    PIR-Sensor - put your mirror to sleep if not used
    126 Posts 37 Posters 259.9k Views 20 Watching
    • KirAsh4K
      KirAsh4 Moderator
      Errr, in your package.json you have a reference to Wunderlist module in the description.
      paviroP 1 Reply Last reply
      Reply Quote 1
      • paviroP
        paviro @KirAsh4
        @KirAsh4 Fixed thanks :)
        – The Doctor
        • pugslyP
          pugsly
          I don’t have the sensor yet, but installed the module and put the entry into my config.js and when I start mm I get a white screen. Is that normal because I do not have the sensor hooked up yet?
          • EoFE
            EoF
            This is awesome! I will definitely be using this when I get my mirror built.
            • paviroP
              paviro @pugsly
              @pugsly I am busy this weekend but I will check next week, for the time being check your web inspector for any errors and make sure there is no mistake in your formatting of the config.js file!
              – The Doctor
              • P
                PtrBld Module Developer
                @pugsly: Are you using Node v6? I had the same issue this weekend.
                • I
                  incubik
                  Hi! Im having the same issue as @pugsly. I do already have the PIR sensor connected but once I launch the MagicMirror the screen goes white.
                  This is what I have in the config.js:
                  module: "MMM-PIR-Sensor',
                  sensorPIN: '2'
                  Any thoughts? Thx!
                  • I
                    incubik
                    There was a type on my message… sorry. This is what I have done:
                    module: 'MMM-PIR-Sensor’,
                    sensorPIN: ‘2’
                    Note from admin: Please use Markdown on code snippets so it is easier to read!
                    • paviroP
                      paviro @incubik
                      @incubik have you checked your Web inspector?
                      – The Doctor
                      • I
                        incubik
                        I have Raspbian install so Im using Epiphany. Does this browser has a web inspector? if so, where? Thx
                        • pugslyP
                          pugsly
                          I got my sensor and hooked it up, same problem.
                          Yes, I am using node version 6.0. When I did the install that’s the version that was installed, I think the install script now installs an older version?
                          • BangeeB
                            Bangee Module Developer
                            I’ve tried to use PIN 26. In my electron errorlog, there was this msg:
                            [Error: digitalRead: IsInt32(arguments['pin']) === false]
                            So I went back to PIN 22 and now my mirror starts again. :-)
                            EDIT:
                            New idea -> Try without ’ ';
                            sensorPIN: 2 ,
                            Reply Quote 2
                            • paviroP
                              paviro @incubik
                              @incubik I don’t use that browser, Google it :)
                              @pugsly Node v6 is not supported at the moment.
                              @Bangee yes, the pin has to be an int :) @incubik you also made that mistake!
                              – The Doctor
                              • I
                                incubik
                                Ok, I will!
                                Maybe it is a hardware problem? I’ve connected the PIR-sensor this way, is this correct?
                                https://www.raspberrypi.org/learning/physical-computing-guide/connect-pir/
                                • paviroP
                                  paviro @incubik
                                  @incubik Looks fine, the hardware does not influence the module behavior tough, you could also run it without something connected.
                                  – The Doctor
                                  • I
                                    incubik
                                    Ok, so if it doesn’t support v6, how can @Bangee made it work? I guess I should:
                                    1. Uninstall NodeJS v6 and install v5
                                      or
                                    2. Delete the Sensor Module for now
                                    • paviroP
                                      paviro
                                      When I checked it did not work, maybe the dependencies were updated since then. If not install v5 :)
                                      – The Doctor
                                      • BangeeB
                                        This PDF shows how to adjust your PIR Sensor.
                                        https://cdn.openimpulse.com/blog/wp-content/uploads/wpsc/downloadables/DYP-ME003_PIR_Sensor_Module_Datasheet.pdf
                                        Today, i don’t know why but after a few minutes the monitor turns off, but then it reactivates again without any motion in front of the mirror. Any sugestions?
                                        • paviroP
                                          paviro @Bangee
                                          @Bangee you can always try to add some logging to the code console.log("something") to see where it is triggered and if the script is the cause or something else :)
                                          – The Doctor
                                          • BangeeB
                                            This is all 10 seconds. But there is noone in front of the mirror… :-(
                                            meteoblueForecast received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                                            logger.js (Zeile 20)
                                            newsfeed received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                                            clock received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                                            calendar received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                                            swisstransport received a module notification: USER_PRESENCE from sender: MMM-PIR-Sensor
                                            • 6
                                            • 7
                                            • 1 / 7
