    Wunderlist - your todos on the mirror
    113 Posts 27 Posters 202.3k Views 22 Watching
      jagerpower @paviro
      @paviro alt text
      paviroP 1 Reply Last reply Reply Quote 0
      • paviroP Offline
        paviro @jagerpower
        @jagerpower also toggle the array in the array until there is nothing else to toggle…
        We're all stories in the end. Just make it a good one, eh?
        – The Doctor
          jagerpower @paviro
          @paviro do i need to toggle these too?
          alt text
          • paviroP Offline
            paviro @jagerpower
            @jagerpower sorry forgot about those… Will add a Screenshot to this post when I am home.
            – The Doctor
            • laknermiL Offline
              laknermi
              Sorry to start a new question thread but how do you determine the app url and auth callback url to get the token from Wunderlist? I know it must be very simple but I can’t seem to figure it out. Is the app url just http://localhost:8080?
              KirAsh4K paviroP 2 Replies Last reply Reply Quote 0
              • KirAsh4K Offline
                KirAsh4 Moderator @laknermi
                @laknermi, you can start your own new topic with your question(s) posted. It’s preferred that way, so we keep the discussions on-topic for the original poster. And then someone more familiar with that module can reply to you.
                laknermiL 1 Reply Last reply Reply Quote 0
                • laknermiL Offline
                  laknermi @KirAsh4
                  @KirAsh4 Thanks!
                  • paviroP Offline
                    paviro @laknermi
                    @laknermi does not matter just leave it as it is when you create the app.
                    – The Doctor
                    • paviroP Offline
                      paviro
                      Hey all of you! :slight_smile:
                      Please try again with the updated version from GitHub!
                      Thanks to @MichMich for now knowing how to better handle API requests in Node :D
                      – The Doctor
                      • laknermiL Offline
                        laknermi @paviro
                        @paviro Hmmm… The developer portal at Wunderlist will not allow me to create a new app if I don’t provide an app URL and Auth callback URL.
                        • paviroP Offline
                          paviro @laknermi
                          @laknermi then set it to http://localhost I thought it was the default.
                          – The Doctor
                          • laknermiL Offline
                            laknermi @paviro
                            @paviro Okay. I’ll try creating a new token with app URL and callback URL set to http://localhost.
                            • laknermiL Offline
                              laknermi @laknermi
                              @laknermi "@paviro
                              Referencing my post for posterity
                              I got it to work! I created a new app in Wunderlist and set the App URL to “https://a.wunderlist.com/api/v1/lists” and Auth Callback URL to “http://localhost:8080” then applied the accessToken and clientID as @jagerpower did above.
                              • paviroP Offline
                                paviro @laknermi
                                @laknermi the App url should not be necessary :) or can be set to anything, like the callback too.
                                – The Doctor
                                • laknermiL Offline
                                  laknermi @paviro
                                  @paviro In that case, your updated version works great! (Which by the way is incredibly cool!!! :dark_sunglasses: )
                                  • paviroP Offline
                                    paviro @laknermi
                                    @laknermi glad you like it :slight_smile:
                                    – The Doctor
                                      jagerpower
                                      @paviro I reinstalled my MM and it works now. Thank you for this module
                                      • Wilco89W Offline
                                        Wilco89
                                        Looks like i’ve got same issue,
                                        tried the Curl line you said before, that gives me the info tht is is all correct.
                                        but nothing shows up.
                                        • Wilco89W Offline
                                          Wilco89
                                          Seems to work after a second npm install.
                                            mikmonken
                                            Hi, i’m having some problems with this too.
                                            tokens and client ID are generated, and wanderlist appears on my mirror but non of this list content.
                                            and when i run the curl command i get this.
                                            {“error”:{“type”:“server_error”,“translation_key”:“api_error_unknown”,“message”:“An unknown server error occurred”,“authentication”:[“missing”]}}
                                            i am a complete novice and just trying to follow instructions, but i’ve clearly messed up somewhere.
                                            Access token and client id are taken as the values that are labelled just that.
                                            heres what i have in my config.js ££££ have replaced numbers
        module: 'MMM-Wunderlist',
        position: 'left',  // This can be any of the regions. Best results in left or right regions.
        header: 'To Do', // This is optional
        accessToken:    '07ad3c20bb0500b£££££££££££££££££a759b6a7e07da2',
        clientID:       'f1££££££££££££££££££1eb',
        lists:          ["Inbox"],
        maximumEntries: '60',
        interval:       '1',
        fade:           'true',
                                            any help would be really appreciated.
                                            Note from Moderator: Please use Markdown on code snippets for easier reading.
                                            • 6
                                            • 3 / 6
