    MagicMirror on Pi Zero W
    46 Posts 19 Posters 68.9k Views 21 Watching
      Mitchfarino Module Developer @Hawking
      @Hawking Thanks for all your help and comments, I’ve managed to get it up and running now!
      Now I just need to get the whitelist sorted :grimacing:
      • H Offline
        Hawking @Mitchfarino
        @Mitchfarino said in MagicMirror on Pi Zero W:
        No problem.
        This worked fine for me, I just added the IP of my regular PC (e.g 192.168.2.185) to the list in the config file so that it looked like
        ipWhitelist: ["192.168.2.185", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
        If I then typed the ip:port (the port is also defined in the MM config, default is 8080) of my raspi (e.g.
        http://192.168.2.170:8080/
        ) in the browser bar of my regular PC I could see the page also on my regular PC (took 1-2 seconds to load).
        If this does not work for you, just open a new thread and provide details.
        • C Offline
          CaptnJB
          BLANK SCREEN, NO CLOCK/CALENDAR/MOMENTS solved and simplified from other topics and posts:
          After you follow the instructions in the first post to #23 then jump to here:
          24 cd ~/MagicMirror/vendor
          25 npm install
          26 sudo reboot
          I’m not a linux expert, but I built this a few weeks back before the latest version of MM and it worked flawlessly. There should be a hook in the original package.json that kicks it into the vendor directory and runs “npm install” there but it doesn’t happen now (5/3/2017).
          Also, for those of you who do not have a monitor, after you SSH into your Rpi Zero W:
          sudo raspi-config
          5 interfacing options
          P3 VNC
          YES you want to enable the VNC server
          reboot when it asks.
          Use VNC Viewer or whatever, connect to your rpi using either ip address or if you set it up in your DHCP table with a :0 (zero) to see your screen or :1 to have a desktop.
          CaptnJB
          • kylelmartinK Offline
            kylelmartin @Iseknutz
            This post is deleted!
              @Iseknutz said in MagicMirror on Pi Zero W:
              I installed the image from https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero/84 , updated the System to use the onboard wifi and this works for me.
              @Iseknutz
              At least I can get this method up and running on my RPI0w, but what’s the trick to updating the system to use the onboard wifi? I’ve created the wpa_supplicant.conf and I’ve even jacked with the etc/network/interfaces - but no luck getting it to connect to the network.
              Thx
              C I 2 Replies Last reply Reply Quote 1
              • C Offline
                CaptnJB @kylelmartin
                @kylelmartin can you post or pm your WPA_supplicant.conf file? Please remove your passwords and maybe change your wifi name if that makes you feel better.
                How are you updating your wpa-supplicant through a terminal or by copying it onto your card? Windows or Mac?
                CaptnJB
                kylelmartinK 1 Reply Last reply Reply Quote 0
                  kylelmartin @CaptnJB
                  @CaptnJB
                  here is the wpa_supplicant.conf file - or at least the latest rendition of it.
                  country=US
                  ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
                  update_config=1
                  network={
                      ssid="KLM-Guest"
                      key_mgmt=NONE
                      priority=1
                      id_str="guest"
                  network={
                      ssid="mywebsite.com"
                      psk="oldasspw"
                      priority=2
                      id_str="klm"
                  My regular old wifi network name has a “.” in the name and I thought that might cause some problems. So, I set up a second guest wifi network so this device wouldn’t need a password.
                  • C Offline
                    @kylelmartin, I apologize for the delay just landed in Madrid. For starters I would take out the id lines. Keep it simple. Try this.
                    country=US
                    update_config=1
                    network={
                        ssid="KLM-Guest"
                        psk=""
                        priority=1
                    network={
                        ssid="KLM"
                        psk="oldasspw"
                        priority=2
                    Also, mywebsite.com should be be your router ssid. If you have it set to that “mywebsite.com” in the file you gave it is most likely “KLM”.
                    Why would you want the guest network to have priority?
                    CaptnJB
                    • I Offline
                      Iseknutz @kylelmartin
                      @kylelmartin after the Update to the actual OS, the Onboard-WiFi from my raspi0 was automatically enabled. Did you use the Desktop or console?
                      C kylelmartinK 2 Replies Last reply Reply Quote 0
                      • C Offline
                        CaptnJB @Iseknutz
                        @Iseknutz I use ssh and nano. I also am a Mac user.
                        I’m glad it’s working
                        CaptnJB
                          @Iseknutz
                          What do you mean by “after the Update to the actual OS”? I used the image linked above. I can’t do an update/upgrade as I have no internet connection. I’m using the console on the Pi and editing my conf in Mint Linux. I’m using Jessie Lite rather than the full install.
                          @CaptnJB
                          Thanks for the rewrite on the wpa_supplicant, but it still won’t connect to any provided wifi network.
                          Thanks to all.
                          • I Offline
                            @kylelmartin I have connected an USB Wlan Dongle (Edimax, working without extra software) and do the update. Im using Jessie Lite and later I installed the desktop.
                            Sorry for my bad english ;)
                            • C Offline
                              CaptnJB @Iseknutz
                              @Iseknutz
                              Greetings from Toulouse. To do the update and upgrade, from the terminal type:
                              sudo apt-get update
                              sudo apt-get upgrade
                              After the installation of the new updated packages, sudo shutdown. Wait. Remove the power and your edimax adapter and connect power. Now does it work?
                              JB
                                @CaptnJB @Iseknutz
                                Silly me! I should have known that to get a wifi adapter to work I needed a wifi adapter!
                                Fortunately I had a usb splitter with power supply and an edimax wifi lying around.
                                After the update and upgrade its working well.
                                Your help was greatly appreciated.
                                Thanks from Texas!
                                KLM
                                • markbajajM Offline
                                  markbajaj @rootsudo
                                  @rootsudo Thank you!
                                  This along with post number 23 got my Pi Zero and Pi zero W working perfectly :)
                                    andreas-becker
                                    @rootsudo said in MagicMirror on Pi Zero W:
                                    The Beginnings:
                                    1. Place wpa_supplicant.conf in Boot folder of SD card
                                    2. Boot SD card and login
                                    3. Enable SSH: sudo raspi-config -> Select Interfacing Options -> select SSH -> select Enable -> select Finish
                                    After step 4 i recommend creating an empty file called “ssh” and also put it in the Boot folder of the SD card.
                                    So you don’t have to do step 6, cause ssh is started on boot with the default credentials (user: pi, password: raspberry)
                                    After boot, it did not open the browser, instead it just showed the console window.
                                    Problem was solved by installing x-server with sudo apt-get install xserver-xorg
                                    • 1 Offline
                                      12wsx
                                      my I please someone to make an image of sd card with installed and working MM? i’m trying about week to run MM on piZero and nothing… all the time diffrent errors which i don’t understand.
                                      Andrius okA 1 Reply Last reply Reply Quote 0
                                      • G Offline
                                        geeklimit @rootsudo
                                        • Andrius okA Offline
                                          Andrius ok @12wsx
                                          Hi @12wsx try this thread https://forum.magicmirror.builders/post/32731
                                            bmarofsky
                                            tried on stretch lite and got this
                                            pi@raspberrypi:~/MagicMirror $ sudo npm install
                                            npm WARN engine http-auth@3.2.3: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                            npm WARN deprecated coffee-script@1.10.0: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                            npm WARN engine apache-crypt@1.2.1: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                            npm WARN engine apache-md5@1.1.2: wanted: {"node":">=4.6.1"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                            npm WARN engine hawk@6.0.2: wanted: {"node":">=4.5.0"} (current: {"node":"4.2.1","npm":"2.14.7"})
                                            • 2 / 3
