    stumped newbe
    40 Posts 3 Posters 24.6k Views 3 Watching
    • T Offline
      trader dude
      i have magic mirror installed but can’t get the weather to show everything else works but no weather shows up .when I start magic mirror I see it says that Im missing help module .I did add new config file and can change the time (12 to 24) format . I did put my api and location id in the config file but that is not the problem . Help! please I have wiped and reinstalled many time.
      Mykle1M T 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @trader dude
        @trader-dude said in stumped newbe:
        Can you post that error about the missing module here so people can look at it. It wouldn’t hurt to post your config here too. This way you can get help
        • T Offline
          trader dude @trader dude
          @trader-dude https://goo.gl/photos/G3sjCeaCrNBEXCfs6
          • T Offline
            trader dude @Mykle1
            @Mykle1 ok i posted some pic hope this helps
            • T Offline
              trader dude
              This post is deleted!
                Here is my entry for weather. Please post yours here so I can see it
                		module: "currentweather",
                		position: "top_right",	// This can be any of the regions.
                			locationID: "", //Location ID from http://openweathermap.org/help/city_list.txt
                			appid: "abcde12345abcde12345abcde12345ab" //openweathermap.org API key.
                  Mykle1 Project Sponsor Module Developer @Mykle1
                  Just copy your config.js file and past it here, as I have done above
                  • T Offline
                    trader dude
                    https://goo.gl/photos/2GKDMrT24BDquX498
                      @trader-dude It’s not very easy to see those pictures so it’s difficult for me to help you. Can you paste your config here instead of linking it to a picture?
                        @Mykle1 Just put XXXXXXXXXXXXXXXXX where your api key goes
                        • yawnsY Offline
                          yawns Moderator
                          There is no error message, it just says there is no helper module. That’s fine, these modules don’t use a helper module.
                          There was another guy some days ago with the same trouble, but he switched to Wunderground so we were unable to troubleshoot
                          • T Offline
                            @trader-dude does that help?give me a sec i will do that
                              @trader-dude Lets start with locationID: That is usually a 6 digit number obtained from openweathermap.org. e.g 512856. Make sure that is correct. Next, the appid: is just a long sequence of numbers and letters obtained from openweathermap.org. e.g 12345gu3454uddu4u5uu64u3. Make sure you enter this exactly as provided. Do not enter the entire url, just the number itself. You need to do that in both the currentweather and weatherforecast.
                              • T Offline
                                trader dude @Mykle1
                                @Mykle1 that i have can i post That?
                                  your appid? No, don’t post that. That is yours and it is private
                                  • T Offline
                                    @trader-dude i had first installed the first version of magic mirror and used a different type of install i think it was called python it worked with my api code.
                                      @trader-dude Are you using MagicMirror version 2.1 now?
                                      • T Offline
                                        trader dude
                                        there is some kind of warning that comes up when i install the magic mirror
                                        • T Offline
                                          trader dude
                                          yes I’m using 2.1
                                            @trader-dude There are some warnings that don’t affect the operation of the mirror. Errors are another story
