        rehash   (for csh and tcsh)
        v22.19.0
        kittypi@KITTYpi:~/MagicMirror $ node --version
        v22.19.0
        kittypi@KITTYpi:~/MagicMirror $ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        bash: $: command not found
          @angeliKITTYx
          The last command you have an extra leading $
          When you copy/paste you only need to hit the little rectangle button at the en
          But you dont need all that . The code is downloaded
          Just do
          cd ~/MagicMirror
          npm run install-mm
          • A
            how do i do percussive maintenance on code xD
            kittypi@KITTYpi:~/MagicMirror $ cd ~/MagicMirror
            npm run install-mm
            > magicmirror@2.35.0 install-mm
            > npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
            npm error code EBADENGINE
            npm error engine Unsupported engine
            npm error engine Not compatible with your version of node/npm: magicmirror@2.35.0
            npm error notsup Not compatible with your version of node/npm: magicmirror@2.35.0
            npm error notsup Required: {"node":">=22.21.1 <23 || >=24"}
            npm error notsup Actual:   {"node":"v22.19.0","npm":"11.13.0"}
            npm error A complete log of this run can be found in: /home/kittypi/.npm/_logs/2026-04-28T20_16_16_675Z-debug-0.log
              @angeliKITTYx the end of your prior log post says 22.21.1 is installed
                 installed : v22.21.1 (with npm 10.9.4)  <-----
              are you in the same terminal window??
              if so, you need
              hash -r
              to capture the path change
              do
              which node
              so we can see where it it located…
              @angeliKITTYx
              • A
                all the same terminal window. i don’t have anything else open. i know it says 22.21.1, but then node version says 19… very odd.
                kittypi@KITTYpi:~/MagicMirror $ hash -r
                kittypi@KITTYpi:~/MagicMirror $ which node
                /usr/local/node/bin/node
                v22.19.0
                  @angeliKITTYx ok, close that window and open another and
                  try the node --version again
                  • A
                    closed the terminal, opened a new terminal…
                    kittypi@KITTYpi:~ $ node --version
                    v22.19.0
                    kittypi@KITTYpi:~ $ cd MagicMirror
                    v22.19.0
                      @angeliKITTYx weird
                      Do
                      which node
                      Go to that folder
                      sudo mv node onode
                      hash -r
                      which node
                      node —version
                      • A
                        kittypi@KITTYpi:~/MagicMirror $ cd ..
                        kittypi@KITTYpi:~ $ which node
                        kittypi@KITTYpi:/ $ cd usr
                        kittypi@KITTYpi:/usr $ cd local
                        kittypi@KITTYpi:/usr/local $ cd node
                        kittypi@KITTYpi:/usr/local/node $ cd bin
                        kittypi@KITTYpi:/usr/local/node/bin $ cd node
                        bash: cd: node: Not a directory
                        kittypi@KITTYpi:/usr/local/node/bin $ sudo mv node onode
                        hash -r
                        which node
                        node —version
                        /usr/local/bin/node
                        node:internal/modules/cjs/loader:1386
                          throw err;
                        Error: Cannot find module '/usr/local/node/bin/—version'
                            at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                            at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                            at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                            at Function._load (node:internal/modules/cjs/loader:1192:37)
                            at TracingChannel.traceSync (node:diagnostics_channel:328:14)
                            at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:171:5)
                            at node:internal/main/run_main_module:36:49 {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: []
                        Node.js v22.21.1
                          @angeliKITTYx i hate this editor on my phone changing the characters
                          do
                          node --version
                          it should report 22.21.1
                          then
                          cd ~/MagicMirror
                          npm run install-mm
                          • A
                            it’s booting now! hurray! however, now I’m getting the package lock error when i try to complete the calendarext3 update and none of my events are populating. I have a thread up on someone else’s trouble shooting but I’m out of time this morning. I be back at it this afternoon. thank you again for all your help.
                              @angeliKITTYx awesome. Thanks for the feedback
                              package-lock? Erase that file then do the update
                              There is a known bug affecting modules that have functions in their config like ext3. We are discussing ways to distribute these fixes.
                                Did you get the npm run install-mm done after verifying node version was correct?
                                • A
                                  yes I did the npm run install-mm successfully.
                                  i got it updated, but now it’s angry again
                                  [2026-04-29 18:51:43.521] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "Ortho": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.522] [ERROR] [calendar] Could not expand event "WD CNU": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.523] [ERROR] [calendar] Could not expand event "HVAC DUCTING FIX": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Injection appt time TBD": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.524] [ERROR] [calendar] Could not expand event "Env. Regulations": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.525] [ERROR] [calendar] Could not expand event "Z4 training": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.526] [ERROR] [calendar] Could not expand event "Jury Duty ": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.527] [ERROR] [calendar] Could not expand event "MATH 260: Linear Algebra ": ical.expandRecurringEvent is not a function
                                  [2026-04-29 18:51:43.527] [INFO]  [calendar] Broadcasting 0 events from https://calendar.google.com/calendar/ical/axxxxx/basic.ics.
                                  [2026-04-29 18:52:09.449] [LOG]   [electron] Shutting down server...
                                  [2026-04-29 18:52:09.452] [LOG]   [node_helper] Stopping module helper: updatenotification
                                  [2026-04-29 18:52:09.462] [LOG]   [node_helper] Stopping module helper: calendar
                                  [2026-04-29 18:52:09.464] [LOG]   [node_helper] Stopping module helper: MMM-CalendarExt3
                                  [2026-04-29 18:52:09.469] [LOG]   [node_helper] Stopping module helper: MMM-Jokes
                                  [2026-04-29 18:52:09.470] [LOG]   [node_helper] Stopping module helper: weather
                                  [2026-04-29 18:52:09.473] [LOG]   [node_helper] Stopping module helper: MMM-Todoist2
                                  [2026-04-29 18:52:09.478] [LOG]   [app] Node_helpers stopped ...
                                  v22.21.1
                                    @angeliKITTYx looks like you didn’t do that in the MagicMirror folder
                                    cd ~/MagicMirror
                                    npm run install-mm
                                    • A
                                      I did it originally in the MM folder, but I ran it again and still getting the same errors
                                      I did catch this before the entire terminal filled up with “: ical.expandRecurringEvent is not a function”
                                      [2026-04-29 19:59:54.445] [LOG]   [server] Starting server on port 8080 ...
                                      [2026-04-29 19:59:54.499] [ERROR] [unknown] (node:58997) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                      (Use `electron --trace-deprecation ...` to show where the warning was created)
                                      [2026-04-29 19:59:54.855] [LOG]   [app] Server started ...
                                      [2026-04-29 19:59:54.858] [LOG]   [node_helper] Connecting so```
                                        @angeliKITTYx that means the install-mm did not work
                                        Please do again and show the output
                                        • A
                                          kittypi@KITTYpi:~ $ cd ~/MagicMirror
                                          npm run install-mm
                                          > magicmirror@2.35.0 postinstall
                                          > git clean -df fonts vendor modules/default
                                          > magicmirror@2.35.0 prepare
                                          > [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                          no husky installed.
                                          up to date in 3s
                                            @angeliKITTYx ok then, one more time
                                            cd ~/MagicMirror
                                            rm package-lock.json
                                            rm -rf node_modules
                                            npm run install-mm
                                            • 3 / 4
