    Config File stopped working after update
    7 Posts 3 Posters 3.9k Views 3 Watching
    • B
      bocapie
      So I installed the update. I use the same config file as before the update. I get a config error. I used Jshint and get zero error.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @bocapie
        @bocapie
        Try copying and pasting the config.js.sample, renaming it to config.js (after renaming your old config so you don’t lose it) and see if that works. If it does you can copy over the entries from your old config.
        • B
          bocapie @Mykle1
          @Mykle1
          Just did that and get the same error.
          Mykle1M 2 Replies Last reply Reply Quote 0
          • Mykle1M
            @bocapie
            Assuming your console isn’t showing any errors, then I would go to the repo and grab the config.js.sample from there to be sure it’s the new one from MM 2.1.1 and try again
            • Mykle1M
              @bocapie
              Also, read this post. Even a Module Developer is having some troubles with the update. However, he did find a workaround that worked for him.
              https://forum.magicmirror.builders/topic/2190/mm-died-after-upgrade/5
              • B
                bocapie
                I got it to load at the bottom line module was with a ’ instead of a "
                hartattackH 1 Reply Last reply Reply Quote 1
                • hartattackH
                  hartattack @bocapie
                  @bocapie said in Config File stopped working after update:
                  When I was first setting up my mirror, I had a bunch of typos that ruined it. Glad you figured it out!
