    Show SMS text message on Mirror
    17 Posts 5 Posters 12.8k Views 4 Watching
    • H Offline
      hawkesley
      Hi, New to this forum so a general question.
      I would like to show SMS messages on my mirror, fed from my local server. My server is apache, php & wordpress. The functionality works fine but for some messages I would like to forward the SMS and display on the mirror.
      Is this possible and if so how to approach it?
      I have looked at MM-iFrame but cannot get that to work.
      Any suggestions welcome.
        broberg Project Sponsor
        https://github.com/ronny3050/phone-notification-mirror
        Maybe?
        • H Offline
          hawkesley @broberg
          @broberg Thanks for that. I did see the module, but as I understand it this will just notify that there is a message , rather than display it?
          The intended use I have is to display the message because the viewer may not be able to use a mobile phone.
          I can send the message to my website and maybe forward it to the mirror from there perhaps using the wordpress api. This is much more complicated though.
            broberg Project Sponsor @hawkesley
            @hawkesley reading the readme file tells you that you can set displayMessage to true, ie display the message is possible. Install it and try it. Eitherway you need some app like pushbullet to forward the sms text to other devices.
            • H Offline
              hawkesley @broberg
              @broberg Ok. Will do if pushB is available for iphone.
              Also just discovered MM-syslog which looks promising if it can use an http get i guess?
                https://www.pushbullet.com, yes works with ios.
                The syslog module works simply enough via http get,
                • H Offline
                  hawkesley
                  Thanks will try both.
                  • H Offline
                    hawkesley @hawkesley
                    @hawkesley
                    Trying MMM-syslog but cant get access.
                    This device is not allowed to access your mirror.
                    Please check your config.js or config.js.sample to change this.
                    I modified the whitelist as follows :e-mail:
                    port: 8080,
                    	ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:192.168.1.1/24", "::ffff:192.168.1.109","::ffff:127.0.0.1", "::1"],
                    The http is : http://192.168.1.112:8080/syslog?type=normal&message=Test Message
                    Any thoughts appreciated.
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @hawkesley
                      @hawkesley did you insert exactly what was showing in the error to the whitelist?
                      • Y Offline
                        yawns Moderator
                        To test, if MMM-syslog suits your requirements you could simply set ipWhitelist: [], which will allow all connections. In addition you might want to check this thread. In your case you could try to add "192.168.1.1/24" to support IPv4
                        • H Offline
                          hawkesley @yawns
                          @yawns Thanks, will look at that.
                          In reply to strawberry I inserted this “::ffff:192.168.1.109”,
                          Access denied on CLI was 192.168.1.109
                          • H Offline
                            @hawkesley Hi,
                            I tested ipW [] and that worked for MMM-syslog.
                            I changed the ipW as suggested with “192.168.1.1/24” and that also works.
                            So, thanks very much both.
                            My remaining question is if I can send the message to MMM-syslog from outside my local network with this ipW?
                            I will try later today.
                            • Y Offline
                              yawns Moderator
                              If you set up some port forwarding in your router and experiment with ipWhitelist that should work
                              • michael24hM Offline
                                michael24h
                                @hawkesley said in Show SMS text message on Mirror:
                                I install phone-notification-mirror as well. AlsoI installed MMM-syslog which working ok.
                                http://MY-MIRROR-ip-ADRRESS/syslog?type=INFO&message=TEST, showing up on screen.
                                but when I add module: phone_notification to config.js, I get only black screen
                                my config:
                                				module: 'phone_notification',
                                            position: 'bottom_left',
                                            header: 'Phone Notifications',
                                            config:{
                                					accessToken: "......token.......",
                                					numberOfNotifications: 5,
                                					displayNotificationIcon: true,
                                					displayMessage: false,
                                					displayCount: false,
                                					alert: false,
                                					fade: true,
                                					maxCharacters: 50
                                • H Offline
                                  hawkesley @michael24h
                                  @michael24h check you have the folder for phone notifications named correctlry in modules folder. Balck screen happened a couple of times for me and this was the problem.
                                    michael24h
                                    yea, thats was problem. I notice after post question
                                      michael24h
                                      Still no notification receive
                                      how i can fix the issue?
